Results 1 to 5 of 5
Reload Thread: Hooking up two amps
    BigSteezie's Avatar
    BigSteezie is offline Junior Member
    Aug 2004
    Nob City,Ind
    27
    Hooking up two amps
    I was wondering if i could hook up my rca cables from my head unit into my jbl bp1200.1 and out of that same amp into my crappy pyramid 4-channel 300w amp to power the rest of my speakers. Or, would i have to run y-adapters with one rca cable going to each amp seperately?
    sumone's Avatar
    sumone is offline CarAudio.com Veteran
    Dec 2003
    Midwest
    3,416
    Re: Hooking up two amps
    does the jbl have a line out? If so, ques. 1 = yes. This signal is usually unprocessed (aka pass-through)
    best sig of all time
    DBfan187's Avatar
    DBfan187 is offline Supa's mom was here!
    Jan 2003
    Poolside with Supa's mom.
    46,449
    11 Post(s)
    Yes you can. It's called 'daisy chaining'. Just set the gains correctly and wang away.
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    but if you do it that way, you can't use your sub volume out on your head unit, if that's important to you.
    When I hooked up my front amp, I just used another set of RCA's to hook it up, so I could independently control each amp...
    maniackilla's Avatar
    maniackilla is offline cout<<"c++";
    Jul 2003
    McKenzie, TN
    804
    Quote Originally Posted by Jack Frost
    agreed, if your HU supports multi preouts
  1. hooking up two amps to my deck! help!
    By TheAnswer808 in forum General Discussion
    Last Post: 08-10-2004, 12:40 PM
  2. Which Amp(s)?
    By TimberJon in forum Amplifiers
    Last Post: 07-08-2004, 10:08 AM
  3. Replies: 3
    Last Post: 04-14-2004, 11:42 PM
  4. hooking up 2 amps
    By liqdsm in forum Amplifiers
    Last Post: 12-28-2003, 01:56 AM
  5. Questions concerning hooking up two or more amps
    By kevinsean23 in forum Amplifiers
    Last Post: 12-15-2003, 06:24 PM
