Results 1 to 5 of 5
Reload Thread: jbl bp1200.1 stable at 1 ohm?
    cmp69's Avatar
    cmp69 is offline Member
    Feb 2002
    Ma
    58
    is the jbl bp1200.1 amp really stable at 1 ohm, and it wont fry or anything?
    Mark_ab's Avatar
    Mark_ab is offline The Alpha Male
    Feb 2002
    Edmonton, Alberta
    31
    4,210
    Yes, it is stable at one ohm. Just make sure it's in an area that gets a lot of airflow, or even better, purchase a small fan to cool it. You should have no problems.
    Is this not a reasonable place to park?
    cmp69's Avatar
    Feb 2002
    Ma
    58
    re to fan
    how would i hook the fan up in the back where the amp is mounted
    imral3's Avatar
    imral3 is offline Sponge Bob Rules !!!!!
    Jan 2002
    NJ
    45
    526
    you should wire it to a dash mounted switch so you can turn it off or on but also the power lead should be switched by the ignition so it turns off with the car. i recommend not wiring inline with the amps power supply as this may introduce noise to the amp.
    good luck and good listening!
    L8r
    Wonderbread's Avatar
    Wonderbread is offline Against Avatar Theft
    Feb 2002
    Vancouver BC
    28
    5,152
    all great ideas, the JBL WILL uinfact run 1 ohm stable, might get warm as everyone is saying...
    wire up a fan.....
    keep it in a nice open area, not hidden behind anything....
    MSN - pnenis@hotmail.com
    Add me if you have any questions!
    Quote Originally Posted by PT Teal
    I woke up one morning and found a cop at my door telling me he found my car on fire in the middle of the desert.
    Quote Originally Posted by cleanerupper View Post
    Some people have told me that the chrome reflects sunlight, therefore the amp doesn't get as hot as others. Is this true?
