Results 1 to 9 of 9
Reload Thread: optima side post
    Vectork39's Avatar
    Vectork39 is offline Senior VIP Member
    Jul 2004
    NJ
    343
    5 Post(s)
    optima side post
    if i run out of space to put wire rings on the terminal can i use a GM side post extenderon the yellowtop, will is give the same amount of power, and can i wire an amp off the side post without a problem?
    MikeofTulsa's Avatar
    MikeofTulsa is offline The one and Only!
    Feb 2002
    Tulsa, OK
    21,235
    1 Post(s)
    308 Post(s)
    Re: optima side post
    shouldnt have any problems.....
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    that's what i'm going to do when i upgrade my battery ground, just run it to the GM side posts.
    works fine, very convienent. Those dual post batteries give you a lot of flexibility that way.
    Vectork39's Avatar
    Jul 2004
    NJ
    343
    5 Post(s)
    ok cuz i'll be running 3 amps, two with 1/o gauge wiring, and 1 with 4g wiring, and i might not have enough space on the top
    JimJ's Avatar
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    why not just run a huge single wire and branch it off with distro blocks? Less overall wire to run, could be cheaper...
    Vectork39's Avatar
    Jul 2004
    NJ
    343
    5 Post(s)
    thats what i was also thinking....
    JimJ's Avatar
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    out of curiousity, what are you going to be running that takes that much current?
    Vectork39's Avatar
    Jul 2004
    NJ
    343
    5 Post(s)
    two hifonics 1500's and a hifonics zx6400
  9. #9
    JimJ's Avatar
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    you don't really need that much cable, then...I'd say one run of 2awg for the 1500's, and another 4awg for the ZX6400.
  1. Post A Picture Of Your Subs
    By iLL-Faded in forum Subwoofers
    Last Post: 02-21-2009, 02:18 PM
  2. does anyone have pix of the se and *** side by side?
    By caraudionoob in forum Subwoofers
    Last Post: 08-13-2004, 09:52 AM
  3. optima yellow top
    By TwistedVisions in forum General Discussion
    Last Post: 06-06-2004, 06:44 PM
  4. Alpine 9811 - need info on back side set up
    By Cressida in forum General Discussion
    Last Post: 12-16-2003, 09:31 PM
