Results 1 to 7 of 7
Reload Thread: Help with wiring JBL BP1200.1
    Budnik's Avatar
    Budnik is offline Member
    Dec 2001
    Sullivan, Illinois
    109
    well, i just got my amp and i'm waiting on the subs. I am going to use it to power 2 dual voice coil subs. for those of you who don't know, this is a one channel amp but it has 2 sets of rca inputs. a front left and right, and a rear left and right. i am wanting to wire the subs in parrallel and bring them to a 2 ohm load. how will i do this? My head unit is panasonic CQ-DFX701U, it has sub wooferouts (1 pair), preout rear, preout front, AUX input, and a cd changer input. those are all in rca form. It has regular wires for the components.
    thanks,
    matt
    imral3's Avatar
    imral3 is offline Sponge Bob Rules !!!!!
    Jan 2002
    NJ
    50
    526
    first thing... how many ohms is each voice coil? that will determine how they will be wired to the amp. and can they handle 600w rms each?
    good luck and good listening!
    L8r
    Budnik's Avatar
    Dec 2001
    Sullivan, Illinois
    109
    the subs have dual 4 ohm voice coils and handle 500 watts rms.
    thanks,
    matt
    imral3's Avatar
    Jan 2002
    NJ
    50
    526
    in that case... i think you would only be able to achieve either a 4 or 1 ohm load with those subs. i dont think that amp can handle a 1 ohm load so you would have to wire it at 4ohms which would put out 600w total or 300w RMS to each sub. to achieve a 2 ohm load you would need either two 8ohm DVC subs or two 4ohm SVC subs.
    L8r
    dr. no's Avatar
    dr. no is offline Senior VIP Member
    Mar 2002
    Highlands
    253
    All you have to do is get 2 Y adaptors for your rca's from your sub output on your headunit so that you all rca inputs on the amp conected. Then just wire your subs in parallel, the 1200.1 is stable at 1 ohm no problem, says so right in the manual. enjoy
    Budnik's Avatar
    Dec 2001
    Sullivan, Illinois
    109
    dr. no, so i will need to have wires coming from both "speaker outputs"? if so, can you make a diagram of how to wire them in parallel for me?
    thanks,
    matt
    imral3's Avatar
    Jan 2002
    NJ
    50
    526
    for a wiring diagram click on the link below my name and look at page 6
    L8r
