Results 1 to 10 of 10
Reload Thread: Need some help connecting my 15 in licker L7
    gonzalez3063's Avatar
    gonzalez3063 is offline Just Wanna Bump
    Jul 2004
    Los Angeles Cali
    I have a 99 chevy tahoe and purchased two 15 in kicker L7 I have two alpine mrv 1507 v12 amps that i want to hook up(one sub per amp) what would be the best connection for these subs with these amps? I really want my truck to bump i made a custom box about 3 cubic ft ,also i have a alpine in dash cva 1006 thanks in advance all help will be appreciated
    bigpeen's Avatar
    bigpeen is offline Member
    Jul 2004
    Kansas City, Omaha, Ames (Iowa State)
    78
    Re: Need some help connecting my 15 in licker L7
    When you say what is the best connection...what are you referring to? Power and ground or hooking up the subs and amps into ohm loads?
    01 Chrysler Sebring
    2 Kicker DX 700S
    2 12in Kicker L7 Solos
    Alpine CVA 1004
    Alpine 6 Disc MP3 changer
    Clarion VCZ628 In-Car 6 Disc DVD Changer
    4 Pioneer 6990R 6X9 5-Ways
    X-Box
    3 more monitors coming soon...
    "Four 15's didn't see no wires...then I heard BOOOM from the amplifiers"
    Hmmmmm...sounded good in the song...but makes no **** sense in reality. Just a thought.
    bigpeen's Avatar
    Jul 2004
    78
    oops my bad... I had to re-read your post. (I didn't get too much sleep last night obviously).
    I hope you have dual 2 ohm voice coil subs.
    You should wire your subs into a 4 ohm load and bridge to your amp and THEN get out some lip gloss and kiss your neighbor's a$$e$ because you are gonna be causing ruckus from the looks of things.
    If you have dual 4 ohm subs you wont get near the sound I think someone with two 15in L&s is looking for. That is BOOOOOOM BOOOOOOOOM right? OR is it BOOOOOOOOOOOOOOOOOOOOOOOOOOOM BOOOOOOOOOOOOOOOOOOM?
    Before you take my word for it...let some other folks chime in...I am still tired and might have said something off...i'm not too familiar with those amps.
    01 Chrysler Sebring
    2 Kicker DX 700S
    Alpine CVA 1004
    X-Box
    Jul 2004
    Los Angeles Cali
    yes i have the dual 2 ohn voie coil the new design not the old one S15L7
    by 4 ohm load you mean parallel wiring then bridging into the amp or series wiring then bridging into the amp???? thanks for response just trying to bump
    99 tahoe
    on 22's
    alpine 6 disc changer
    Kenwood eq
    alpine v12 mrv 307 amp for mids
    4 5'in infinity kappa for mids
    2 ampine mrv1507 for lows
    2 15'in kicker S15L7's( when i hook the up)
    p2
    farenheit 34 in dash dvd mp3 player
    tv tuner
    and finally but not lease six 7'in monitors all around
    bigpeen's Avatar
    Jul 2004
    78
    From what I picked up on that amp..it puts out about 900 watts RMS at 4 ohms.
    You want to wire your subs in SERIES. Doing that will make the sub a 4 ohm load. You can go here to see how its done if you don't know... http://kicker.com/images/manuals/04S...r%20Manual.pdf
    So do that to both subs and bridge them on both amps and you will give those L7s the juice they need for you to go "BUMP" in the night. :thumbsupw
    I looked at your sig and thats a lot of monitors...I just want my 4 and I will be set.
    Once it is all hooked up play Bachbusters Digitally Remastered...Symphony never sounded so **** loud and deep.
    01 Chrysler Sebring
    2 Kicker DX 700S
    Alpine CVA 1004
    X-Box
    Jul 2004
    Los Angeles Cali
    thanks big will try later after i come home from work ill let u know how it worked out
    99 tahoe
    on 22's
    Kenwood eq
    p2
    tv tuner
    saywhat?'s Avatar
    saywhat? is offline satx120, jealous?
    Apr 2004
    H'Burg Mississippi!
    30
    11,175
    okay, your amps are mono blocks correct? if so, hit up the wiring section and click the wiring diagrams sticky. check for the DVC 2 ohm single sub to one ohm diagram. it tells more than we can explain hence the infamous sayin "a picture is worth a thousand words" if they are 2 channel amps.......dunno.
    bigpeen's Avatar
    Jul 2004
    78
    good idea SAYWHAT? I just thought about that after lunch.
    Well gonzalez...try either one of our ideas and let us know what happens.
    If we hear of an earthquake in LA today YOU are the one to blame.
    Cheers!
    01 Chrysler Sebring
    2 Kicker DX 700S
    Alpine CVA 1004
    X-Box
  9. #9
    saywhat?'s Avatar
    Apr 2004
    H'Burg Mississippi!
    30
    11,175
    if they are two channel amps u may be able to run one channel to each coil, giving a rated power at 2 ohms (stereo) to each coil.
  10. #10
    Jul 2004
    Los Angeles Cali
    Im in testing proces right know and just for the heck of it i hooked one up (in series mode) to one amp to see how they sound(just purchased them saturday havent had a chance to hear them) and damm just one hears clear as hell I can just imagine with two thanks guys for all ur advice but i have one more question im running one rca cable (L & R) from my EQ how should i split it. ( for each amp) Should i buy a simple Y-spliter and split the rca cable that way or my amp has an rca L&R out should i hook the other amp that way thanks
    99 tahoe
    on 22's
    Kenwood eq
    p2
    tv tuner
  1. Connecting portable mp3 player to car system
    By achuvikov in forum General Discussion
    Last Post: 07-11-2004, 04:21 AM
  2. connecting 4 channel amp to one subwoofer(DVC)!!
    By BASS OUTLAW in forum Wiring, Electrical and Installation Help
    Last Post: 06-20-2004, 10:35 PM
  3. connecting wire to speakers
    By Casserole in forum Wiring, Electrical and Installation Help
    Last Post: 03-20-2004, 12:06 PM
  4. help needed connecting 2 amps....
    By craigc38 in forum Wiring, Electrical and Installation Help
    Last Post: 12-02-2003, 02:57 PM
  5. connecting amp at home
    By jonboy385 in forum Amplifiers
    Last Post: 11-18-2003, 12:45 AM
