+ Reply to Thread
Page 7 of 7 FirstFirst 1 2 3 4 5 6 7
Results 91 to 103 of 103
Reload Thread: Will a High Output Alternator Fry my car's Electrical System?
  1. #91
    orphe's Avatar
    orphe is offline CarAudio.com Elite
    Feb 2005
    Houston
    1,016
    54 Post(s)
    Re: Will a High Output Alternator Fry my car's Electrical System?
    Quote Originally Posted by Brazito View Post
    I'm more confused as to what to do now than I was previously.
    Too many saying "do this", others saying "don't do that or this will happen".
    Makes me want to go back to stock and **** it all.
    Are there any experts? And not self proclaimed experts. I need my truck running not melting.
    I’ve pretty much read this entire thread and was in the same boat as you. I’m NOT an expert by any means but I did install my HOA and its been going strong for about 2 months so far. Just install and do the big 3 and you WILL be ok
  2. Likes eraceyfase liked this post
  3. #92
    Jd377's Avatar
    Jd377 is offline Member
    Apr 2011
    Kansas City, MO
    40
    This is very helpful to people new to HO alts! Wish I had found this sorta thing back when I was buying one for my car.
  4. #93
    eraceyfase's Avatar
    eraceyfase is offline Junior Member
    Mar 2012
    Lebanon, MO
    1 Post(s)
    i like to think of it like this. lets say you have a 10 amp breaker for your 110 volt tv and a 30 amp breaker with heavier wire for your 110 volt air conditioner with heavier wire. one day tou plug the tv into the a/c plugin. did it fry because of the higher capacity, no you actually put less strain on the system. i know this is alt current but it puts it into laymans terms. if anything a HO alternator is safer as long as you do it right... with more output your amp will put out less distortion making it easier for your subs. also there will be less voltage fluctuation in the rest of the car, making it easier on things like your ignition coils or ecu.
  5. #94
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Quote Originally Posted by eraceyfase View Post
    Just because an amp is recieving more current doesn't mean it will put out less distortion. Also, why would the TV fry?
  6. #95
    eraceyfase's Avatar
    Mar 2012
    Lebanon, MO
    1 Post(s)
    i said the tv wouldnt fry. read it again... and ok if the amp wasnt recieving enough current in the first place it would put out less distortion than it did before with the proper current. mybad. also when im wiring something i like to make sure i have way more power available than i actually need that way if i change it up i dont have to put in heavier equipment to back it up. thats a pain in the ***.
  7. #96
    Bomber Z's Avatar
    Bomber Z is offline Senior VIP Member
    Oct 2012
    Davie, Florida
    206
    22
    63 Post(s)
    I'm running a H/O alt with the big 3 wire also 3 Kinectic batteries, and running a 4g. wire to each batt from alt.Plus a cap on each amp. Things have been running cool and smooth. If you take short cuts you will end up with problems.
  8. #97
    LosIsATool's Avatar
    LosIsATool is offline CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,852
    109 Post(s)
    7615 Post(s)
    Quote Originally Posted by Bomber Z View Post
    Get rid of the caps and it will run better.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  9. #98
    Bomber Z's Avatar
    Oct 2012
    Davie, Florida
    206
    22
    63 Post(s)
    How will it run better w/o the caps??? It hold the voltage is more consistent with the caps. That why they are in place. This system has been under construction for 3 years. Testing which amps, speakers, caps batteries work best. With all the testing I've done. So for this has been the most consistant the voltage has been. So You have me confused why you would suggest removing the caps. ???
  10. #99
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,958
    15
    36 Post(s)
    4045 Post(s)
    Here's a little test for you to do to see how much power your capacitor provides. See how long JUST THE CAPACITOR will power your amp. Play music, disconnect at the battery and let us know how long the "reserve" in your capacitor lasts.
  11. #100
    Bomber Z's Avatar
    Oct 2012
    Davie, Florida
    206
    22
    63 Post(s)
    Caps dont provide power, just reinforce it. I would never try that you will end up burning something up.
  12. #101
    Aug 2012
    Iowa
    39
    12 Post(s)
    Sexiest plumber iv ever seen!
    Quote Originally Posted by tRiGgEr View Post
    Not true.
  13. #102
    psych0ticnemes1's Avatar
    psych0ticnemes1 is offline Psych0tic Customs
    Apr 2005
    Behind You
    5,842
    175 Post(s)
    Does anyone know how to determine if the regulator is built into the alternator or the computer?
    References:
    Ali1, michaellane, cadillac114, chasinSKURT, DaRevrin, rhuff80, sam yung, The215, tukn18s, Xenophontos,nuboot,jfitz97,LuckyDerDer 2x
  14. #103
    blowthemup's Avatar
    blowthemup is offline CarAudio.com Elite
    Dec 2006
    North Carolina
    556
    93 Post(s)
    Quote Originally Posted by psych0ticnemes1 View Post
    Other than your positive charge line for your alternator how many wires does it have?
+ Reply to Thread
  1. electrical system question
    By rick22 in forum Wiring, Electrical and Installation Help
    Last Post: 05-31-2004, 12:36 AM
  2. System for Cloud Cars 95-'00 (cirrus, stratus, breeze)
    By tobz in forum General Discussion
    Last Post: 05-21-2004, 02:17 PM
  3. my car's idling LOW!... could it be my system?
    By allyourblood in forum General Discussion
    Last Post: 03-04-2004, 07:51 AM
  4. what kind of cars does everyone have their system in?
    By jtomsic in forum General Discussion
    Last Post: 03-02-2004, 05:16 PM
