+ Reply to Thread
Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 61 to 75 of 101
Reload Thread: Will a High Output Alternator Fry my car's Electrical System?
  1. #61
    taysextreme's Avatar
    taysextreme is offline Want some Come get some
    Dec 2007
    jersey
    324
    Re: Will a High Output Alternator Fry my car's Electrical System?
    bigbang is right, but the power is pulled in the direction it is needed so there is no need to worry about it traveling through elsewhere
  2. #62
    Feb 2008
    Sarasota, FL
    133
    Mine is being installed in the morning. I bought a 180a from Ohio General and they told me more than once, upgrade to the largest size of cable that you can for everything more or less EXCEPT the Alt to Batt Pos. They told me, which I confirmed multiple times, on a short run, 4awg (at least for upwards of 200a) is plenty and ideal; they don't recommend larger than that in that location because the size of the post on the alternator is too small to bind to the larger wire; ergo because of the size difference, the post on the alt heats up too much and can overheat it. That was their recommendation and I'm going to have the shop that is doing it for me talk to them and confirm with a detailed description of my specific engine.
    The other interesting thing they said was do NOT fuse that wire. I confirmed this as well, DO NOT fuse this wire because if for some reason it does indeed blow, the alternator will no longer see the battery and think that it's dead, so it will kick into high gear and stay that way until it burns up because it will never see that battery again until you've changed that fuse, thus leaving you with a dead battery and a burnt out alternator.
    Discuss.
  3. #63
    ffkk's Avatar
    ffkk is offline Member
    Nov 2006
    PTA, RSA
    105
    BMW e46 328i
    Alpine CDA-9833R, Focal Polyglass Splits, 12" Kicker CVR, JBL GT75.4, Calibra DIGI 1250 Monoblock, DELTEC Battery
  4. #64
    Papaloads's Avatar
    Papaloads is offline Junior Member
    Feb 2008
    LA, CA
    19
    Quote Originally Posted by InfinitePeace View Post
    Discuss.
    I am no expert at all but from what i gathered on this thread it appears that putting a fuse on the wire from the battery's positive terminal to the Alternator WILL NOT affect anything ASSUMING you leave your ORIGINAL factory installed wire from the battery to the alternator.
    If you do not remove that original wire then there shouldn't be any concerns about the "alternator no longer seeing the battery and thinking it's dead"
    Experts please confirm or correct my above statements!
  5. #65
    missinglink's Avatar
    missinglink is offline Member
    May 2008
    Las Vegas , NV
    55
    I have 2 Ohio alts. I will agree NEVER put a fuse between the alts and battery. Your alternator needs to read a draw if the fuse goes your alternator will compensate. I have 2 1/0 gauge from one and a single off the other. 1/0 wont heat up as much as the 4gauge if your having alot of draw. Much over 1,000 watts I would go with the 1/0. Granted your alt will only put out so much power. (this is why 4 gauge is enough) If you are running 1/0 to your amps its wise to run 1/0 from the source.
    MLA
  6. #66
    lostforawhile's Avatar
    lostforawhile is offline Junior Member
    May 2008
    georgia
    28
    ok another one, tell this to the people who tell you this crap, the alternator and the battery are connected together on the same circuit, the battery can produce way more current then any high output alternator ever can, so why aren't the electronics fried? all regular alternators for automotive use produce the same voltage,or close to it. they can just produce more current on demand. with a HO one. one thing to look for is where your alternator is connected to the charging system. if it has a fusible link at the fuse box, you need a better connection point for a HO one, good place is run a 1/0 or 2/0 wire from your battery to your starter,then connect the alternator lead wire to the starter terminal also. this is good for your starter also,as this is a lower resistance path from the battery. thats means more current at the starter if it needs it.
  7. #67
    May 2008
    georgia
    28
    Quote Originally Posted by ReDemoN View Post
    Here is my ? about the wire that runs from the batt to the alt?
    This is on a 94 civic
    Do I take away the factory wire that runs from the fusebox to the alt?
    I'm gonna use 1/0 gauge wire from the batt to the alt.
    I just run the wire directly to the alt from the batt terminal?
    See the civic has a little wire that runs from the fuse box to the alt, there is a wire that runs from the batt to the fuse box so i'm just trying to figure out what the deal is.
    Any help would be nice if you need a picture of what I'm talking about let me know.
    get rid of the stock wire from the alternator to the fuse box if you are going high output. run a 1/0 or 2/0 battery wire to the starter motor,then use the starter lug to attach your heavy wire from the alternator. good connection point.
  8. #68
    May 2008
    Las Vegas , NV
    55
    I have never changed my starter wire size and I run 13batteries & 20,000 watts. Why is the starter a better point? Why is from the alt to the starter to the battery better then straight from the alternator to the battery? You have me confused please explain more.
    Sorry I'm not sure about the starter re-route. Why wouldn't he just upgrade his alt to batt wire. All other wires will see the same thing regardless where its routed if his fuse box is from the battery or the alternator it will read the same. It might be safer from the battery though. Bail the line from fuse box if something don't work you might route it to the battery.
    As it may have a separate purpose.
    MLA
  9. #69
    May 2008
    Las Vegas , NV
    55
    We looked into this little wiring question. Its a 80amp fused and a load sencing wire, keep that wire and add a 1/0 from the alt to the battery. I know why he was saying to the starter its closer may save some wire.(sorry I see why) It will have the same effect either way...
  10. #70
    May 2008
    georgia
    28
    Quote Originally Posted by missinglink View Post
    MLA
    well i was saying to run it to the starter because it's easy to add the wire to the starter lug, then it will connect right to your battery through the terminal. this way if you have to add an extra wire it's eaisier then trying to add it to the battery terminal. it also looks a lot cleaner.
  11. #71
    May 2008
    Las Vegas , NV
    55
    Yea we saw why you said it. You made a good point sorry mane. We see how you have to route it and it would work either way. I was just confused till we looked up the engine diagram. Than for the answer and not for the chewing LOL. Thanks for the point If I do a similar car I will keep it in mind.
    MLA
  12. #72
    persian_gulf's Avatar
    persian_gulf is offline Junior Member
    Mar 2008
    iran
    i have nissan maxima 2000
    engine:VQ30DE
    i need ~400 amp alternator for my car
    what do you recommend me??
    plz help me!
  13. #73
    shizzzon's Avatar
    shizzzon is offline Supporting Vendor SPL-Lab
    Apr 2008
    KY
    555
    I've been told that if you have a HO alt installed and if your starting batt dies and ever got a jump, you must be extremely careful for the next several minutes.
    If the engine rises above idle rpm, the alt will start to send gigantic amounts of current to your almost dead battery. If you have a 300A alt for instance, it will try to send all of it's power to your battery which will end up killing it because that is too much current to charge a batt.
    The best thing to do is keep the rpm as low as possible and that way is to just keep idle for a while. IF you get no output at idle, barely rev it up and keep it there. Alts max out at 2k rpm engine rpm so it doesnt take much to be at risk.
  14. #74
    Jando86's Avatar
    Jando86 is offline CarAudio.com Elite
    Jan 2008
    San Diego
    665
    ekectrile.
    LOL
    HU: DEH-p960mp
    FRONTS: Diamond Audio hex 6.5
    AMPS: JBL power series amps
    REARS: JBL 2Ω 8 inch 3 ways
    MOOFERS: 2 12'' Oz Audio Matrix Elites
    EA 200 amp HO alty
    Kicker 1/0 Hyperflex in my raccoon wounds
    bank of live gerbils for power.
    power from the gods optional.
    Refs: J3m Concepts, DJ Nitrous 427 (same), Cdieselfan, Zueslicious(x5), P.T.R., Kinville, snakeye, joe89, Mendonmafia, BLD 25, Spoonraker, R/T Pimp, foreman, Manethon, Vitveet, MrJoeyJiffy, Rc10Mike, Local Yokels, and also-my mom says I'm a nice boy.
  15. #75
    May 2008
    georgia
    28
    discuss.
    um the factory fused it for a reason, also the reason a lot of cars have fusible links,
    you may have a fried alternator but you won't have a burned car. i've worked with automotive electricity for twenty years as a serious hobby and sometimes profession,and thats the stupidest thing i've ever heard. that factory fuse or link is there to keep a dead short in the alternator from setting the battery cable to it on fire, screw the alternator,if that link or fuse goes you've got worse problems.
    what are these guys smoking? you crimp a terminal on end of the two gauge cable that fits the alternator post,the alternator isn't going to overheat because you used a larger size wire, the wire is not going to make the alternator put out more amps then it's made for, the terminal on the alternator is designed for the amps it can put out, the wire size has nothing to do with it. a larger wire has less resistence then a smaller wire,therefor it heats up less not more. these guys need to go back to school to lear basic electrical theory, everytime i hear someone tell people this BS it makes me want to start an electrical installers school or something. reminds me of the guy who said i couldn't install power door locks in my 86,because it didn't have the "computer" for them. what a load of ****.
+ Reply to Thread
  1. electrical system question
    By rick22 in forum Wiring, Electrical and Installation Help
    Last Post: 05-31-2004, 12:36 AM
  2. System for Cloud Cars 95-'00 (cirrus, stratus, breeze)
    By tobz in forum General Discussion
    Last Post: 05-21-2004, 02:17 PM
  3. my car's idling LOW!... could it be my system?
    By allyourblood in forum General Discussion
    Last Post: 03-04-2004, 07:51 AM
  4. what kind of cars does everyone have their system in?
    By jtomsic in forum General Discussion
    Last Post: 03-02-2004, 05:16 PM
