+ Reply to Thread
Results 1 to 1 of 1
Reload Thread: Adding a subwwoofer
    1976kjell's Avatar
    1976kjell is offline Junior Member
    Jul 2018
    Harstad, Norway
    Icon32 Adding a subwoofer
    Hi and thanks for the membership
    The current setup in my 63 Ford Galaxie:
    Only the rear RCA wiring is connecting the headunit and the Blaupunkt 4100 GTA amplifier in the trunk
    And only the rear speaker connectors on the GTA 4100 are used for my Blaupunkt XL 200 speakers
    A pioneer ts-w3003d4 https://www.pioneerelectronics.com/P...PRO/TS-W3003D4
    is in my garage and a 53-litre slot vented subwoofer box is ordered, so its soon time to use this stuff
    My plan is to use two Y-connectors to connect the two rear rca cables that go to the amplifier so the complete amlifier will act as rear speakers when fading
    Will this work with this wiring:Adding a subwwoofer-4100_1.jpg
    The way this is done is that the subwoofer which have 4 rca connectors (2/8 ohm) uses the 4 front rca connectors on the amplifier. My knowledge about those ohm relations isnt strong, so i wondered if that setup will work?
    Or will it only works with this wiring: Adding a subwwoofer-4100.jpg
    The last alternative will make it necessary to buy a 2-channel amplifier for the new subwoofer because the subwoofer isnt included in that setup
+ Reply to Thread
  1. adding another amp
    By pbnj22 in forum Wiring, Electrical and Installation Help
    Last Post: 05-05-2012, 02:53 AM
  2. Adding a fan to my amp.
    By digitalrainman in forum Wiring, Electrical and Installation Help
    Last Post: 06-05-2008, 11:30 PM
  3. adding a sub
    By orioles26 in forum Subwoofers
    Last Post: 05-08-2006, 03:07 AM
  4. adding another XXX?
    By mmmwings in forum Subwoofers
    Last Post: 02-16-2005, 05:45 PM
  5. Need help adding a sub
    By Deamonicus3 in forum Subwoofers
    Last Post: 10-13-2004, 11:50 AM
Tags for this Thread
