+ Reply to Thread
Results 1 to 3 of 3
Reload Thread: Amp level setting
    mirrortints's Avatar
    mirrortints is offline Junior Member
    Jun 2012
    Beltsville, MD
    Amp level setting
    Ok, first time using a mb quart amp. Does the Level look normal? Never seen it go from high voltage to low voltage.
    Sent from my SM-G955U using Tapatalk
    1jjspence's Avatar
    1jjspence is offline Junior Member
    Jul 2018
    Rogers, AR
    37
    Re: Amp level setting
    I'm new on the forum but I can jump in on this. Some amps label the gain this way, it's referring to the expected preamp voltage. If RCA voltage is 5V, you'll obviously need less gain than a 2V signal. It's probably a better way to label the gain, in my opinion, because it more accurately describes what it's actual purpose is.
    Sent from my SAMSUNG-SM-G930AZ using Tapatalk
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is online now CHEAP A/F
    Jan 2017
    NC
    6,766
    17
    30 Post(s)
    2705 Post(s)
    yeah it's fine just set like normal, use 50hz tone with meter set volts to watts u want (make sure amp does watts u set it for fyi mb quart does not even come close to doing ratings., look at the crunch 1500.1 that tested 323rms 2 days ago.. made by same company)
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, 2.1cfad ported, soundqubed 6.5" coax/doors, hp & lp xover on hu, AGM starting batt...
    2 ohms rule
+ Reply to Thread
  1. Replies: 8
    Last Post: 11-20-2010, 11:57 PM
  2. Setting Bass EQ and Level
    By drifterman33 in forum Amplifiers
    Last Post: 03-13-2007, 01:06 PM
  3. setting the low pass and level
    By orphe in forum Amplifiers
    Last Post: 12-31-2006, 12:12 PM
  4. Level Setting? Not Gains?
    By Doitle in forum General Discussion
    Last Post: 11-23-2005, 12:08 PM
  5. measuring gain level setting
    By imral3 in forum Wiring, Electrical and Installation Help
    Last Post: 04-26-2002, 01:02 AM
