+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Reload Thread: New Alt, Low Voltage issues
    CplCuddles's Avatar
    CplCuddles is online now Certified Meme Warrior
    Nov 2014
    Topeka, KS
    412
    2 Post(s)
    146 Post(s)
    Icon9 New Alt, Low Voltage issues
    Hey guys I'm back again with another issue,
    I recently bought a 320 Amp Elite Series Alternator for GM Truck. I was having dropping voltages into the 10s when I decided to buy a HO alt. I replaced my 130amp stock alt with the Mechman and left on my default belt to start. I then started having low voltage at idle issues.
    My Tahoe idles at 500rpm, I'm told this is low, but it has done it since the day I bought it, no issues until now. My initial problem was that when idling (500rpm) I would drop into the high 10s when playing music. I tried to put on a smaller belt as I have seen that is recommended for the smaller pulley, I could not get a smaller belt to fit (even tried 1/2 inch shorter belt, it would barely not fit), So I have the original serpentine belt still on, it seems to be plenty tight. Figuring it was my batterys charge that was the issue, I bought a 750Mah trickle charger and left it on the battery overnight.
    This solved the low voltage at idle issue, initially. A few days later on the 4th of July I had the key on and the stereo on low and my voltages were saying 10V dropping into 9.5V, somehow I turned on my Tahoe and it jumped back up to 14.7V. The next day I couldn't start my Tahoe and had to get it jumped, same voltage issue as the day before. I took my Redtop to O'Reilly to get it load tested, and it came out fine according to them.
    Then yesterday a new problem emerged, while driving I noticed my rpms dropping below 500rpm. I let off the gas and let it drop to see how low it would go and it dropped to about 200rpm and all my lights dimmed out almost completely. I parked and revved for a minute and then turned it off (I was going inside) and it rested at 10.2V immediately after turning my Tahoe off. The low voltage issue seems to be somewhat intermittent was this point. My father who is a mechanic is adamant that it MUST be the alternator. Does this sound like something may be defective with the alternator I received or what else may be causing this? Thanks!
    02 Chevy Tahoe
    Optima Redtop up front
    Big 3
    Mechman Elite 320 amp Alt
    Kenwood X599
    Crescendo Audio Symphony Coax's
    Sundown Audio SAX 100.4 & SAZ 1500d
    Sundown Audio X 12v2 @ 29Hz
    Chris McNeeley's Avatar
    Chris McNeeley is online now Red Light Ear Rapist
    Jul 2016
    Toledo, ohio
    30
    313
    205 Post(s)
    Re: New Alt, Low Voltage issues
    Just stop and burn it down. A v8 that idles 500? Do understand that pulley rotation speed directly effects amperage output. Serious, just stop.
    Team Bang Hard Ohio Chapter
    2013 Subaru Legacy B-Pillar
    4 Crossfire v4 18s
    4 Crossfire 4k's
    2 Crossfire 2000.4s with Ampere JM1 Dsp
    3 SINGER 270's + MI Solar 115ah 18v + 16.5ah 12v x2
    The Camry's Avatar
    The Camry is offline Hey, I Try.
    Sep 2013
    Western Oregon
    2,971
    14 Post(s)
    1344 Post(s)
    Turn down your gains and go get your engine checked. You're having serious issues.
    CplCuddles's Avatar
    Nov 2014
    Topeka, KS
    412
    2 Post(s)
    146 Post(s)
    Quote Originally Posted by Chris McNeeley View Post
    Gotta push through my dude. I do understand that pulley rotation directly affects amp output. I figure since the engine is having low rpm issues, that would be causing my voltages issues. People around me keep disagreeing and saying its prob my alt. I'm not a mechanic... at all.
    Quote Originally Posted by The Camry View Post
    This is happening even without music, this all started after putting in my new Alt. Gonna get my codes checked tomorrow and see what comes up.
    02 Chevy Tahoe
    Big 3
    Kenwood X599
    Jul 2016
    Toledo, ohio
    30
    313
    205 Post(s)
    Gotta push through? I just hope your dumb*ss doesn't cause an accident when your sh*t breaks down.
    4 Crossfire v4 18s
    4 Crossfire 4k's
    mikedeezxxx's Avatar
    mikedeezxxx is offline Member
    Apr 2018
    Santa Clarita, CA
    59
    1 Post(s)
    23 Post(s)
    Just put your old alternator back on and see if the problem goes away.
    CplCuddles's Avatar
    Nov 2014
    Topeka, KS
    412
    2 Post(s)
    146 Post(s)
    I don't understand what you're so perturbed about. That it idles at 500rpm? as I said it has always done that. That actually seems to be normal with my vehicle as well as vehicles of the similar type.
    Quote Originally Posted by mikedeezxxx View Post
    I'll probably try this, just a pita.
    02 Chevy Tahoe
    Big 3
    Kenwood X599
    BassDrop's Avatar
    BassDrop is offline Senior VIP Member
    Nov 2015
    SALINAS CA
    221
    100 Post(s)
    Quote Originally Posted by CplCuddles View Post
    I have a 14 sierra and it idles at 500 rpms. In thinking of getting a new alt built but **** seeing **** like this makes me not want to. $400 down the drain.
  9. #9
    CplCuddles's Avatar
    Nov 2014
    Topeka, KS
    412
    2 Post(s)
    146 Post(s)
    Quote Originally Posted by BassDrop View Post
    The way I think about it is that its only a problem if I'm idle for long periods of time and pulling more than I am producing. On average I'm not full volume bassing every time I drive, so I'm really only pulling from reserve during downtime like stoplights. Which I figure if I get a nice reserve bank that won't be a problem at all, because the alt recharges the reserve while I'm not consuming more than produced. I'm not sure that it is the alt that is the actual issue here. Hence why I'm here
    02 Chevy Tahoe
    Big 3
    Kenwood X599
  10. #10
    Boominburban's Avatar
    Boominburban is offline CarAudio.com Elite
    Jan 2015
    Athens, TN
    51
    1,313
    14 Post(s)
    463 Post(s)
    " somehow I turned on my Tahoe and it jumped back up to 14.7V"
    So, when its running above idle, it reads 14.7v ?? (14.4 to 14.8v is pretty std charging voltage for that series alt. on a GM.) If so, it's probably not a defective alternator. 500rpm is low. 700-900 is std idle speed for that vehicle. Id look into that.
    Refs;Bought from: Boomsday, special_k_1999, BAD_MAYEM, C1500Martin, roko, Michaellane
    Sold to: sam_b03, Nate121, Smaxor5, Boomsday, unrealii, paulluap,technobass,gmc123
    TN State Champion MECA MOD 4 - 2017, 2nd place World Finals - 2017
    #Boominburban - Team OSC - Team FU Audio
    Two JS Ult 300 amp alts - Battery delete under hood - 167ah of LTO Lithiums - 8 runs of 2/0 royal excelene
    80 prs HU - PPI DSP -88R DSP - PPI E.7 EQ for fine tuning
    Four PPI p600.2 on front stage - 4 CDT HD-M6's / 2 DS18 6.5 neopros / 2 DS18 tw210 tweeters
    Three Taramps 15k's on 6 FU Audio Team 15's
  11. Thanks Chris McNeeley thanked for this post
  12. #11
    CplCuddles's Avatar
    Nov 2014
    Topeka, KS
    412
    2 Post(s)
    146 Post(s)
    Quote Originally Posted by Boominburban View Post
    Correct, If it above about 600rpm it shows perfect voltages. From what I've seen online 500-750rpm seems to be normal. I mean if it truly isn't normal will get it looked into, because it's kind of a pain to have this HO alt and I have idle issues.. lame.
    02 Chevy Tahoe
    Big 3
    Kenwood X599
  13. #12
    Buck's Avatar
    Buck is offline designing boxes Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,850
    38 Post(s)
    1202 Post(s)
    Get a smaller pulley. The alt sounds like it's turning so slowly that it's not making any power. You can also adjust your engine idle speed maybe
    does your vehicle have a throttle body with a cable from the pedal?
    ---------- Post added at 11:11 AM ---------- Previous post was at 11:10 AM ----------
    What year vehicle?
    [email protected]
    I help with full system support, if you need advice
    I just like making people happy
  14. #13
    CplCuddles's Avatar
    Nov 2014
    Topeka, KS
    412
    2 Post(s)
    146 Post(s)
    Quote Originally Posted by Buck View Post
    What year vehicle?
    It does make plenty of power at 600+rpm, it's seems that it's the low idle that is the issue. I honestly don't know about the throttle body, 2002 is the year.
    02 Chevy Tahoe
    Big 3
    Kenwood X599
  15. #14
    Buck's Avatar
    May 2008
    Nashville
    18,850
    38 Post(s)
    1202 Post(s)
    Idk if you'd want to do this, you probably either need to raise your engine idle or get a slightly smaller pulley. I would contact the alt manufacturer and see what they recommend.
    ---------- Post added at 11:29 AM ---------- Previous post was at 11:29 AM ----------
    You don't want to overspin your alt at higher rpms
    [email protected]
  16. #15
    THATpurpleKUSH's Avatar
    THATpurpleKUSH is online now Smoke weed everyday
    Sep 2009
    Banging gears and passing queeers
    5,768
    16 Post(s)
    2321 Post(s)
    Red tops are starting only batteries and aren't designed for sustained current draw. Sounds like the alt is defective tho.
+ Reply to Thread
  1. Voltage Issues! Please help
    By Ace87 in forum Wiring, Electrical and Installation Help
    Last Post: 04-12-2016, 04:55 PM
  2. Voltage issues
    By shammyhavik in forum Wiring, Electrical and Installation Help
    Last Post: 01-03-2015, 04:12 PM
  3. Voltage Issues, Bad Alt?
    By timma100 in forum Wiring, Electrical and Installation Help
    Last Post: 03-23-2012, 10:18 PM
  4. voltage issues
    By CAT MAN in forum Wiring, Electrical and Installation Help
    Last Post: 12-28-2011, 01:41 PM
  5. Voltage Issues
    By rival904 in forum Wiring, Electrical and Installation Help
    Last Post: 05-08-2009, 09:06 AM
