+ Reply to Thread
Results 1 to 2 of 2
Reload Thread: Humming/Buzzing Noise
    kwatson30's Avatar
    kwatson30 is offline Junior Member
    May 2018
    Illinois
    I have a JL 500/1 amp w/ 15" Eclipse sub. Everything was working fine when I went into a store. When I returned and turned my car on, I immediately heard a loud Humming/buzzing noise coming from my back left speaker and sub. I immediately turned off the radio, but it didn't stop the noise.
    I then unhooked the back left speaker to stop the noise, and had to unhook the RCAs to the amp to stop the noise from the sub. When I reconnect the speaker and RCAs, the noise starts again and no music will play out of the particular speakers, and no bass comes out of the sub. All other speakers work fine... any idea what the issue is?
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    10,106
    15
    38 Post(s)
    4140 Post(s)
    Re: Humming/Buzzing Noise
    Problem should be either your RCAs shorting out to ground or an internal fault with your head unit... replace RCAs to test. Be VERY careful, that sort of "noise" can burn up speakers fast and that is not good for your amp. I'd be testing with a speaker you don't care about and be ready to power off the amp quick if the noise persists.
+ Reply to Thread
