+ Reply to Thread
Results 1 to 15 of 15
Reload Thread: Inverter/Generator?? Will this sustain power for stereo and Rooftop A/C?
    udfxrookie's Avatar
    udfxrookie is offline Junior Member
    May 2018
    Tampa, FL
    2 Post(s)
    I have a 1998 Ford E-150 with a stock 130 Amp Alternator
    -Red Top Main Starting Battery
    -Battery isolator
    2xYellow Top Optima Batteries in parrallel
    For stereo and amps:
    from battery bank to 2 farad cap
    1 x 1000w pioneer amps
    1 x 500w pioneer amp
    Proposal for Rooftop A/C:
    from battery bank to 2000 watt inverter
    A/C Specs: 115 v, Min Circuit Ampacity: 11, Max Circuit Ampacity: 15, 60 Hertz
    Will the setup I have with the battery bank in place work?
    Will it drain the ba-jesus out of the battery bank?
    Should I put in a capacitor for the A/C (to cover surges, etc)?
    What's the difference between Power Inverter and Power Converter?
    I have a Whistler P1000AC 1000 Watt Continous/2000 Watt Peak
    I can get
    WFCO WF-9875 75 Amp Power Converter
    whats the difference and which is better?
    Boomin_tahoe's Avatar
    Boomin_tahoe is online now Hurtin' feelings errrday.
    Jul 2005
    WA
    14,265
    41 Post(s)
    6039 Post(s)
    Re: Inverter/Generator?? Will this sustain power for stereo and Rooftop A/C?
    When you say redtop/yellowtop, I'm guessing you overspent $$ for Optima. I wouldn't have chosen said batteries due to shortage of lifespan. No reason to have caps if your running 3 batteries. I'm confused on the rooftop a/c part...your car has the option of a/c on the truck? Big 3 and 2 batteries should be fine with what you have.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
    udfxrookie's Avatar
    May 2018
    Tampa, FL
    2 Post(s)
    I have the Big 3 done and when you have friends at the autopart store $80 Optima's aren't bad
    The van is something I picked up from a guy that lived in NY (I'm in FL) so there's issues with the underside.
    I ran into severe issues with the back A/C and have decided to up my mpg and use a rooftop A/C system a buddy had.
    Jul 2005
    WA
    14,265
    41 Post(s)
    6039 Post(s)
    Van...oh crap thought it was a truck my bad. FL is a def must for a/c....esp the high humidity there.
    So what's the issues with the a/c that you needed 3 batteries? Sounds like something else non car audio related.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    udfxrookie's Avatar
    May 2018
    Tampa, FL
    2 Post(s)
    No issue, just overkill prep
    It's a conversion van/work van.
    Inside I have:
    2xAlpine 6x9's
    4xKicker 5 1/2's
    2xKicker 12" Subs
    1x1000watt amp
    1x500watt amp
    Wiring:
    Big 3 with 1/0 awg
    Battery Bank ran with 1/0 awg
    Amps ran with 4 awg
    ALL speakers 8 awg
    Inverter with 4 awg
    Cap with 4 awg
    Putting in:
    Inverter
    Rooftop A/C (again for overkill on trips
    Permanent laptop (since it has it's own battery and charging system to reduce load)
    30" LCD TV
    PS3
    Eventually:
    H.O. 220 Amp Alternator
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    10,106
    15
    38 Post(s)
    4140 Post(s)
    Not sure about rooftop AC but it sounds the sort of thing that would consume a lot of energy. I'd be looking for a HO alternator right away and you'll just have to see how well your battery bank holds up if you're trying to run it while idling or with the van off. Be wary of those power inverters. I've seen plenty that claim some high wattages but those may just be surge ratings. I'd think a legit 2000W inverter would be near the size of a 2000W amp and about as expensive. Anyway, make sure you buy from a store with a good return policy to be safe there.
  7. Likes wew lad liked this post
  8. #7
    Jul 2005
    WA
    14,265
    41 Post(s)
    6039 Post(s)
    I'm confused. 1st you say your having severe issues with back a/c. Then next reply you say no issues, just upgrading everything
    I think your just bragging about running thick wiring to everything. (8 gauge to 5.25" speakers isn't necessary btw)
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  9. #8
    udfxrookie's Avatar
    May 2018
    Tampa, FL
    2 Post(s)
    No issues as in, not the topic for that =)
    (Rear A/C can be blocked and front will work fine, not the point, looking to go with the rooftop)
  10. #9
    wew lad's Avatar
    wew lad is offline wew lad inc
    Mar 2015
    Des Moines, IA
    5,308
    50 Post(s)
    2849 Post(s)
    Remove the 2 farad cap and run directly to your amps/ac the 2 farad cap won't do anything, even a 500f+ bank wont do much due to the constant draw
    is this going to be used with the van off, or on?
    ++++1 to the HO alt as being the first thing you put money into. If you can fit a GM large case, go that route.
    Would an external generator be quiet and more worthwhile for you?
    Try what you have, and if you need more you need more. without any issues stated it's hard to help you out as I'm not sure what you even need...the A/C will be the biggest draw by far. I don't expect your batteries to last longer than 1-3 hours if you're running everything
    Quote Originally Posted by JohnKuthe View Post
    I AM The Future of personal transportation, NOW!!
    Quote Originally Posted by Loudz View Post
    Pretty sure everyone on this site hates you (@JohnKuthe) more then me and that's very hard to accomplish.
  11. #10
    udfxrookie's Avatar
    May 2018
    Tampa, FL
    2 Post(s)
    I don't plan on ever running the AC with the vehicle off, honestly don't plan on ever running any if it with the van off.
  12. #11
    giltyler's Avatar
    giltyler is online now Senior VIP Member
    Jul 2013
    DFW METROPLEX
    310
    1 Post(s)
    91 Post(s)
    You should check with an RV dealer or forum where they deal with this kind of unit regularly for the best information.
    1987 THUNDER ON WHEELS NATIONAL CHAMPION 0-100 Watt class
    Avatar Tony Mannino "The Godfather" M&M Electronics with me at Finals
    Reference amedeuce papermaker shizzon
  13. Likes THATpurpleKUSH liked this post
  14. #12
    kcr357's Avatar
    kcr357 is online now Senior VIP Member
    Aug 2012
    ft laud
    302
    1 Post(s)
    116 Post(s)
    15 amps at 115v is going to be over 140 amps at 12v. Running 120v stuff off of a 12v source draws a massive amount of current. Id use a generator like mentioned above
    Sold to
    Bought from
    NinjaBass
    FasFocus00
    "If I was so worried about resistance I'd be unplugging the factory wiring harness, and checking resistance on every wire in my vehicle."
  15. #13
    kcr357's Avatar
    Aug 2012
    ft laud
    302
    1 Post(s)
    116 Post(s)
    So ues, itll drain your batteries even while running.
    Sold to
    Bought from
    NinjaBass
    FasFocus00
  16. #14
    gotgixers's Avatar
    gotgixers is offline CarAudio.com Elite
    Jan 2015
    Athens, TN
    51
    1,304
    14 Post(s)
    458 Post(s)
    you would need a 2000w continuous, 3500-4000w peak inverter, to run that A/C rooftop unit correctly. It is going to pull around 1650w+ of power every time the compressor cycles.
    Refs;Bought from: Boomsday, special_k_1999, BAD_MAYEM, C1500Martin, roko, Michaellane
    Sold to: sam_b03, Nate121, Smaxor5, Boomsday, unrealii, paulluap,technobass,gmc123
    TN State Champion MECA MOD 4 - 2017, 2nd place World Finals - 2017
    #Boominburban - Team OSC - Team FU Audio
    Two JS Ult 300 amp alts - One 75ah agm under hood - Four 126ah agm's - Three 66ah LTO Lithiums - 8 runs of 2/0 royal excelene
    80 prs HU - PPI DSP -88R DSP - PPI E.7 EQ for fine tuning
    Four PPI p600.2 on front stage - 4 CDT HD-M6's / 2 DS18 6.5 neopros / 2 DS18 tw210 tweeters
    Three Taramps 15k's on 6 FU Audio Team 15's
  17. #15
    udfxrookie's Avatar
    May 2018
    Tampa, FL
    2 Post(s)
    And then someone sent me this video:
    https://youtu.be/dmIQkOw6Tl4
    Showing an EasyStart with a 2k inverter powering a rooftop A/C
+ Reply to Thread
Tags for this Thread
