+ Reply to Thread
Results 1 to 13 of 13
Reload Thread: Subwoofer thumping
    flappijs's Avatar
    flappijs is offline Junior Member
    May 2018
    Latvia
    Subwoofer thumping
    Hello everyone.
    So , I bought audi a6 c5 avant some while ago and it had some cheap chinese headunit ,so I decided to replace it with Pioneer MVH-190UB,everything was good but then I wanted little bit more bass in the car so I bought subwoofer and installed it ,everything was fine ,there wasnt any noises when the music was playing and so on.
    Then I had to change trunk lid because it was too rusted out, but because of the subwoofer ,i wasnt able to place in it the trunk so I removed the sub, just the box ,left the + and - for the sub just in the trunk togheter with amp.Changed the trunk ,got home and hooked up the sub and it was starting to make the thump noise,hearthbeating or how you call it. So I thought I f'd something with the trunk lid wiring when placing it back togheter , somewire touching or something, so I took the plastics off and inspected the wiring and it looked good so then I unplugged all the things (number plate lights, fog lights and so on ) so then I started to think it isnt because of the trunk lid change.
    So ,I started attacking the amplifer wires. So the thing is when I turn down the gain ,it isnt making the noise, when I turn it up a little ,it starts doing it the thump again.To make sure the amp wasnt fried I hooked it up to friends car and everything was fine in his car so then I was left with RCA's , the ground wire and the source. So I changed the ground location 3 times and still was the thump so I kinda decided its not the ground, the source wire had good voltage when measuring with multimeter so not the source so ,the RCA's are left. Took them out because I thought maybe some because of other wires there are some signals ''entering'' the RCA's but still, so ,tried my friends RCA's ,still the thump. So next thing I did,was took jumper cables and connected the source and ground directly from battery to amp and it was fine ,no thumping, so to find out which wire was the ''bad'' one I tried only with the source ,but the thump was back ,tried only ground and thump went away. So now I know that there is some problem with the ground.At first I thought its the ground wire itself, but it isnt because I took the jumpercable and attached it to the ground wire place where it was and still got the thump. So know I don't know what should I do ,and why it suddenly got bad.
    Thats kinda long story and my english isnt that great so excuse me if some parts arent understandable but I hope I explained enough for you to understand whats really the problem.
    I hope someone can help me with this .
    THATpurpleKUSH's Avatar
    THATpurpleKUSH is offline Smoke weed everyday
    Sep 2009
    Banging gears and passing queeers
    5,501
    14 Post(s)
    2172 Post(s)
    Re: Subwoofer thumping
    Was the amp still turning on when you removed the sub and left the bare wires in the box?
    flappijs's Avatar
    May 2018
    Latvia
    Yes, and thats probably the reason(atleast I think so ) ,because I had to drive from home to garage and I was listening to music when driving and the amp was still completely hooked up ,just the wires from the sub were removed.
    Sep 2009
    5,501
    14 Post(s)
    2172 Post(s)
    So you completely removed the wires from the amp? Or did you just disconnect the box and remove it?
    flappijs's Avatar
    May 2018
    Latvia
    I have passive subwoofer .
    The amplifier was left in the car , but the subwoofer box was taken out. The wire from amplifier to the subwoofer (the +and -one for speaker) is the one I disconnected from the subwoofer side and left the wires in car , I dont know if they touched when driving or not.
    EDIT : Just now remebered that I didnt mention the thump goes away when I unplug the RCA's.
    350zspl's Avatar
    350zspl is offline CarAudio.com Veteran
    Mar 2008
    WPB Florida
    4,096
    3 Post(s)
    138 Post(s)
    i had seen this symptom before , it was cured when i grounded the rca on the back of the radio
    Head Unit Alpine IDA-X305S
    Front Stage Sundown SA-65CS V.2
    Amplifiers Sundown SAX-100.4 V.2/Sundown SCV-2000D
    Subwoofers Sound Qubed HDS208-D2
    RCA's Stinger 8000 Series
    Sound Deadening Stinger Roadkill
    Alternator Wrangler 200 Amp
    Battery Stinger SPP1200
    Power/Ground Stinger 0 Awg
    Enclosure Ported 30 Hertz
    ronin1717's Avatar
    ronin1717 is offline Member
    Apr 2017
    tx
    130
    2 Post(s)
    48 Post(s)
    Quote Originally Posted by 350zspl View Post
    This^^^ pioneer radio, I've experienced this... something about a pic fuse wish I could be more help
    Sep 2009
    5,501
    14 Post(s)
    2172 Post(s)
    Pioneer headunits are notorious for needing additional grounding on the RCAs.
  9. #9
    flappijs's Avatar
    May 2018
    Latvia
    Yeah, was reading through the forums and saw that some people had problems and fixed with grounding RCA's , so after writing when I remove the RCA's the thumping stops I thought I should try it too ,havent it tested yet, but if I understand it right, I just wrap some thin wire around the RCA's outer shell and then the other end of wire attach to radio case right ?
  10. #10
    350zspl's Avatar
    Mar 2008
    WPB Florida
    4,096
    3 Post(s)
    138 Post(s)
    i think there is a bolt on the back of the radio you can ring terminal too
  11. #11
    Louisiana_CRX's Avatar
    Louisiana_CRX is offline dem shoes......
    Aug 2006
    Piney Hills of Louisiana
    37,548
    24 Post(s)
    1883 Post(s)
    Being pioneer most likely the internal pico fuse is shot ..grounding the rcas usually helps but doesn’t get rid of the noise all the way ..Pioneer wants more than the decks are worth to fix the issue
    Current 2010 Louisiana USACi State Records :
    Trunk 0-1000.................. 151.3
    StreetBeat 2................... 145.6
    Stock 1801-up.................153.8
    SuperStock 1801-up..........154.2
    Top three in 11 out of 26 power classes and Louisiana USACi Points Leader at 465
  12. #12
    flappijs's Avatar
    May 2018
    Latvia
    Finally got time to try ground the RCA's ,aaaaaand it works now,no more thumping.
    Thanks for the help .
  13. #13
    350zspl's Avatar
    Mar 2008
    WPB Florida
    4,096
    3 Post(s)
    138 Post(s)
    sweet
    with pioneer i always remove the RCA's before connecting or disconnecting power .
+ Reply to Thread
