+ Reply to Thread
Results 1 to 4 of 4
Reload Thread: Voltmeter + location
    CplCuddles's Avatar
    CplCuddles is offline Certified Meme Warrior
    Nov 2014
    Topeka, KS
    373
    2 Post(s)
    129 Post(s)
    Hey guys,
    So I have an easy question, I hope. I know people say when putting in a voltmeter you want to hook it up to your amp inputs to get the best reading. If I have say 2-3 amps and I hook it up to the power distro within a foot from each input will that give me a good reading for all the amps?
    02 Chevy Tahoe
    Optima Redtop up front
    Kenwood X599
    Crescendo Audio Symphony Coax's
    Sundown Audio SAX 100.4 & SAZ 1500d
    Sundown Audio X 12v2 @ 29Hz
    THATpurpleKUSH's Avatar
    THATpurpleKUSH is online now Smoke weed everyday
    Sep 2009
    Banging gears and passing queeers
    5,511
    14 Post(s)
    2176 Post(s)
    Re: Voltmeter + location
    Yes
    shizzzon's Avatar
    shizzzon is online now I am who you think I am
    Apr 2008
    KY
    1,266
    19 Post(s)
    299 Post(s)
    If you are only using 1 voltmeter, this is what i'd do-
    If this distro is controlling the power distribution to all amplifiers, then you would do 1 of the 2 following-
    1- Connect the voltmeter to the amp that will potentially always pull the most power.
    If they are all relatively about equal, then connect the voltmeter to the distro block on the side that goes directly to all the amplifiers, but ALSO check the following as well-
    Look at the voltmeter's reading when playing loud.
    Now, while playing, individually measure each amplifier's voltage via DMM and compare to voltmeter.
    This will ensure that no other variables are at play that could possibly force one amplifier to be losing voltage compared to the others.
    And as always, if you are leary about electrical stability, can always install one of our SMART Voltmeters which are user programmable.
    They will shut down any and all audio equipment if voltage trips a set threshold immediately to protect equipment from failing when electrical issues arise without the user being aware at the time of driving.
  4. Likes wew lad liked this post
  5. #4
    CplCuddles's Avatar
    Nov 2014
    Topeka, KS
    373
    2 Post(s)
    129 Post(s)
    Quote Originally Posted by shizzzon View Post
    That smart voltmeter looks pretty neat, thanks for the info!
    02 Chevy Tahoe
    Kenwood X599
+ Reply to Thread
