+ Reply to Thread
Results 1 to 8 of 8
Reload Thread: engine noise while headlights on , acceleration.
    contevo's Avatar
    contevo is offline Junior Member
    Dec 2013
    texas
    3 Post(s)
    hello, everyone.
    So recently I upgraded my factory unit to a dual xdvd6bt27
    on a Honda Civic 2006 ex. I follow this guide:::
    D.I.Y. the long-awaited amp integration harness by Whiterice! - 8th Generation Honda Civic Forum
    I ran into engine noise while headlights are on and driving, when I turn it off the headlights the noise goes away. I did ground the RCA and still does it I double check my wiring I don't see anything wrong. I did not have this problem when I had factory unit.
    Anybody ran into this problem? if so what was your solution!
    Thank You for your time.
    Alejandro14's Avatar
    Alejandro14 is offline Senior VIP Member
    Jul 2016
    Texas
    211
    70 Post(s)
    Re: engine noise while headlights on , acceleration.
    maybe try new rcas t spec line are good ... check if any wire is making contact check the ground on radio ..
    LOUDNDEEP's Avatar
    LOUDNDEEP is offline DRAGGIN DEEZ NUTS
    Feb 2013
    NEW YORK
    224
    72 Post(s)
    may not be related but do you have led headlight bulbs,does it make the same noise on all sources?
    contevo's Avatar
    Dec 2013
    texas
    3 Post(s)
    Quote Originally Posted by LOUDNDEEP View Post
    No led installed. I was thinking checking my speakers wire to see if making contact to something. This is so frustrating.
    wew lad's Avatar
    wew lad is offline wew lad inc
    Mar 2015
    Des Moines, IA
    5,399
    50 Post(s)
    2892 Post(s)
    check all the grounds in your engine bay
    Quote Originally Posted by JohnKuthe View Post
    I AM The Future of personal transportation, NOW!!
    Quote Originally Posted by Loudz View Post
    Pretty sure everyone on this site hates you (@JohnKuthe) more then me and that's very hard to accomplish.
    contevo's Avatar
    Dec 2013
    texas
    3 Post(s)
    I check for all ground tonight
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,539
    42 Post(s)
    6181 Post(s)
    Very well could be bad ground. I have the same issue.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
    Soundstream Rubicon 1.2500D & 4.500 amps (New amps coming soon)
    contevo's Avatar
    Dec 2013
    texas
    3 Post(s)
    So after 2hrs i kind of pin point to my right front speakers, and i pull the FR rca cable out of the headunit and noise gone. I dont where to look for in my engine bay for bad ground?
+ Reply to Thread
