+ Reply to Thread
Results 1 to 12 of 12
Reload Thread: Voltage Meter Hook Up ?
    LetMyBeatPound's Avatar
    LetMyBeatPound is offline Sinister Deeds Done Cheap
    Sep 2017
    Albuquerque, NM
    32
    268
    155 Post(s)
    Just finished installing my HO alternator from Excessive Amperage. And I couldn't be happier, my system is louder, the bass is cleaner, my amp isn't getting as hot, and my subs look like they are actually moving now. I would like to add a voltage Meter now tho so I could keep track of where my voltage is... I'm gonna try and blow my subs up over the next few days cuz I have both cone kits I needed and the Head unit JeffDaChef recommended should be here today. So I'll be doing good
    93 Dodge Caravan
    Excessive Amperage 300amp Hairpin Alt
    JVC KD-X340BTS, 2x FU750v2.0 - 18"
    12CFT Net Vol. Ported Box Tuned @ 32hrz
    Aphard Sound Machete M2000D
    3x 100aH Power Sonic Batteries
    Sony 5.25 4ways(Dash)
    Kicker 6X9 3ways(Rear Hatch)
    2/0g AWG OFC Welding Cable
    8G AWG OFC Speaker Wire
  2. Likes Darth_Immitis liked this post
  3. #2
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,945
    240 Post(s)
    7770 Post(s)
    Re: Voltage Meter Hook Up ?
    hook the voltage meter's pos and neg straight up to your amp's negative and positive.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  4. #3
    Sep 2017
    Albuquerque, NM
    32
    268
    155 Post(s)
    Quote Originally Posted by Jeffdachef View Post
    That's a good idea, that way it's reading the voltage I wanna know about no? Thanks Jeff, you've been such a big help to me brotha, you have no idea... Everyone that hears my system is super impressed and I couldn't of done it without y'all's help. And I'm not even done I still got the front stage and the 4x 18 C-pillar build to do but it's coming out nice
    93 Dodge Caravan
  5. #4
    Jeffdachef's Avatar
    Feb 2013
    15,945
    240 Post(s)
    7770 Post(s)
    yeah you dont really need to see your battery voltage, you need to see the voltage the amp sees so you'll figure out any possible ground issues that might occur if your battery voltage(measure with a multi-meter) and amp voltage(volt meter) are way different.
  6. #5
    Hertz Mafia's Avatar
    Hertz Mafia is offline FEATHER RUFFLER
    Jul 2016
    Michigan
    2,109
    42 Post(s)
    1360 Post(s)
    U shouldn’t try and blow your subs. If a coil goes it could take out the amp. Seen it done before.
  7. #6
    Sep 2017
    Albuquerque, NM
    32
    268
    155 Post(s)
    Quote Originally Posted by Hertz Mafia View Post
    Not enough power to kill em. On a positive note tho, before I could stink up my speakers easily at 70-80% volume. Now I have it at 90-95% volume and haven't been able to stink them up yet. And since I added the voltage meter, at full tilt my voltage drops a lil under 14v when before my Max voltage was 13.4v with dips down to 10s and even got amp to go into protect cuz it dropped under 10v's and when this would happen my amp would get very hot fast... Now I can jam at 80-85% volume for 30-40 mins and amp only gets warm...
    That HO alt really really helped boost and stablize my system
    93 Dodge Caravan
  8. #7
    Sep 2017
    Albuquerque, NM
    32
    268
    155 Post(s)
    Are there any forum post or web sites that have information on eliminating rattles, vibration noise from everything. My rear quarter n mid windows rattle n bang so hard I think they may break sometimes and my roof n side panels move like my van is breathing and I don't even wanna get into the rear hatch noise... I'm thinking expanding foam, silacone, a lil bit of real sound deadener for the roof and hatch, and then a bunch of the cheap ductwork wrapping for the floor.
    Sound like a decent direction for sound deadening?
    93 Dodge Caravan
  9. #8
    Mayhem's Avatar
    Mayhem is offline Tiddies
    Feb 2017
    Gainesville, VA
    744
    10 Post(s)
    389 Post(s)
    To eliminate the rattles in my old SUV windows I used some basic weather stripping on the seals.
    All the way around the windows and the rear window hatch.
    Worked great for me because I never opened those windows anyways.
    For deadening, just don’t skimp on it.
    All my panels are deadened and I reinforced all the clips. Took a while but completely worth it. I have zero rattles inside the cabin.
    Spray foam is messy, I wish I didn’t have to use it but it does work.
    Team Fi 12
    CT 4000.1
    CT 125.4
    CT 60.4
    Crescendo PWX Mids / STS Tweets
    80PRS
    CES 270 Alt
    D3400 and 2 Kinetik HC2400s
    Maxwell supercap banks x2
    Urwifeinthepassenger
  10. #9
    Sep 2017
    Albuquerque, NM
    32
    268
    155 Post(s)
    Well I got that deck the KD-340BTS and I am not disappointed, I thought the HO alt and this HU would make a difference, but I'm totally blown away. It's a completely different system. That HU I had I there before must have been compete junk. It's funny that one guy said that adding that alternator and deck wouldn't help any... He was wrong big time... With proper power and signal, my system is producing great quality music now. The bass is Fuller now with the deck and you can distinguish between different notes now instead of them just bleeding together. Thanks again JeffDaChef, you are the man!
    93 Dodge Caravan
  11. #10
    Jeffdachef's Avatar
    Feb 2013
    15,945
    240 Post(s)
    7770 Post(s)
    yeah dude just wait till you do an active network setup with your mids and highs with that head unit. Your vocals will be beyond heavenly.
  12. #11
    Sep 2017
    Albuquerque, NM
    32
    268
    155 Post(s)
    Ffff
    Gg
    Oh yeah I can't wait. I got that Fosgate DSR-1 too, it just sitting in the closet. All I need is to order the 3 sets of speakers (tweets, midranges, midbasses), an amp, and a bit more wire. I'm gonna go with the PRV neo's for the mid range n bass. IDK which tweeters, I like the Crescendo FT1 super tweets tho. Would like to use a single amp to power them, but I think I'll just end up using two 1ks or a 1k and 500w.
    93 Dodge Caravan
  13. #12
    Jeffdachef's Avatar
    Feb 2013
    15,945
    240 Post(s)
    7770 Post(s)
    Quote Originally Posted by LetMyBeatPound View Post
    Ffff
    Gg
    doesnt work that way, you need a dedicated pair of channels for each mid, midbass and tweeter. Most likely you'll need to run two 4 channels at the minimum. A single big amp for all mid, midbass and tweeter is a horrible idea.
+ Reply to Thread
