+ Reply to Thread
Results 1 to 4 of 4
Reload Thread: 93 Park Ave Ultra any route for 2/0 welding cable through firewall
    guntherp's Avatar
    guntherp is offline Junior Member
    Jan 2018
    Chicago
    Hey guys! Newbie here!
    This 1993 Buick Park Avenue Ultra already had serious grounding/electrical issues that had to be rectified before a system upgrade could be considered. Purchased a 34/78 Northstar AGM deep cycle battery, 2/0 welders cable, tinned copper terminals, heat shrink tubing, 16ton hydraulic crimper, 220A DB Electric alternator and just completed the Big 4 with substantial improvements. Battery voltage at 12.8V and holds at 14.8V with full electrical load at highway speed.
    93 Park Ave Ultra any route for 2/0 welding cable through firewall-93-pau-big-4-upgrade-check-size.jpg
    Need to run 2/0 cable preferably through firewall and passenger door trim to trunk. There are body rust issues along the fuel lines where one would tie clip a power wire beneath the vehicle that have to be addressed in the future so it would be foolish to run wire outside at this time.
    Hoping to run two 2/0 power lines. The first to power a 1000W inverter mounted on the floor hump between driver and passenger seats. The second run to the trunk to power two deep cycle batteries which will be installed in the spare tire pit.
    Opened the dash and removed the glove box hoping to get access to what seemed to be grommets on the upper firewall.
    93 Park Ave Ultra any route for 2/0 welding cable through firewall-glove-box-access.jpg
    The battery as shown above is situated on the passenger side and there are grommets (well better call them electrical junctions) on the firewall side. The space beneath these grommets is difficult to reach due to the a/c accumulator and related piping but seems the only choice. Can't find any other "grommet" type connection on the passenger side.
    93 Park Ave Ultra any route for 2/0 welding cable through firewall-firewall-grommets.jpg
    Any advise would be much appreciated.
    Thanks!
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    10,274
    15
    39 Post(s)
    4244 Post(s)
    Re: 93 Park Ave Ultra any route for 2/0 welding cable through firewall
    Looks super tight under the hood from those pics. Sometimes you just have to drill. I like to go in low by the floor where passenger's feet would set.
  3. Thanks guntherp thanked for this post
  4. #3
    kcr357's Avatar
    kcr357 is offline Senior VIP Member
    Aug 2012
    ft laud
    337
    1 Post(s)
    128 Post(s)
    Ace has grommet fittings, just grab some of those and drill new holes.
    Sold to
    Bought from
    NinjaBass
    FasFocus00
    "If I was so worried about resistance I'd be unplugging the factory wiring harness, and checking resistance on every wire in my vehicle."
  5. Thanks guntherp thanked for this post
  6. #4
    guntherp's Avatar
    Jan 2018
    Chicago
    At this point, I've pretty much removed as much of the dash as courage and YouTube video directions will allow. Well at least when it's time to install new radio or gauges I'll know how, but it is of no joy on this endeavor.
    From the furthest depth that I can reach from the dash to the surface of the firewall is still 7 inches of Great Unknown. I probed with a tiny drill bit above the pictured wire harnesses but hit a new metallic obstruction once through the firewall and quit before I damaged something unseen so putting the dash back together now.
    Ordered a step drill kit from Amazon (Home Depot wanted $74, no thanks) and the self-sealing Stinger Firewall Bushing grommet which I understand is way overpriced so will check if ACE has similar.
+ Reply to Thread
  1. 2/0 or 1/0 SHCA lugs for 2/0 welding cable?
    By C1500martin in forum Wiring, Electrical and Installation Help
    Last Post: 06-03-2014, 12:47 PM
  2. Replies: 10
    Last Post: 03-31-2013, 08:10 PM
  3. 99 Buick Park Ave Ultra install log
    By maylar in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 12-23-2011, 04:47 PM
  4. Any suggestions for an audio set-up?
    By 98RangerOwner in forum Wiring, Electrical and Installation Help
    Last Post: 07-03-2002, 12:04 AM
  5. Are these any good for the price?
    By Sidefx in forum Subwoofers
    Last Post: 07-02-2002, 04:05 PM
