+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
Reload Thread: What battery(s) would you run?
    znewberry's Avatar
    znewberry is online now Junior Member
    Jan 2018
    Illinois
    21
    10 Post(s)
    Im getting ready to buy a second battery for my setup in an attempt to help the horrible dimming any suggestions?
    I was looking at XS Power XP3000
    4k RMS
    poolman966554's Avatar
    poolman966554 is online now Senior VIP Member
    Mar 2015
    NW, PA
    282
    1 Post(s)
    123 Post(s)
    Re: What battery(s) would you run?
    4k rms? Do you have a high output alt/ big 3 yet? if not, then your on a road for disaster. What kind of vehicle do you have?
    What amps do you have, and how big battery,and what ohm load are you running?
    Those are the most important questions as far as im concerned.
    That being said, i bought my Duracell G34 AGM at sams club for $129. they are popular around here and have good reviews. Great deal.
    Avinusa HU for 2007 Honda Crv
    Electrical : Duracell Grp 34 AGM with Big3
    front stage : stock
    Sub amp : AB 4480.1
    Subs : 2) Sundown SA-12s @1 ohm in 3.8cu'ft @ 33hz
    znewberry's Avatar
    Jan 2018
    Illinois
    21
    10 Post(s)
    Quote Originally Posted by poolman966554 View Post
    1) Chrysler 300 / Stock Battery
    2) Alt is stock at 160 im hoping it will do the job.
    3) Big 3 in this car is not much of help I have read due to heavier gauge wiring being used already.
    4) AMP currently is a little soundstream picasso 3500d 1ohm however I plan to get a NICE solid amp this summer. *Un decided on wich amp, open for suggestions*
    5) Current Subwoofers are two 2000w RMS Untouchable Sound 12" https://untouchable-sounds.myshopify...g-series-12-d1 However I have plans to get two sundown jv4 rev2 eventually. So preferabbly my next amp upgrade is strong enough to power that setup.
    you can see the box for the setup here. Just finished it tonight,
    https://youtu.be/zzI3EIeszWw
    $129 seems cheap! the ones im looking at are 300+ bucks without cables ;/
    los33's Avatar
    los33 is offline Car Audio G
    Apr 2014
    Houston, TX
    3,385
    24 Post(s)
    2153 Post(s)
    Quote Originally Posted by znewberry View Post
    I had multiple 300's, the 3.5l and the hemi..
    Both have the large red power wire which is 0 gauge, but the rest is not 0 gauge.. the ground wire is more like 8 gauge.
    Also mechman and many other companys offer a 240+ amp alternator for 399+.
    An AGM battery its self did wonders for the 300.
    Sent from my SM-N950U using Tapatalk
    znewberry's Avatar
    Jan 2018
    Illinois
    21
    10 Post(s)
    Quote Originally Posted by los33 View Post
    Wait are you using the AGM as a second battery or the primary?
    Mar 2015
    NW, PA
    282
    1 Post(s)
    123 Post(s)
    no reason not to use a agm as a primary
    front stage : stock
    Sub amp : AB 4480.1
    los33's Avatar
    Apr 2014
    Houston, TX
    3,385
    24 Post(s)
    2153 Post(s)
    AGM as a primary, you do not want to mix a standard lead acid battery with agm..
    Lithium and agm is perfectly fine.
    Look into autozone, oreily, advanceauto agm brand batteries.
    They are all odyssey batteries that work fine as a primary, the secondary battery can be a much more audio specific like lithium or just xs power or any other brand you prefer.
    macsdad's Avatar
    macsdad is online now boom-boom
    Jun 2010
    Trussville, Al
    52
    2,701
    22 Post(s)
    773 Post(s)
    I got my under the hood batt from advance auto for 140. Do they still run the primary batt in that car in the trunk? Should make it fairly easy to add batts if so. I have an xs975 in the rear near the amp.
    2013 Cadillac SRX Performance package
    Cadillac CUE Entertainment System
    10 speaker Bose premium
    Incriminator Audio IA20.1
    Stereo Integrity HST12MKII
    Bought from; mylows10 x5, double07 x6, ssteele x1, boxxcd x1, vecticus x1, 72impala x1, treesive x1, jaeguerra209 x1, pinoy2o9 x1, michaellane x1, trumpet x1, ricoshay x1, boomsday x1, mitchell0715 x1, Jeffdachef x1. Sold to; mrfoca x1, Treo 15 x2, Trades; AnthonyO x1, Shauncox26 x1, loudenuff x1
  9. #9
    znewberry's Avatar
    Jan 2018
    Illinois
    21
    10 Post(s)
    Ah I didn't think about changing my primary battery before adding a second battery.
    Right now I only am running the Soundstream Picasso 3500D and im getting dimming during hard hits. I dont plan on upgrading my amp for several months. I wonder if JUST a good AGM as primary will work without a second battery. Atleast untill I get more power.
    What do you think?
    1) Big 3 install
    2) AGM battery
    3) SECOND BATTERY (xs or w/e) ONLY if needed or when I get better amp.
  10. #10
    znewberry's Avatar
    Jan 2018
    Illinois
    21
    10 Post(s)
    Quote Originally Posted by macsdad View Post
    yup all in the trunk
    A little off topic but here is the first dry fit , glue still abit gooey I couldnt wait haha. I need amp rack idea now hmmmm
    https://ibb.co/dNySCR
    https://ibb.co/g9dSCR
  11. #11
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is online now NOT TO OLD TO BASS
    Jan 2017
    NC
    4,718
    17
    23 Post(s)
    1904 Post(s)
    What do you think?
    1) Big 3 install
    2) AGM battery
    yeah the duracell is good idea but i got my starter agm at advance., by it online u get 20-25% off so mine was like $136 and go up there and they install it.. as far as better amp have u looked at the wolframs pretty good deals on them and just for power orion xtr 2500 does over 3k, twisted sounds 2.8k i think did 4k..
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, custom 2.11 cf ad ported tuned @ 36hz 30.375 port area, soundqubed 6.5" coax, hp xover (hu), AGM starting batt... FU 750 destroying my spoiler https://www.youtube.com/watch?v=joeeCIZJpUs pioneer 3003 videos https://www.youtube.com/watch?v=rTcgVGvuFX8 https://www.youtube.com/watch?v=WI4yGDqN27g
  12. #12
    Jan 2017
    NC
    4,718
    17
    23 Post(s)
    1904 Post(s)
    looks like for a 300 advance agm would be $168 with discount..
  13. #13
    znewberry's Avatar
    Jan 2018
    Illinois
    21
    10 Post(s)
    Quote Originally Posted by BOOMINGRANDPA View Post
    TBH I havent got that far yet it was a headache figuring out the FiX 86 is what I needed to keep factory deck. Im new to this and trying to make it right. Ide love to get a good amp right now , however im still in the process of the basics it seems to prepare for bigger so for right now i will try the big 3, agm battery and hope it hold me over untill a new amp and second battery.
    that twisted sounds looks mean, thats right up my ally when I upgrade, why such a price dif from that and the orion !?!?
  14. #14
    znewberry's Avatar
    Jan 2018
    Illinois
    21
    10 Post(s)
    thats better than the initial 350+ I was going to spend on the second battery b4 primary upgraded.
    just to clearify this is the battery u guys are talking about https://shop.advanceautoparts.com/p/...000%7CL3*15597 with discount exact fit to my car its 210.48
  15. #15
    Jan 2017
    NC
    4,718
    17
    23 Post(s)
    1904 Post(s)
    yeah thats it 3yr warranty to but should be $165 + tax after 25% off.. grab that 25% pop up when u go there.. now there are other better agm batts but this is good for me..i have seen it test at 13v.. also i had load test done on it for fun 2 weeks ago mine is a 740 cca it tested 953cca at 12.65v at 109 degrees.. my old batt was a 800cca it tested at 529 which is y i replaced it lol...
+ Reply to Thread
  1. What sub/subs would you run?
    By Serpent710 in forum Subwoofers
    Last Post: 02-16-2011, 02:15 PM
  2. What subs would you run on Crunch GP3000d?
    By hornedfrog1985 in forum Subwoofers
    Last Post: 08-01-2009, 02:51 AM
  3. What amp would you run with Powerbass two 2xl 10"s?
    By Gradyj14 in forum Subwoofers
    Last Post: 12-19-2008, 02:17 PM
  4. What 15" Would you run off a Kicker 2500.1?
    By WhiteEX in forum Subwoofers
    Last Post: 11-10-2008, 08:44 PM
  5. What would you run? Oz ME or RE SE?
    By BASS_WARRIOR in forum Subwoofers
    Last Post: 06-03-2008, 11:32 PM
