+ Reply to Thread
Results 1 to 4 of 4
Reload Thread: Noise in ACC wire from dash
    mattkim1337's Avatar
    mattkim1337 is offline Junior Member
    Jan 2018
    Portland, OR
    2 Post(s)
    Hi, after many days of checking and moving my grounds around, I have finally found the source of my speaker whine. Originally, I had my Pioneer AVH-4200NEX connected to the factory ACC and ground harness. This caused speaker whine whenever I accelerated or braked (I'm driving a hybrid car). I temporarily rewired the headunit to run off the cigarette lighter +12V and ground, and all noise is completely gone. I'm happy that I discovered a workaround, but could anyone explain why the acc wire from the factory harness gave me speaker whine while the cigarette lighter did not?
    wew lad's Avatar
    wew lad is online now wew lad inc
    Mar 2015
    Des Moines, IA
    4,568
    46 Post(s)
    2362 Post(s)
    Re: Noise in ACC wire from dash
    Quote Originally Posted by mattkim1337 View Post
    Noise is almost always an issue with a ground not the source signal. It honestly sounds like the unfortunate consequence of the vehicle being hybrid and maybe they didn't mitigate for noise under load properly?
    I don't see any issues going forward with it wired the way you have it, but I am curious if grounding the headunit somewhere closer to the ground for the accessory ground or the computer would help
    Is your ground for the headunit in the OEM harness or directly to sheet metal?
    Quote Originally Posted by JohnKuthe View Post
    I AM The Future of personal transportation, NOW!!
    Quote Originally Posted by Loudz View Post
    Pretty sure everyone on this site hates you (@JohnKuthe) more then me and that's very hard to accomplish.
    Jan 2018
    Portland, OR
    2 Post(s)
    Quote Originally Posted by wew lad View Post
    I tried grounding the head unit through both the factory harness wire and to bare sheet metal (using a multimeter to find a ground point) and I still had the whine.
    wew lad's Avatar
    Mar 2015
    Des Moines, IA
    4,568
    46 Post(s)
    2362 Post(s)
    Is your car under any sort of warranty?
    You might try posting in a forum specific to your car
+ Reply to Thread
  1. Bad RCA wire? 4 channel amp will cut in and out from channels
    By eargj in forum Wiring, Electrical and Installation Help
    Last Post: 10-24-2017, 02:18 PM
  2. Need help with running a wire from tailgate of minivan to the front dash
    By badshah2000 in forum Wiring, Electrical and Installation Help
    Last Post: 06-21-2016, 07:37 AM
  3. popping noise in dash speakers
    By treylittlefield in forum Speakers
    Last Post: 09-03-2009, 09:40 PM
  4. 2000 Pathfinder: How can I get a wire from the engine bay to behind the dash?!!?!?!??
    By AVSTANG02 in forum Wiring, Electrical and Installation Help
    Last Post: 07-03-2005, 03:53 PM
