+ Reply to Thread
Results 1 to 2 of 2
Reload Thread: Speaker Install Help
    nawcor's Avatar
    nawcor is offline Junior Member
    Jan 2011
    Florida
    I'm installing new door speakers and I'm running new speaker wire to the amp on a stock radio.
    Do I run the new wire just off the speakers themselves straight to the amp or do I split them from the stock radio wires and then run them to the amp?
    It's been awhile since I've done an install and I can't seem to remember the answer.
    Dec 2017
    Phoenix, AZ
    101
    34 Post(s)
    Re: Speaker Install Help
    You just run the wire to the amp. The amp has connections either through RCA cables or high wire that go from the head unit to the AMPLIFIER. The AMPLIFIER takes the signal from the head unit, and AMPLIFIES the signal sending more power to the speakers. If you were to wire both, you would be trying to take the same input from the head unit and the amplifier. Not sure how that would work, either playing both signals and sounding like it was a constant echo, or the amplifier may drown it out. Either way, Just wire the speakers through the amplifier.
+ Reply to Thread
  1. Hyundai Excel '96 Speaker Install Help
    By ragils5 in forum Wiring, Electrical and Installation Help
    Last Post: 09-08-2005, 01:52 AM
  2. speaker install help
    By Dj-torn in forum General Discussion
    Last Post: 06-05-2005, 10:57 PM
  3. speaker install help
    By FLYASAPELICAN in forum Wiring, Electrical and Installation Help
    Last Post: 04-04-2005, 07:25 PM
  4. Speaker Installation Help
    By GReddyBooSTer in forum Speakers
    Last Post: 03-29-2005, 03:48 PM
  5. Speaker Install Help
    By John AMD in forum General Discussion
    Last Post: 09-24-2002, 03:03 PM
