+ Reply to Thread
Results 1 to 6 of 6
Reload Thread: 2008 Taurus power lead from battery (HELP!!!)
    Fishx65's Avatar
    Fishx65 is offline Member
    May 2011
    Michigan
    33
    Been digging around on the firewall of this 08 Taurus all morning trying to find a place to run an amp power wire. I was hoping to go through a pre-existing grommet like the good ole days but I'm not finding anything. There's so much sound dampening material on both sides of the firewall I can't see anything. Any installers on here remember where to get through on the 08-09 Taurus?????
    Popwarhomie's Avatar
    Popwarhomie is offline Team Lethal Pressure
    Jan 2010
    Jacksonville, FL
    5,029
    59 Post(s)
    2293 Post(s)
    Re: 2008 Taurus power lead from battery (HELP!!!)
    2016 Focus ST - Rockford DSR1 / PPI 900.4 / Silverflute 6.5" mids / Massive CT2 tweeters /Sundown Xv2 15"/ Taramps DSP3k / Stinger Roadkill / KNU wiring / Northstar SMSAGM80 /
    2010 Focus coupe [email protected]
    Pioneer 80prs /(8) FU Audio 750 12"s / (4) FSD 2600s / (1) FSD 125.4 / (1) FSD 85.4 / (4) Crescendo UN-10" mids / (4) Crescendo FT1 tweeters / Stinger Roadkill / 2/0 EB flex wire / (5) Powerware 90AH batteries / DC 270XP Alt /
    https://www.youtube.com/popwarhomie
    Quote Originally Posted by BOOMINGRANDPA View Post
    I have no idea what i'm talking about.
    Fishx65's Avatar
    May 2011
    Michigan
    33
    Thanks Pop, saw that link the other day and it would work fine. I was just hoping to find a grommet I could slide it through without drilling a hole. Got everything installed this morning except for the power cable. I'm gonna head out to the garage and give it one last go before I breakout the drill. Got anxious and ran a jumper outside the vehicle to the amp and it sounds great!!!!!
    Jan 2010
    Jacksonville, FL
    5,029
    59 Post(s)
    2293 Post(s)
    If you have a good place to run it under the car(most likely don't) I would do that. Should be a plug in the spare tire well so you don't have to drill a hole.
    Fishx65's Avatar
    May 2011
    Michigan
    33
    Quote Originally Posted by Popwarhomie View Post
    Thanks. Amp is gonna sit under drivers seat. Just spent another 15 minutes searching for a way in and it looks like I might be able to get it through the hood release cable grommet. Unfortunately, there's almost no room to work on either side of the firewall. Still might have to breakout the drill.
    Fishx65's Avatar
    May 2011
    Michigan
    33
    Got in through an unused grommet on the drivers side kick panel!!!! It was really hard to find cuz it's almost completely hidden by the drivers door wiring boot.
  7. Likes Popwarhomie liked this post
+ Reply to Thread
  1. 2 power wires from battery
    By 2007rustanggt in forum Wiring, Electrical and Installation Help
    Last Post: 02-26-2012, 12:39 PM
  2. Alarm Sounds when power re-applied from battery?
    By headless in forum Wiring, Electrical and Installation Help
    Last Post: 02-21-2006, 11:31 AM
  3. Replies: 41
    Last Post: 08-11-2005, 10:34 PM
  4. Amp power from battery
    By jheaton57 in forum Wiring, Electrical and Installation Help
    Last Post: 09-30-2004, 11:26 PM
  5. Power light comes on amp but no sound from subs??HELP
    By jamie heim in forum Wiring, Electrical and Installation Help
    Last Post: 01-29-2004, 12:54 AM
