+ Reply to Thread
Results 1 to 5 of 5
Reload Thread: Rear batteries don't seem to be charging
    Airman21's Avatar
    Airman21 is offline CarAudio.com Elite
    Mar 2006
    Ohio
    536
    1 Post(s)
    13 Post(s)
    I have a 300amp alt and Duracell agm in the front with 2/0 going to the rear batteries (2 XS Power 3100). Noticed the volts on my Taramp 8000d was reading 11.7. Normally it reads low 14 until I am really pushing it then it drops down to low 13's. I started checking the amp before I would drive to work or home (1 hour each way). 11.7 at idle and when using the subs it would drop to 10.9. Next trip it started at 11.6. Seemed to drop .1 after each 1 hour drive with low volume. Front battery is totally charged so I know the alt is doing it's job and my electrical system is staying at 14.1 while cruising and 12.4 when idle so everything is good there. I checked my fuses everything is good. Is the 1 run of 2/0 not good enough? I would think it would be enough. Even with the subs turned off and a 1 hour drive the batteries didn't go up in voltage at all which makes me think maybe something with the wiring is the issue. Any ideas? I have the charger hooked up to the back batteries right now. Been pumping 40amps for 3 hours and still not fully charged yet.
    98 Bravada
    Quote Originally Posted by Twistid View Post
    huh? oh ya, thats my number! give me as many calls as you like! infact you can post it on gay meeting websites for late nite butt secks
    Originally Posted by Ed Lester
    I am gonna use my computer for what it was designed for and thats to download P0rn.
    REF- Schism13 (trade), 6spdcoupe (bought), 32tl (bought), thunder9500 (bought), 3.5Max6spd (bought), Blackbonnie (bought), rpfuror (built me a box), Iggster (bought),nitro_freak1 (bought), M3NTAL (bought)
    dragon.breath's Avatar
    dragon.breath is offline Senior VIP Member
    Nov 2007
    Al
    460
    108 Post(s)
    Re: Rear batteries don't seem to be charging
    Just start checking connections, like the rear battery ground to the car.
    digital designs 9512h with cf cap
    sundown saz 3000d at 2 ohms
    meca legal 141.3 db on the headrest with a 34hz tuned daily box
    Airman21's Avatar
    Mar 2006
    Ohio
    536
    1 Post(s)
    13 Post(s)
    Quote Originally Posted by dragon.breath View Post
    Yep I went out and checked connections. The positive on from the front battery to the rear was disconnected. Dang mechanics... lol.... everything is working as normal thanks...
    Shocked that I was able to go 2 weeks on battery only for both amps. Those xs power are no joke.
    98 Bravada
    nyoc's Avatar
    nyoc is offline Member
    Sep 2010
    Toledo, OH
    82
    6 Post(s)
    What Duracell are you running up front? I have 3 DURDC12-100P and I was wondering about using 1 up front for my starter. Thanka
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is offline CHEAP A/F
    Jan 2017
    NC
    6,733
    17
    30 Post(s)
    2687 Post(s)
    check in line fuses.. 12.4 isn't very good at idle mine is 14.6 with no extra batts big 3 or big ga wire.. just let advance load test it..
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, 2.1cfad ported, soundqubed 6.5" coax/doors, hp & lp xover on hu, AGM starting batt...
    2 ohms rule
+ Reply to Thread
  1. New battery needs to be charged?
    By ssj2xxgotenxx in forum Wiring, Electrical and Installation Help
    Last Post: 07-12-2006, 01:47 AM
  2. Sub boxes don't need to be perfectly square right?
    By Jeepaudio in forum Subwoofers
    Last Post: 03-21-2004, 03:15 PM
  3. Qtc, Vas - don't seem to add up for an Eclipse
    By danfortner in forum Enclosure Design & Construction Help
    Last Post: 04-09-2003, 02:43 AM
