+ Reply to Thread
Results 1 to 1 of 1
Reload Thread: Mercedes-Benz 1999 ML 320 Bose Wiring New Head Unit
    nicolaselhani's Avatar
    nicolaselhani is offline Junior Member
    Aug 2017
    New York, NY
    Hello,
    I have a Mercedes-Benz 1999 ML 320. It comes with a Bose Amplifier and Subwoofer. I took out the original tape player and replaced it with a double din Android Head Unit: https://goo.gl/XrV6Yp
    For the speakers connection I used the RCA outputs from the new headunit instead of the direct wiring from the harness, because the direct output from the new headunit created a lot of noise and distortion (I'm assuming amp from new headunit to amp in car was too hot a signal).
    I just have two questions:
    Question 1
    The subwoofer wiring diagram on the car shows four connections - instead of the regular 2 connections of positive (+) and negative (-).
    I wouldn't know how to splice that to an RCA head to connect to the new headunit's subwoofer out RCA plug.
    There is a good amount of bass in the car when I play music - does this mean the car's amplifier is automatically distributing bass to the subwoofer without me having to connect anything? If not, how can I connect it?
    (I attached the car's wiring diagram as well as the headunit's wiring diagram for help).
    Question 2
    The person who initially installed the unit when I was out of the town, not sure he did a good job. Do you guys mind verifying the following and if I need to change anything?
    1. Headunit ACC wire -> Connected to -> Car Ignition wire (Shouldn't this be connected to the Constant 12V?)
    2. Headunit Amplifier Control wire -> Connected to -> Car Antenna Trigger wire (Do I need this connection at all if don't want to use the FM/AM? Or is this something for the amplifier?)
    3. They connected both the "Ground" and "Brake Control" wires from the Headunit -> Connected to the same -> Car Ground wire (What is Brake Control? Do I really need this to be connected to anything? What purpose does it serve?)
    4. Finally the Headunit's ILLUMINATION wire was left unused and the Car's ILLUMINATION wire is also unused. Shouldn't I connect them together? My new headunit's Panel light is always on. If I connect them will they turn on only when I turn the car's lights on?
    Thank you guys so much for all your help
    Nick
    Attached Thumbnails Attached Thumbnails Mercedes-Benz 1999 ML 320 Bose Wiring New Head Unit-radio-wiring.jpg   Mercedes-Benz 1999 ML 320 Bose Wiring New Head Unit-car-wiring.jpg
+ Reply to Thread
  1. Need help wiring new head unit
    By *Ace* in forum Wiring, Electrical and Installation Help
    Last Post: 08-15-2012, 03:29 AM
  2. Wiring New Head Unit with Bose (No Onstar) *Quick Question*
    By s1m0nx in forum Wiring, Electrical and Installation Help
    Last Post: 08-30-2010, 10:59 AM
  3. Help installing new head unit in 1999 Ford Explorer
    By booty900 in forum Head Units
    Last Post: 02-01-2010, 05:22 PM
  4. Need Help: Trouble wiring my new head unit
    By cnoxin1234 in forum Wiring, Electrical and Installation Help
    Last Post: 01-18-2009, 06:28 AM
  5. What do I need to install a new head unit on a Chevy BOSE system??
    By shamisc in forum Wiring, Electrical and Installation Help
    Last Post: 07-11-2008, 12:25 AM
