+ Reply to Thread
Results 1 to 6 of 6
Reload Thread: Did I get my internal amp?
    tbreitinger14's Avatar
    tbreitinger14 is offline Junior Member
    Mar 2015
    Sac City, IA
    5 Post(s)
    Hey, guys.. so, I'm fairly certain I f'ed up my internal amp. I have a dual alb10 (I know, crap anyways) that I think I fried. I had originally had a short wire running from the positive terminal to the remote terminal for testing, as well as having my ground connected.
    Well, when I went to install the actual remote wire, I pulled out that small wire running from the power terminal and scraped the ground terminal (there was a spark). Now, it doesn't work.
    I have replaced the fuses (even though they didn't look like they were blown) and I've tested power with a DMM. DMM shows the correct power when going from positive to ground terminal.
    No light shows on though. Not even a red or protection mode light.
    So, question is, is it safe to say that I've fried the internal circuitry of this powered subwoofer? Follow up question, is there an easy way to diagnose / fix?
    Thanks!
    shredder1's Avatar
    shredder1 is offline CarAudio.com Elite
    Dec 2013
    Phoenix, AZ
    1,560
    20 Post(s)
    719 Post(s)
    Re: Did I get my internal amp?
    Did you check the fuse at the battery... do you have one?... power at the terminals tho... IDK if that's worth fixing if it is blown... I suppose it can't hurt to try...
    The Budget Beater Blazer Build... Lookin' for those Basshead Problems!
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is online now CHEAP A/F
    Jan 2017
    NC
    6,735
    17
    30 Post(s)
    2688 Post(s)
    Quote Originally Posted by tbreitinger14 View Post
    Thanks!
    not really unless u pull sub and test it separtely not really but amp is probably gone if u replaced all fuses.. man u better off to get like ct sounds package on amazon for like $200 u get fair amp ok sub and ported box and u can upgrade sub and or amp later with that..
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, 2.1cfad ported, soundqubed 6.5" coax/doors, hp & lp xover on hu, AGM starting batt...
    2 ohms rule
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    10,265
    15
    39 Post(s)
    4238 Post(s)
    Thanks!
    This is hard to follow, but it seems you may have fried the remote turn on output from your head unit if that's what you shorted to ground.
  5. Likes shredder1 liked this post
  6. #5
    Mar 2015
    Sac City, IA
    5 Post(s)
    I've replaced the fuses. Also, it has nothing to do with the head unit... the short happened when my jumper that was connecting my power and remote accidentally hit the ground.
    Also, I know I could go with a better sub, just ran outta money. �� bought all new infinity door speakers and a new pioneer 4800bs.
    Thanks for the responses!
  7. #6
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,528
    42 Post(s)
    6179 Post(s)
    I see the confusion. When you keep saying remote wire, we're thinking the blue remote wire coming from the HU....which turns on the amp(s) once the HU turns on. You need to call it something else to defuse the confusion.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
    Soundstream Rubicon 1.2500D & 4.500 amps (New amps coming soon)
+ Reply to Thread
  1. Cant get my JL amp to turn on
    By sc300jz in forum Wiring, Electrical and Installation Help
    Last Post: 12-12-2011, 06:19 AM
  2. Did I fry the internal amp??
    By mrgraffix in forum Wiring, Electrical and Installation Help
    Last Post: 06-02-2010, 02:14 AM
  3. Replies: 132
    Last Post: 04-07-2009, 06:32 PM
  4. Did i blow my amp?
    By <Confused_beginner> in forum Wiring, Electrical and Installation Help
    Last Post: 05-04-2002, 02:12 PM
Tags for this Thread
