+ Reply to Thread
Results 1 to 4 of 4
Reload Thread: 8gauge to 0gauge
    Bradda_dan's Avatar
    Bradda_dan is offline Junior Member
    Jun 2017
    Kapolei, Hi
    1 Post(s)
    8gauge to 0gauge
    Iʻm running an 8 ga power wire from my battery but need 0gauge wire for the second amp i bought. If i ise a power dist block will it over heat and cause damage or should i just run 0 from my battery and figure out a new way to run the 2 amps. Thanks
    adulbrich's Avatar
    adulbrich is offline Lock up your daughters!
    May 2014
    Ames, Iowa
    19
    13,818
    118 Post(s)
    6114 Post(s)
    Re: 8gauge to 0gauge
    Run 0 gauge from your battery. Do NOT run 0 gauge off of 8 gauge!
    My Silverado is under construction AGAIN http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/621466-alexs-silverado.html
    Quote Originally Posted by massivespl View Post
    Love is when she licks your butthole and try's to kiss you and u smack her but she doesn't get mad because she know that nasty and she in the wrong
    Quote Originally Posted by Slo_Ride View Post
    Fuck me running. Even I wouldnt eat stripper snatch.
    Quote Originally Posted by ilikeradios View Post
    I would rather beat you to death with a garden rake then talk politics with you due to your overwhelming ignorance.
    Quote Originally Posted by Joseph7195 View Post
    A three legged hooker walks into a bar. Yadda Yadda Yadda, I ended up sucking a dick.
    Quote Originally Posted by gckless View Post
    When that hooker turns out to have a cock. That's bigger than yours.
    Quote Originally Posted by LongThrow View Post
    If I had $2,000, I wouldn't be running kicker comps.
    Jeffdachef's Avatar
    Jeffdachef is offline Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,088
    217 Post(s)
    7247 Post(s)
    get rid of the 8 gauge completely
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
    audiobaun's Avatar
    audiobaun is offline CarAudio.com Veteran
    Jun 2011
    Tx
    9,104
    25 Post(s)
    2100 Post(s)
    Id save that 8ga wire if its a decent wire count and use it on your sub/or future sub wiring
    2)American Bass VFL Mini Hybrid [email protected] Ea 4)American Bass XFL DVC 4ohm [email protected] Ft [email protected] CDT 6,5 HD6 Briax.,CDT CL60,CDT 25 tweets,Kicker KS25 tweets Autotek Mean Machine [email protected],Autotek BTX [email protected] AlterStarts Alt 255A/Dallas,Tx,2)Orileys Super Start AGM batts(1more coming)Cadence CCA 0ga on Big 6,AudioTechnix 0ga CCA Kicker Kq9 Eq,Eclipse CD3000(lookingfor upgrade)StingerPro Distro,3)XS Scorpian 8in Scroll Fans 1998 3dr Xcab Chevy(under construction,but operational)
+ Reply to Thread
  1. wanting to buy 0gauge wire
    By silverstarL7 in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 06-16-2011, 11:49 AM
  2. wtb: DISTRO 0gauge to 3-4gauge outputs.
    By Virtue in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 09-11-2009, 11:03 PM
  3. Replies: 13
    Last Post: 04-17-2009, 05:52 AM
  4. 2 runs of 4 gauge wire to a amp that takes 0gauge???
    By 5.0coug in forum Wiring, Electrical and Installation Help
    Last Post: 05-05-2007, 03:13 AM
  5. 4gauge already ran, upgrade to 0gauge?
    By aggybong in forum Amplifiers
    Last Post: 06-18-2005, 06:45 PM
Tags for this Thread
