+ Reply to Thread
Results 1 to 6 of 6
Reload Thread: how to wire my amp to 4 speakers when stereo only has 2 RCA outputs????
    bkm48198's Avatar
    bkm48198 is offline Junior Member
    Jul 2017
    Michigan
    1 Post(s)
    My pioneer car stereo only has 2 RCA outputs and I have a 4 channel amp, I have the rear speakers running thru the amp via the RCA cables but don't know the best way to hook up the front speakers to the amp also. I assume I could run wires from the head unit speaker output back to the amp and then from the amp to the front speakers, or I could get a RCA splitter (1 female to 2 males). Can I use both the RCA's for the rear and also hook up the fronts thru wires to the high input or will that cause the stereo to have problems? I know I can't hook up the rears thru the wires at the same time as the RCA's but is it OK to hook up the fronts?
    LosIsATool's Avatar
    LosIsATool is online now CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    18,044
    109 Post(s)
    7727 Post(s)
    Re: how to wire my amp to 4 speakers when stereo only has 2 RCA outputs????
    Y spliters.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    Zapco ST-4X SQ, ST-1000XMii
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
    Mike Waters's Avatar
    Mike Waters is offline Senior VIP Member
    Sep 2012
    Middleburg, Florida
    326
    82 Post(s)
    Quote Originally Posted by LosIsATool View Post
    Y spliters.
    What he said. Here's a link to a pair for sale so you can see what they look like.
    https://www.walmart.com/ip/2pcs-Fema...&wl13=&veh=sem
    bkm48198's Avatar
    Jul 2017
    Michigan
    1 Post(s)
    If I use the y spliters won't I lose the fade from front to back ? I would prefer not to lose the ability to have more power from the rear at times and the rear speakers will handle more power than my door speakers.
    Popwarhomie's Avatar
    Popwarhomie is offline Team Lethal Pressure
    Jan 2010
    Jacksonville, FL
    5,225
    64 Post(s)
    2421 Post(s)
    Quote Originally Posted by bkm48198 View Post
    Adjust the gains.
    2016 Focus ST - Rockford DSR1 / PPI 900.4 / Silverflute 6.5" mids / Massive CT2 tweeters /Sundown Xv2 15"/ Taramps DSP3k / Stinger Roadkill / KNU wiring / Northstar SMSAGM80 /
    2010 Focus coupe [email protected]
    Pioneer 80prs /(8) FU Audio 750 12"s / (4) FSD 2600s / (1) FSD 125.4 / (1) FSD 85.4 / (4) Crescendo UN-10" mids / (4) Crescendo FT1 tweeters / Stinger Roadkill / 2/0 EB flex wire / (5) Powerware 90AH batteries / DC 270XP Alt /
    https://www.youtube.com/popwarhomie
    Quote Originally Posted by BOOMINGRANDPA View Post
    I have no idea what i'm talking about.
    bkm48198's Avatar
    Jul 2017
    Michigan
    1 Post(s)
    I didn't think of adjusting the gains. I've 54 and have never been into amps and don't have subs, just have a Mustang with a nice engine and want to be able to hear the radio better over the exhaust when I get on the freeway.
+ Reply to Thread
  1. How to wire my amps
    By QSGTO in forum Wiring, Electrical and Installation Help
    Last Post: 04-28-2009, 06:37 AM
  2. How to wire my amp
    By spmorgan in forum General Discussion
    Last Post: 03-18-2009, 09:34 AM
  3. How To Wire My Amp and Subs Correctly?
    By xguntherc in forum Amplifiers
    Last Post: 12-29-2008, 10:32 PM
  4. How to wire my amp and sub
    By rjcastr in forum Wiring, Electrical and Installation Help
    Last Post: 09-23-2008, 02:32 PM
  5. How to wire my 2 extra speakers to 4 speaker HU?
    By accord2000 in forum Speakers
    Last Post: 06-02-2007, 03:10 AM
