+ Reply to Thread
Results 1 to 2 of 2
Reload Thread: head unit loses power and regains intermittently
    wdowns's Avatar
    wdowns is offline Junior Member
    Apr 2017
    Northborough, MA
    1 Post(s)
    Long post looking for help
    Kenwood head unit installed in 2011. No issues until about 6 months ago.
    Typical Day:
    Start engine first thing in morning - head unit is powered on and functioning normally
    Between 1 - 10 minutes into drive - head unit shuts off. no power. can't turn back on with power button.
    Sometimes between 5-10 minutes of no power - unit turns back on, functions normally again. Shuts back off after 1-5 minutes again. does not come back on for remainder of day.
    If I pull the 10amp fuse out from the car fuse block and put it back in (same fuse obviously, it is not a blown fuse), radio will turn on. Will shut down within 10minutes again.
    Yesterday (6/18/2017) I replaced the head unit with a new one. problem did not go away. It initially powered on and functioned normal, but lost power about 5 minutes in.
    made a video of the following (with new head unit installed):
    car in park in my driveway:
    turn engine on as normal, radio does not come on. pull radio fuse with engine running and replace. radio turns on; functions normally and sounds good. power radio off/on with power button on head unit; still working good. shut engine off, pull key out of ignition - radio shut down as it should have. put key back in and start car - no power to radio.
    I did this same troubleshooting with both head units - I don't think it has anything to do with the radio itself (anymore).
    Another note - With engine off and key out of ignition; if I pull the 10amp fuse and replace, the radio will come on. When this happens, the radio does not shut off, even with the doors open. I've seen this a couple times also when turning the engine off. If I notice it when leaving my car, I usually unplug the faceplate.
    more info during troubleshooting:
    while driving, when head unit is off, I sometimes hear an electronic sounding squeal for about 2 seconds, then I see the head unit power back on.
    When I had the old head unit disconnected, I heard pulsing squeal from speakers, almost like a security system?? lasted for about 90 seconds and then went away. No radio was hooked up. (If I have a security system, I don't know about it. I do have OnStar but I've never used it.)
    "service air bag" light sometimes comes on/off. usually doesn't stay on for more than 5 minutes. Maybe 4 or 5 times in past 6 months, I have also lost all dash indications (fuel level, tach, sped, and coolant temp) while driving for a couple seconds and then they came back.
    Assuming the radio problems are related to the other problems; can't say for sure.
    Can anyone offer some advice??
    Thank you
    Jan 2017
    28 Post(s)
    2226 Post(s)
    Re: head unit loses power and regains intermittently
    u either have a wire touching metal somewhere or just loose.. but i think the remote turn on to hu isn't tight or something., thats probably yellow wire that may be stuck in fuse box., tighten that fuse/wire..
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, custom 2.11 cf ad ported tuned @ 36hz 30.375 port area, soundqubed 6.5" coax, hp xover (hu), AGM starting batt...
    2 ohms rule
    Quote Originally Posted by Popwarhomie View Post
    Shit Ill sleep with you if you do that for me..
+ Reply to Thread
  1. Replies: 5
    Last Post: 12-18-2012, 07:38 PM
  2. Head unit gets power but screen is blank.
    By astin0801 in forum Wiring, Electrical and Installation Help
    Last Post: 11-21-2006, 12:39 AM
  3. head unit turning on and off????????
    By badaphooko01 in forum Wiring, Electrical and Installation Help
    Last Post: 03-28-2006, 02:31 PM
  4. tap into HEAD UNIT's power wire?
    By noob with an RS in forum Wiring, Electrical and Installation Help
    Last Post: 06-09-2005, 09:59 PM
  5. Head Unit shuts on and off
    By gundecker in forum Wiring, Electrical and Installation Help
    Last Post: 08-17-2003, 08:37 PM
