+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
Reload Thread: Route for 0 gauge wire???
    1mounty's Avatar
    1mounty is offline Member
    Jan 2017
    texas
    81
    43 Post(s)
    Has anybody ever ran 0 gauge wire through a Volkswagen Passat? If so what's the best route for it and the least amount of cutting. Help!?!?
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    13,554
    39 Post(s)
    5720 Post(s)
    Re: Route for 0 gauge wire???
    What year? What are your plans for the audio? What's going into the car?
    Should find an existing hole thru the firewall. Or sometimes people find a hole big enough to run some 1/0 gauge wiring thru along with a factory wire thru it. If all else fails, you can always drill a hole thru the firewall. But...makes sure your free and clear of anything.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
    macsdad's Avatar
    macsdad is offline boom-boom
    Jun 2010
    Trussville, Al
    52
    2,742
    23 Post(s)
    787 Post(s)
    I have ran wire under my car, zip tied it to some factory wire already there, never had an issue, just an idea dude.
    2013 Cadillac SRX Performance package
    Cadillac CUE Entertainment System
    10 speaker Bose premium
    Incriminator Audio IA20.1
    Stereo Integrity HST12MKII
    Bought from; mylows10 x5, double07 x6, ssteele x1, boxxcd x1, vecticus x1, 72impala x1, treesive x1, jaeguerra909 x1, pinoy2o9 x1, michaellane x1, trumpet x1, ricoshay x1, boomsday x1, mitchell0715 x1, Jeffdachef x1. Sold to; mrfoca x1, Treo 15 x2, Trades; AnthonyO x1, Shauncox26 x1, loudenuff x1
  4. Likes The_Grimy_One liked this post
  5. #4
    1mounty's Avatar
    Jan 2017
    texas
    81
    43 Post(s)
    A soundqubed hdc3 18 in the trunk and and a 04 passat
    ---------- Post added at 08:32 AM ---------- Previous post was at 08:31 AM ----------
    Quote Originally Posted by macsdad View Post
    How hard is that? And is there a hole for the wire to come back through or do I have to drill one?
  6. #5
    Mayhem's Avatar
    Mayhem is offline Tiddies
    Feb 2017
    Gainesville, VA
    715
    10 Post(s)
    368 Post(s)
    This ^^^
    I have two runs of power under mine and that's on my Jetta
    The factory firewall grommet can't fit 1/0
    Team Fi 12
    CT 4000.1
    CT 125.4
    CT 60.4
    Crescendo PWX Mids / STS Tweets
    80PRS
    Dumb amount of 1/0
    CES 270 Alt
    D3400 and 2 Kinetik HC2400s
    Urwifeinthepassenger
  7. #6
    1mounty's Avatar
    Jan 2017
    texas
    81
    43 Post(s)
    Quote Originally Posted by Mayhem View Post
    This ^^^
    So run it under and cut a hole in the trunk? On which side of the car?
  8. #7
    Mayhem's Avatar
    Feb 2017
    Gainesville, VA
    715
    10 Post(s)
    368 Post(s)
    Quote Originally Posted by 1mounty View Post
    Driver side
    i had to cut metal to get mine in. From the trunk, I cut a hole on the driver side wall. Right around the top side of the wheel well. The floor on mine was a lot thicker and the exhaust is right around that area. All that heat can stay down there and away from my wire.
    Its not hard and there are many zip tie points. Everything can be tucked up with ease.
    If you get that done then we can tackle the grounds. The ground points on my car were a bizzznitch to get to. I assume they will be on yours as well.
    The good thing is I've done everything there is to do to my VW except build a wall so ill do my best to answer any questions.
    Team Fi 12
    CT 4000.1
    CT 125.4
    CT 60.4
    80PRS
    Dumb amount of 1/0
    CES 270 Alt
  9. #8
    DarkKnightSM's Avatar
    DarkKnightSM is online now Senior VIP Member
    Mar 2017
    Co Springs
    373
    1 Post(s)
    191 Post(s)
    Consider this! Most factory grommet locations are already crammed tight. But rubber stretches! So if your 1/0 guage seems like its not fitting, take a smaller guage wire, wd40 that wire, atleast the part that initially goes into the grommet or rubber part, and start feeding it through, till you have enough to grab on the other side. Then with enough wire still left on the engine bay side, take the 1/0 guage wite and attach it to the smaller guage wire, id use wd40 on the initial part of the 1/0 that will be entering the firewall, then after enough gets theough it should slide back and forth relatively easy.
    My only thing is, on newer cars i hate pulling up trim peices, sometimes the rivets can be somewhat difficult to locate and you can end up breaking them. Making the reinstallation look a tad loose, it might be better to just heed the advise of others and go under. Whatever you do, run wire loom. Make sure that wire is fully protected
    Oh and for the purposes of attaching wire together, duct tape it BEFORE you wd 40 it otherwize it obviously wont hold
  10. #9
    macsdad's Avatar
    Jun 2010
    Trussville, Al
    52
    2,742
    23 Post(s)
    787 Post(s)
    It wasn't hard at all for me, it was an 08 dodge caliber, and since there were already factory wires there I just used the holes they used just had to make the hole bigger in the oem grommet.
  11. #10
    shredder1's Avatar
    shredder1 is offline CarAudio.com Elite
    Dec 2013
    Phoenix, AZ
    1,560
    20 Post(s)
    719 Post(s)
    When I put 2 runs of 0 ga under my Blazer to the rear I ran it through garden hose to protect it. Then zip-tied it it seemed an easy way to do this and cheap too... Harbor Freight.
  12. Likes macsdad liked this post
  13. #11
    shredder1's Avatar
    Dec 2013
    Phoenix, AZ
    1,560
    20 Post(s)
    719 Post(s)
    Then I used something similar to this where I went through the metal in the rear...http://www.ebay.com/itm/SET-OF-10-CA...item4615ecc42e ...
  14. #12
    1mounty's Avatar
    Jan 2017
    texas
    81
    43 Post(s)
    Driver side
    What if I told you guys there's no grommets on the driver side of a 04 Volkswagen Passat? Bc I can't find none and I have the panels off and everything
  15. #13
    shredder1's Avatar
    Dec 2013
    Phoenix, AZ
    1,560
    20 Post(s)
    719 Post(s)
    Are you looking for a grommet in the rear? I had to drill one thru with a hole saw bit then I installed a grommet/bushing to avoid that sharp metal where I cut it.
  16. #14
    1mounty's Avatar
    Jan 2017
    texas
    81
    43 Post(s)
    Quote Originally Posted by shredder1 View Post
    No through the front I can't find any even if they are small I was going to make it fit lol. I'm not trying to go under the car Bc I have no way to get it off the ground high enough for me
  17. #15
    1mounty's Avatar
    Jan 2017
    texas
    81
    43 Post(s)
    How to Find the Paint Code and Interior Trim Code on Your Volkswagen or Audi! :: East Coast Auto Salvage
    In that link there's two pics of a trunk in an 04 passat are those two bolts in the top left of the pic safe or good to use as a ground? If I sanded them to metal?
+ Reply to Thread
  1. run 8 gauge wire for a 980 watt amp?
    By hardrockfan in forum Wiring, Electrical and Installation Help
    Last Post: 09-02-2004, 04:31 PM
  2. Can I use 10 gauge wire for my power
    By howler2004 in forum Wiring, Electrical and Installation Help
    Last Post: 06-24-2004, 07:24 PM
  3. Gauge wire for Hifonics BX1500d
    By Derek123 in forum Amplifiers
    Last Post: 01-20-2004, 11:09 PM
  4. What gauge wire for a HU...or Five?
    By Heresy in forum Wiring, Electrical and Installation Help
    Last Post: 02-17-2003, 03:02 AM
