+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 36
Reload Thread: Amp decreases output when volume is high
    mrpep's Avatar
    mrpep is offline CarAudio.com Elite
    Apr 2014
    chicago
    1,112
    13
    3 Post(s)
    485 Post(s)
    I've had my setup for about a year now and no issues but now all of a sudden when I turn it up high the bass cuts off and as soon as I turn it back down the bass comes back in. I can't play bass at high volume. I have a alpine MRX-M100 amp , a second battery in parallel, 4 gage power, 1 10" sub 600 rms, kenwood HU. No big 3 just a plain set up. What could it be?? All working looks good and solid.
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,287
    41 Post(s)
    6054 Post(s)
    Re: Amp decreases output when volume is high
    Loose wire somewhere.....is the gain set right?
    Also....if the big 3 isn't done yet, as you stated it isn't, you could very well be starving your electrical,....not providing enough juice for the amp and thus shuts down at high volume.
    I highly suggest doing the big 3 1st before adding anything audio.....and this is a perfect example why.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
  3. Thanks audiobaun thanked for this post
  4. #3
    mrpep's Avatar
    Apr 2014
    chicago
    1,112
    13
    3 Post(s)
    485 Post(s)
    Weird thing is it's been running well for a year without big 3. How could it suddenly need it? Could it be ground ?
  5. #4
    Jul 2005
    WA
    14,287
    41 Post(s)
    6054 Post(s)
    Quote Originally Posted by mrpep View Post
    Have you cranked the volume before? Yes, I would check ground, every connection you can get to.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  6. #5
    mrpep's Avatar
    Apr 2014
    chicago
    1,112
    13
    3 Post(s)
    485 Post(s)
    Yeah I crank it all the time ... I'll check connections again tomorrow and report back.
  7. #6
    Louisiana_CRX's Avatar
    Louisiana_CRX is offline dem shoes......
    Aug 2006
    Piney Hills of Louisiana
    37,558
    24 Post(s)
    1893 Post(s)
    Could be bad rca's as the voltage increases from the deck the resistance decreases ..usually the result of older solder joints also the same could hold true to inputs on the amp
    Current 2010 Louisiana USACi State Records :
    Trunk 0-1000.................. 151.3
    StreetBeat 2................... 145.6
    Stock 1801-up.................153.8
    SuperStock 1801-up..........154.2
    Top three in 11 out of 26 power classes and Louisiana USACi Points Leader at 465
  8. #7
    trumpet's Avatar
    trumpet is offline CarAudio.com Veteran
    Jan 2011
    Grafton, ND
    37
    6,792
    43 Post(s)
    1859 Post(s)
    Monitor the voltage at the amplifier when the volume is turned up. Run the engine and also be sure the voltage at your secondary battery is close to the voltage at the primary battery.
    Rubyserv - I believe I can delivery joy every time you drive by the power of an incredible sound system. Barry Schanz, Owner
    Authorized dealer for CDT Audio - Shop With Us Now.
    FB | Rubyservsales
    IG | Rubyserv
  9. #8
    audiobaun's Avatar
    audiobaun is online now CarAudio.com Veteran
    Jun 2011
    Tx
    9,325
    27 Post(s)
    2171 Post(s)
    Corroded batter connections could be a possibility as well..Check you fuse connection also..Alt may be going bad,could have a bad battery in the mix..bad /corroded ground..Loose connections..Id start with all those.Id deff get that Big 3 done..Its worth the time and little money spent.As Ive always stated..It takes power to make power.Got to have supply for the demand
    2)American Bass VFL Mini Hybrid [email protected] Ea 4)American Bass XFL DVC 4ohm [email protected] Ft [email protected] CDT 6,5 HD6 Briax.,CDT CL60,CDT 25 tweets,Kicker KS25 tweets Autotek Mean Machine [email protected],Autotek BTX [email protected] AlterStarts Alt 255A/Dallas,Tx,2)Orileys Super Start AGM batts(1more coming)Cadence CCA 0ga on Big 6,AudioTechnix 0ga CCA Kicker Kq9 Eq,Eclipse CD3000(lookingfor upgrade)StingerPro Distro,3)XS Scorpian 8in Scroll Fans 1998 3dr Xcab Chevy(under construction,but operational)
  10. #9
    evilmonstertruk's Avatar
    evilmonstertruk is offline Premium Member evilmonstertruk is a Supporting Member of the forum!
    Sep 2014
    Virginia
    1,073
    3 Post(s)
    317 Post(s)
    Could be your battery just getting older. Can't take it as well as it used too. Like everyone said monitor voltage and see.. Happy Father's day btw
    Sent from my LG-H910 using Tapatalk
  11. #10
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is offline CHEAP A/F
    Jan 2017
    NC
    6,215
    18
    29 Post(s)
    2501 Post(s)
    yeah like they said could be batt or ground make sure it's not loos and no paint under it.. my amp did exct sme thing (but did it when i installed it) had sub volume to high on hu turned it down hasn't done it since..
    KENWOOD X301 HU, PRECISION POWER Phantom 1000 (@2ohm), pioneer 3003 12 1.63cfad ported, soundqubed 6.5" coax/doors, hp xover (hu), AGM starting batt...
    2 ohms rule
    Quote Originally Posted by Popwarhomie View Post
    Shit Ill sleep with you if you do that for me..
  12. #11
    sfall's Avatar
    sfall is offline Member
    Jun 2017
    NY, NY
    44
    4 Post(s)
    34 Post(s)
    Quote Originally Posted by Louisiana_CRX View Post
    That's not true. Voltage is inversely proportional to resistance. You may be thinking of current.
  13. #12
    mrpep's Avatar
    Apr 2014
    chicago
    1,112
    13
    3 Post(s)
    485 Post(s)
    With two batteries could it be both batteries ? Maybe ground needs cleaning and re tightening ? Kinda ***** but I have to fix
  14. #13
    Jan 2017
    NC
    6,215
    18
    29 Post(s)
    2501 Post(s)
    i added screw to my ground but it was still basically the gain
    2 ohms rule
  15. #14
    mrpep's Avatar
    Apr 2014
    chicago
    1,112
    13
    3 Post(s)
    485 Post(s)
    So I tested the batteries and the main engine battery is 14.4 volts and the second battery is 8.5 volts, it's also the one going to my amp which is also 8.5 volts. Shouldn't they both be 14.4 since they're parallel? Or is it possible that the second battery going to my amp had a poor ground. Or the battery is going dead. The battery is only 2 years old .
  16. #15
    Jul 2005
    WA
    14,287
    41 Post(s)
    6054 Post(s)
    8.5???!! I'm pretty sure that battery is dead. So you found the issue @adulbrich
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
+ Reply to Thread
  1. Amp protect when volume is turned up
    By Thorton0 in forum Wiring, Electrical and Installation Help
    Last Post: 04-19-2017, 07:15 PM
  2. my sub plays only when the volume is high
    By big alf in forum Wiring, Electrical and Installation Help
    Last Post: 12-26-2014, 05:05 PM
  3. Subwoofer Amp goes into protection when volume is high.
    By DB589 in forum Wiring, Electrical and Installation Help
    Last Post: 11-04-2011, 11:39 AM
  4. Replies: 4
    Last Post: 10-26-2007, 12:57 PM
  5. HELP! Cd player turns off when volume turned high!
    By aspen1284 in forum Wiring, Electrical and Installation Help
    Last Post: 03-10-2006, 03:24 PM
