+ Reply to Thread
Results 1 to 5 of 5
Reload Thread: Voltage drop question
    Based's Avatar
    Based is offline CarAudio.com Elite
    Mar 2014
    Louisiana
    883
    1 Post(s)
    417 Post(s)
    Hey I have a question about voltage drop. How comes voltage can drop from 14.4 to 13.5 for example, instead of just going from 14.4 to 12.6 instantly? If an alternator can only produce 100 amps, if you draw 90 amps will that make your voltage drop or do you have to be pulling 100 amps before seeing any drop at all?
    Based's Avatar
    Mar 2014
    Louisiana
    883
    1 Post(s)
    417 Post(s)
    Re: Voltage drop question
    Also what does this mean
    Taramps HD3k:
    Voltage Low Power: 10 , 5 VDC Voltage Maximum Supply: 16 VDC Consumption at Rest:. 1.70 Amp Maximum Consumption Musical @ 12.6 VDC 170 Amp. Maximum Consumption in Sinusoidal Signal @ 12.6 VDC: 340 Amp.
    Papermaker85's Avatar
    Papermaker85 is offline Better built than bought!
    Dec 2006
    New orleans LA
    32
    12,495
    68 Post(s)
    2 Thread(s)
    5100 Post(s)
    Quote Originally Posted by Based View Post
    you see the decrease in voltage because the alternator cannot instantaneously saturate the permanent magnets to produce the current o there is a lag that cause the voltage to drop so it can saturate it. its called ripple current. the current increases in order to deliver the power. you need a Capacitor to help smooth the ripple..
    those older caps aren't very great. with 3kw you could get away with 5 300F caps series..
    http://www.mouser.com/ProductDetail/...fLC2rGZw%3d%3d just a soldering gun and some 12ga wire between the caps and as large as you can going into and out of the caps
    Insidious Audio
    But you at 2ohm it's all good!
    yeah i told wife guy on here pm'ed me wanting to buy my amp she said tell him it not fs (cause she knows i'll spend more $ on new one) and told her i wanted d2 sub for bday next week she said tell ya'll i'm to old to go down to 1ohm lol..
    10k-watts's Avatar
    10k-watts is offline Member
    Aug 2016
    Hampton, VA
    40
    95
    21 Post(s)
    Quote Originally Posted by papermaker View Post
    Capacitor is any option... most add another battery and a high output alt
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    BSchrowang's Avatar
    BSchrowang is offline Budget Builder
    Apr 2016
    Peru Illinois
    491
    198 Post(s)
    Taramps HD3k:
    With music playing it pulls 170 amps, on a burp it pulls 340 amps.
    2010 Ford Crown Victoria Police Interceptor:
    2 American Bass XFL 15"s
    8 cubic foot box
    Taramps HD 3000 at 1 ohm
    Soundbox 1/0 CCA wire
    200 amp police alternator
+ Reply to Thread
