Results 1 to 7 of 7
Reload Thread: Do I need a HO alt or will big 3 surfice?
    monkkid981's Avatar
    monkkid981 is offline Junior Member
    Apr 2017
    Grand Rapids MI
    4 Post(s)
    So I recently bought two Pioneer TS-W3003D4's, which I had planned on running at 600 RMS each @ 1 OHM off of a GM-D9601 at 1200 watts. I am still fairly new to the whole car audio scene, so I made sure to do a crap ton of research before making my purchases, but I didn't even consider my alt..
    I currently drive a 2000 Malibu, running a 105 A alt. This car isn't exactly worth putting more parts and money into than I really need, and I'd rather not spend a few hundred on an HO alt for a car I won't have for longer than another year or two.
    Would I be able to get away with a 105 A alt running a 1200 watt system with the big 3 upgrade?
    I realize this is probably a stupid question, but I'm honestly stumped. :/
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,059
    40 Post(s)
    5947 Post(s)
    Re: Do I need a HO alt or will big 3 surfice?
    ****, thought this was from the other thread....lol.
    Doing the big 3 alone should be fine. Your not running much power.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
    monkkid981's Avatar
    Apr 2017
    Grand Rapids MI
    4 Post(s)
    [/COLOR]
    Even on a stock alt? I'm not 100% sure it's 105 amp, it could honestly be less.
    Jul 2005
    WA
    14,059
    40 Post(s)
    5947 Post(s)
    Quote Originally Posted by monkkid981 View Post
    [/COLOR]
    Just because you have a 1200 watt amp doesn't mean your gonna run that much power. You'll never see that much. Maybe 75% of it.
    Just don't be stupid and distort the hell out of things. Set gain properly and should be ok.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    tymoto21's Avatar
    tymoto21 is online now CarAudio.com Elite
    Apr 2008
    wisconsin
    927
    1 Post(s)
    258 Post(s)
    i would replace your front battery with a decent agm and do the big 3. you will be fine
    audiobaun's Avatar
    audiobaun is offline CarAudio.com Veteran
    Jun 2011
    Tx
    9,245
    25 Post(s)
    2152 Post(s)
    [/COLOR]
    My Honda CRV I believe is a 90 amp alt/stock if that..I have an agm under the hood with another in rear tire well and grounded with [email protected] axle big3 in 2ga,with ELD Bypass thanks to keep_hope_alive,Running 1500-1750 [email protected] on substage,2 ohms up front of approx 125 rms x2, and 20x2 on rears,,doesnt feel taxed at all/does just fine all day long.As stated..You should be fine with at the least a good AGM batt under the hood/and decent supply wiring to the amp/amps, and an excellent ground for your power needs and you should be just fine with Big3
    2)American Bass VFL Mini Hybrid [email protected] Ea 4)American Bass XFL DVC 4ohm [email protected] Ft [email protected] CDT 6,5 HD6 Briax.,CDT CL60,CDT 25 tweets,Kicker KS25 tweets Autotek Mean Machine [email protected],Autotek BTX [email protected] AlterStarts Alt 255A/Dallas,Tx,2)Orileys Super Start AGM batts(1more coming)Cadence CCA 0ga on Big 6,AudioTechnix 0ga CCA Kicker Kq9 Eq,Eclipse CD3000(lookingfor upgrade)StingerPro Distro,3)XS Scorpian 8in Scroll Fans 1998 3dr Xcab Chevy(under construction,but operational)
    ChaseinBass's Avatar
    ChaseinBass is offline CarAudio.com Elite
    Jul 2013
    Calif
    1,963
    4 Post(s)
    933 Post(s)
    LOL me too i was getting very confused !
    Pioneer Prs80, Rockford DSR1, Taramps 15000 HD, two 18 team FI , 4x PPI900.4s, Massive Audio CT2 tweeters, CDT 6.5 mids and 2 pr Anarchy midbass, 3 group31 juice box batterys , lots of 0 gauge and NRG aluminum hardware, Triple 300 amp CES hairpins, 4 Banks of 6 ultra caps.
