+ Reply to Thread
Page 1 of 8 1 2 3 4 5 6 7 8 LastLast
Results 1 to 15 of 109
Reload Thread: Do I really need an H/O alternator for 2 12" Orion hcca 2500 watt rms speakers?
    JonM's Avatar
    JonM is offline Member
    Jan 2017
    Columbus Ohio
    142
    77 Post(s)
    Long story short: I'm running 2 Orion HCCAs 12" black coil on Orion hcca 8k amp at 2 ohms (half power) built into a custom made box for my trunk of a 99 camery. I'm running 2 XS power 3100d batteries with 4 OTT power wire and 4OTT grounded to trunk. No big three upgrade. I had a 300 amp alt put in which went up to 19 volts and blew the starter fuse about 3 minutes after I got the car back from the shop. They took it out and reinstalled the original alt. I returned the alt for another from Ohio Genarator and they said the alt was fine but put in a new regulator anyway. Tom recommended the big three upgrade and also the ground from the rear batteries should be up front with at least a 2 Ott ground wire because when grounded to the rear chassis, it's like a 4 gauge wire going up to the front when a 2 ott is needed. Do I really need this? I've been driving around for the past 2 months with no big three upgrade and a stock alt and my voltage hasn't gone below 11.9. I did the big three upgrade and in about 2-4 minutes the voltage went from 14.4 to 11.5 so I disconnected it.
    My 3 questions:
    Do I really need the big three upgrade and a H/O alt?
    If I get the 300 amp alt re installed will my voltage stay at 14.4 with the subs at full tilt?
    And do I really need a ground going from the rear up to the front?
    This is a daily driver car. Thanks guys
    Chris McNeeley's Avatar
    Chris McNeeley is offline Red Light Ear Rapist
    Jul 2016
    Toledo, ohio
    29
    205
    116 Post(s)
    Re: Do I really need an H/O alternator for 2 12" Orion hcca 2500 watt rms speakers?
    Yup
    Maybe
    Yup
    I drive mine daily. You shop at afflication audio in columbus?
    2013 Subaru Legacy B-Pillar
    4 Crossfire v4 18s
    2 Crossfire 8x's @.33
    1 Crescendo C.2 SQ with a Ampere JM1
    3 SINGER 270's + Limitless 100ah 16v + 25ah 12v
    JonM's Avatar
    Jan 2017
    Columbus Ohio
    142
    77 Post(s)
    Yeah, how'd you know?
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    12,704
    33 Post(s)
    5363 Post(s)
    Big 3 a must.
    A HO alt? Not necessarily but would help later on down the road.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
    Austin175's Avatar
    Austin175 is offline CarAudio.com Elite
    Jan 2010
    Burlington,Ia
    855
    2 Post(s)
    231 Post(s)
    Yes do the the big 3
    The H/O alt will help so yes
    An I would it can't really hurt anything
    Even running your 8k at half power I would switch all your wire to 1/0 car audio wire or 2/0 welding wire, think of it like this:
    Your electrical is pumping water on a pipe you have a steady flow but not a lot of water by upgrading the size of your alt & wire your electrical could pump more water faster with the same steady flow bc to me dropping to that low of voltage is not good that's under resting voltage.
    2003 Lancer ES
    H/U- Pioneer 880prs
    Mids/Highs- ????
    Sub Stage- DC Xlm2 12s(soon to be FI BTL Neo's)
    Mids/Highs Amp- Crescendo 1000C4
    Sub Amp- 2 Ampere 3800.1s
    Wiring- Welding 2/0, Welding 4g & Welding 8g
    Alt-????
    Batteries- 4 Xs Xp3ks & 1 Lithium
    Enclosure- 3.33Cf tuned to 34hrtz
    Austin175's Avatar
    Jan 2010
    Burlington,Ia
    855
    2 Post(s)
    231 Post(s)
    Also on that H/O alt was it external or internally regulated? If external you would need to set it to the voltage you want it to charge at
    2003 Lancer ES
    H/U- Pioneer 880prs
    Mids/Highs- ????
    Alt-????
    ChaseinBass's Avatar
    ChaseinBass is online now CarAudio.com Elite
    Jul 2013
    Calif
    1,895
    4 Post(s)
    898 Post(s)
    Quote Originally Posted by Austin175 View Post
    So you did big three upgrade and voltage went from 14 volts to 11 volts ?? I dont even know how that could be possible ? Big three upgrade is just reinforcing your existing grounds ?
    answers to questions
    yes
    no ( could be possible but highly doubtful but I would guestimate high 12v at full tilt )
    yes
    Pioneer Prs80, Rockford DSR1, Taramps 15000 HD, two 18 team FI , 4 PPI900.4s, Massive Audio CT2 tweeters, Faitalpro neo 3" mids and 2 pr Anarchy midbass, 3 group31 juicebox batterys , lots of 0 gauge and NRG aluminum hardware, Triple alts, 4 Banks of maxwell ultra caps.
    Jul 2016
    Toledo, ohio
    29
    205
    116 Post(s)
    Quote Originally Posted by JonM View Post
    Because i know jason the owner and theyre the only authorized dealer for them around there and your car sounds like their install style.
    4 Crossfire v4 18s
  9. #9
    JonM's Avatar
    Jan 2017
    Columbus Ohio
    142
    77 Post(s)
    Quote Originally Posted by Chris McNeeley View Post
    He's a good guy, he was able to work with me on what I wanted when a couple of other shops wouldn't.
  10. #10
    JonM's Avatar
    Jan 2017
    Columbus Ohio
    142
    77 Post(s)
    Quote Originally Posted by ChaseinBass View Post
    yes
    yes
    The voltage drop is much faster with the big three upgrade. With out the upgrade the drop was much more gradual, from work to home the drive is around 15 minutes and the voltage is still around 12.3 when I get home. with the stereo turned up all he way the entire time. With the upgrade I'll be just getting on the freeway and it'll be at 11.5 and I'll have to turn it down. It's worse when I'm driving on side streets. With out the upgrade it stays above 12 volts and has only once went to 11.9 volts. With the upgrade and the alt installed I'm hoping to keep it at 14.4 volts. I lose 1670 watts when it hits 12.5 volts and that's a noticeable difference in sound and pressure. That's why I'm trying to keep it at 14.4 volts.
  11. #11
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is online now NOT TO OLD TO BASS
    Jan 2017
    NC
    4,718
    17
    23 Post(s)
    1904 Post(s)
    sure u sanded the paint off the grounding points well? i don't understand how volts got worse in anyway..
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, custom 2.11 cf ad ported tuned @ 36hz 30.375 port area, soundqubed 6.5" coax, hp xover (hu), AGM starting batt... FU 750 destroying my spoiler https://www.youtube.com/watch?v=joeeCIZJpUs pioneer 3003 videos https://www.youtube.com/watch?v=rTcgVGvuFX8 https://www.youtube.com/watch?v=WI4yGDqN27g
  12. #12
    MrGreen83's Avatar
    MrGreen83 is online now Member
    Jun 2015
    Richmond, VA
    34
    38
    14 Post(s)
    Doing a Big 3 upgrade on an existing alternator isn't helping anything. The Big 3 allows more current to flow....so all u did was allow ur equipment to pull more current from ur existing factory alternator. Hence why the voltage is dropping lower now.
    U FIRST need an alternator that can keep up with the power demands......then the Big 3 is beneficial. They work together as a team.
  13. Likes beak81champ, ChaseinBass liked this post
    Dislikes Hertz Mafia disliked this post
  14. #13
    JonM's Avatar
    Jan 2017
    Columbus Ohio
    142
    77 Post(s)
    Quote Originally Posted by MrGreen83 View Post
    Thanks! That's what I was wondering.
  15. #14
    Jul 2005
    WA
    12,704
    33 Post(s)
    5363 Post(s)
    I disagree. Upgrading the big 3 is so much cheaper than buy an alt...which can be upwords of 700 bucks new for a 270-300 amperage one, and depending upon who(DC Audio, Singer, etc).
    He did mention he has extra batteries to be able to keep up with the electrical demand.
    There's absolutely nothing wrong with replacing the charging wires 1st. Then at a later time, when money allows, then I would say get a HO alt.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  16. Likes ChaseinBass, Hertz Mafia liked this post
  17. #15
    MrGreen83's Avatar
    Jun 2015
    Richmond, VA
    34
    38
    14 Post(s)
    I missed the 2 batteries part. But obviously they aren't helping
+ Reply to Thread
