+ Reply to Thread
Page 4 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 46 to 60 of 109
Reload Thread: Do I really need an H/O alternator for 2 12" Orion hcca 2500 watt rms speakers?
  1. #46
    JonM's Avatar
    JonM is offline Member
    Jan 2017
    Columbus Ohio
    142
    77 Post(s)
    Re: Do I really need an H/O alternator for 2 12" Orion hcca 2500 watt rms speakers?
    I know, but I can't see or hear anyone's systems on here and I want to listen to other systems to get new ideas and compare mine.
  2. #47
    Hertz Mafia's Avatar
    Hertz Mafia is offline FEATHER RUFFLER
    Jul 2016
    Michigan
    1,680
    35 Post(s)
    1012 Post(s)
    Quote Originally Posted by JonM View Post
    There is a lot of bassheads in Ohio and a lot in Michigan. A lot of shows around here too. Go to a show and get some demos
  3. #48
    honkyg's Avatar
    honkyg is offline uncle ofay da kracka
    Jan 2009
    under your bed and in your nightmares
    459
    1 Post(s)
    211 Post(s)
    1; yes x2
    the big three is a must-do for all installations, regardless of the current draw. this allows your current to have a larger path of least resistance to travel among the completed circuit in sustaining an even draw to and from all components either feeding or consuming current.
    a 99 camry stock alternator is 90 amp max for the 2.2l and 3.0l v6. well below the amount necessary to supply current to the stock electrical components needed to keep the car running, power the acoutriments, AND supply a heavy draw of 700 amps (orion recommended spec) to just a mono amplifier while also taking into account the two rear batts constantly needing to stay afloat after deep dwells. the ohio gen alternator's regulator was most likely not set correctly (too high), or the current draw it saw allowed it to kick up into the 18v range, idk tbh, never dealt with ohio gen.
    2; not likely. as already stated, that amplifier draws 700 amps. it will draw 700 amps at 2 ohm just as it will draw 700 amps at 1 ohm. halving the load resistance doubles the wattage, but amperage is a constant factor applied in this electrical formula.
    3; always. the best analogy i can use, as i have for many years now,... is drinking a milkshake. do you prefer the big dumb straws from burger king, or do you prefer using a straw from a capri sun pouch or coffee stir?
    there is no such thing as 'too much' when it comes to main power wiring in a dc circuit... not imo.
    i believe what is happening when you have the big three connected, is you are allowing the batteries in back to charge just that much quicker (greater path of least resistance to the alt/front batt) after the amp has been relying on them to supply the bulk of the current during extended play at high volume, probably in the 12v range, which is why you havent smoked the amp yet. without the big three, it seems your batts in back are being taxed first and your power circuit supplying them is not allowing them to regain full capacity, thus slowly feeding off the front batt and alternator as a crutch with such a minimal ground.
    i think im gonna go sit on the toilet and take a big papermaker where it belongs.
    D.I.L.L.I.G.A.F.?
  4. #49
    LosIsATool's Avatar
    LosIsATool is offline CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,645
    106 Post(s)
    7465 Post(s)
    Quote Originally Posted by honkyg View Post
    1; yes x2
    2. No it won't. Less power requires less amperage. And higher efficiency.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  5. #50
    honkyg's Avatar
    Jan 2009
    459
    1 Post(s)
    211 Post(s)
    Quote Originally Posted by LosIsATool View Post
    huh?
    ohms law doesnt change, bro.
    14.4vdc x 700a x 1 ohm = 10080watts x .8 (typical class d 80% efficiency) ~8065w~ but we'll just go with a nice rounded 8k
    rail volt-amperes needed;
    square root of: power (watt) multiplied by resistance (ohm)
    2000 x 4 = 8000
    4000 x 2 = 8000
    8000 x 1 = 8000
    sq rt of 8000 = 89.4427va
    this is the rail volt-amperes needed to sustain 8000w at 1 ohm driven cleanly, or 4k @ 2, 2k @4,.. etc, etc.
    the rail va remains constant regardless of load resistance, thus, the current needed to supply said volt-amperes from the dc input will also remain constant unless dc input voltage or gain changes. more input voltage applied requires less current to attain rail voltage and just the inverse. lessening the gain will require less current as you are dropping the output power.
    D.I.L.L.I.G.A.F.?
  6. #51
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,645
    106 Post(s)
    7465 Post(s)
    huh?
    2000 x 4 = 8000
    4000 x 2 = 8000
    8000 x 1 = 8000
    A 8k at 1ohm is not a 8k at 2ohm.
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  7. #52
    JonM's Avatar
    Jan 2017
    Columbus Ohio
    142
    77 Post(s)
    I think what he's saying is 8k at 1 ohm has the same resistance as 4K at 2 ohm. So 4K at 2 ohm the resistance is twice that of 8k at 1 ohm, but because it's half the wattage of the 8k the resistance is the same as the 8k so the draw on the electrical is going to be the same.
  8. #53
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    12,676
    33 Post(s)
    5343 Post(s)
    JL Audio has their amps as so. Any impedance, same wattage. Which I don't like.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
  9. #54
    JonM's Avatar
    Jan 2017
    Columbus Ohio
    142
    77 Post(s)
    1; yes x2
    Thanks man, this helps out a lot! I had no idea what the draw was. My idea was to play the stereo off the batteries. I thought I'd be good since I don't turn it up loud for long periods of time. I was going to use the voltmeter as a gauge to know when to shut the subs off(below 11.5), and let the batteries charge back up. The batteries combined have 210 amp hours and a total of 10,000 amps with an additional 90 AH from the alt for a total of 310 AH. Why wont this work for running a 5k system? (I've got an audiopipe 2k amp for mids and highs which is really 100watts x4)
  10. #55
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,645
    106 Post(s)
    7465 Post(s)
    Yes I've had a few. They are tightly regulated. But ******* current hogs
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  11. #56
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,645
    106 Post(s)
    7465 Post(s)
    Lol what?
    No. 8k at whatever ohm will need roughly 800 amps of current
    4K at whatever ohm will need roughly 400 amps of current.
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  12. #57
    JonM's Avatar
    Jan 2017
    Columbus Ohio
    142
    77 Post(s)
    Lol what?
    But ohms = resistance, the higher the resistance, the harder its going to be for the amp to draw the power
  13. #58
    cfox10's Avatar
    cfox10 is offline Rock the house.
    Mar 2011
    Tillamook, Oregon
    1,956
    3 Post(s)
    811 Post(s)
    Firstly, a rough estimate is 100a of current draw for every 1k in power. Obviously this doesn't factor in loss/heat etc.
    It's MUCH more efficient for an amp to run at say 4ohm than it is at 1ohm because of resistance.
    An 8k amp @ 1ohm is going to pull far more amperes than an 8k amp @ 4ohm. It is NOT the same, that is completely inaccurate.
    Example: https://www.youtube.com/watch?v=DMBV0dVAtUo
    In this dyno, you can see at 4ohm the amp pulls 150a of current and at 1ohm it draws 389a of current.
  14. Likes ChaseinBass liked this post
  15. #59
    ChaseinBass's Avatar
    ChaseinBass is offline CarAudio.com Elite
    Jul 2013
    Calif
    1,894
    4 Post(s)
    897 Post(s)
    Quote Originally Posted by cfox10 View Post
    But is that because 8k amp at 4 ohms is really a 2k amp
    Pioneer Prs80, Rockford DSR1, Taramps 15000 HD, two 18 team FI , 4 PPI900.4s, Massive Audio CT2 tweeters, Faitalpro neo 3" mids and 2 pr Anarchy midbass, 3 group31 juicebox batterys , lots of 0 gauge and NRG aluminum hardware, Triple alts, 4 Banks of maxwell ultra caps.
  16. #60
    los33's Avatar
    los33 is offline Car Audio G
    Apr 2014
    Houston, TX
    3,383
    24 Post(s)
    2151 Post(s)
    Quote Originally Posted by ChaseinBass View Post
    higher ohm rating = less heat
    Less heat = better efficiency
    The lower the ohm rating the dirtier the amperage flow gets so it pulls more current to compensate for the loss of amperage in the current.
    The better efficiency (higher ohm) has less amperage loss making no need to pull more the needed.
    Sent from my Z970 using Tapatalk
+ Reply to Thread
