Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 39
Reload Thread: Ripped off by installer?
    ATA86's Avatar
    ATA86 is offline Junior Member
    Feb 2017
    Uk
    1 Post(s)
    So after having a system "professionally" installed I find that it has constant noise in (changes frequency depending on speed of the engine) and has bags of excess wire etc. I took the door panels off because both rear doors had stopped unlocking to find this: https://imgur.com/a/sDda8
    They sold me sheets and sheets of sound deadening stuff, am I right in assuming that the random patches they've stuck on are good for pretty much nothing and that they probably put the rest back into their stock?
    Thanks
    JohnKuthe's Avatar
    JohnKuthe is offline CarAudio.com Veteran
    Sep 2016
    Missouri
    2,057
    13 Post(s)
    1194 Post(s)
    Re: Ripped off by installer?
    Quote Originally Posted by ATA86 View Post
    Thanks
    Pretty shoddy work! I had my installer guy put all the Damplifier Pro and almost all the Luxury Liner Pro I bought in and some BQuiet I'd bought before I bought the Second Skin stuff on/in! All over the place. Little patches of sound deadener is better than nothing, but not nearly as good as covering the panels to be deadened as completely as possible.
    And those wiring jobs need some terminals on the wires!! Or at least the strands of wire twisted and tinned, then properly wrapped around the screw.
    John Kuthe...
    John Kuthe...
    2006 Grand Caravan "Baby II"
    Alpine CDE-153BT HU
    Alpine PXA-H800 DSP
    Alpine PDX-V9 main amp
    Alpine PDR-V75 secondary amp
    4 Alpine SPR-69 6x9" midrange
    2 PHD 5.1 AF 5.25" drivers w/ separate tweeters and passive crossovers with plans of going full active!
    JL Audio 12TW3-D4 400W TW3 Thin-Line Series 12" Dual 4 ohm Subwoofer set to 2 Ohms
    Damplifier Pro, BQuiet and Luxury Liner Pro sound deadening, lots!
    BSchrowang's Avatar
    BSchrowang is offline Budget Builder
    Apr 2016
    Peru Illinois
    491
    198 Post(s)
    Sounds like you took all 8 inches dude. But seriously thats a sad excuse for an installer to leave clumps of wire. Small patches of sound deadening acutually do work to reduce vibrations but they didnt use nearly as much as you paid. I would probably look to see if there is anything else wrong then go back and start asking questions.
    2010 Ford Crown Victoria Police Interceptor:
    2 American Bass XFL 15"s
    8 cubic foot box
    Taramps HD 3000 at 1 ohm
    Soundbox 1/0 CCA wire
    200 amp police alternator
    JohnKuthe's Avatar
    Sep 2016
    Missouri
    2,057
    13 Post(s)
    1194 Post(s)
    Quote Originally Posted by BSchrowang View Post
    Well, we're not looking at the outer door's inner sheet metal surface either, behind what looks like a plastic pretty complete inner door panel cover. That's where I had my installer guy put a lot of Damplifier Pro.
    John Kuthe...
    Alpine CDE-153BT HU
    Alpine PXA-H800 DSP
    lsvtec's Avatar
    lsvtec is offline Junior Member
    Feb 2017
    CA
    25
    7 Post(s)
    Wow sorry about that bad install. That really *****.
    JohnKuthe's Avatar
    Sep 2016
    Missouri
    2,057
    13 Post(s)
    1194 Post(s)
    Quote Originally Posted by lsvtec View Post
    And that is why I'm glad I worked WITH my installer guy the entire time I had him working on my install. I was watching everything he did. Everything!
    John Kuthe...
    Alpine CDE-153BT HU
    Alpine PXA-H800 DSP
    k5james's Avatar
    k5james is offline Senior VIP Member
    Jul 2005
    Yuma, AZ
    283
    1 Post(s)
    112 Post(s)
    Yeah, that's rough man. The deadener is fine. Covering the entire panels is just waiting deadener but I'm sure you paid for more than they put on. I'd leave the panels off and take it back to them and say "wtf" and try and get your money back for at least the deadener.
    Next time do it yourself. If you can take remove the panels you can do your own install.
    2006 Dodge Ram 2500 Mega Cab 4x4
    HU: CD7200MKII
    Front Stage: SI TM25/ID X-69
    Front Stage Amp: PG Ti21000.4
    Sub Stage: Sundown SD-3 12 x2 (soon to be 3 SA-8v3s in a CSCStang TLine)
    Sub Stage Amp: PG Ti22000.1
    EnvoyDenalii's Avatar
    EnvoyDenalii is offline B A N N E D
    Dec 2016
    Cheese State Go Packers!!
    153
    1 Post(s)
    81 Post(s)
    Quote Originally Posted by JohnKuthe View Post
    John Kuthe...
    john stfu, u posted 3 times in this thread and just talked about ur s.hit pedo van
    and yes op u got ripped off sorry to say
  9. Thanks erod856 thanked for this post
    Dislikes JohnKuthe, BMayes36 disliked this post
  10. #9
    JohnKuthe's Avatar
    Sep 2016
    Missouri
    2,057
    13 Post(s)
    1194 Post(s)
    Quote Originally Posted by k5james View Post
    And again that''s why I'm glad I was there to watch and consult with my installer guy for everything he did for me. I actually wanted him to install panel deadener to the inside surface of the inner door sheet metal also, but relented on that as long as he covered the outside surface as completely as possible/feasible. Which he did! I was sorry I hadn't bought more Damplifier Pro because it's better than the BQuiet stuff I;d purchased, but the BQuiet stuff was better than nothing.
    I really took a risk when I took Baby II to Custom Sounds and they took Baby II into their sequestered shop area and did all the work they did for me.
    John Kuithe...
    Alpine CDE-153BT HU
    Alpine PXA-H800 DSP
  11. Dislikes erod856 disliked this post
  12. #10
    BMayes36's Avatar
    BMayes36 is offline Senior VIP Member
    Jul 2016
    NYC
    229
    106 Post(s)
    Quote Originally Posted by EnvoyDenalii View Post
    You're constantly post dumping in the classifieds. Don't think you should be telling anyone to stfu until you follow your own advice.
  13. Likes JohnKuthe liked this post
  14. #11
    Dec 2016
    153
    1 Post(s)
    81 Post(s)
    Quote Originally Posted by BMayes36 View Post
    dont worry about me homie, worry about urself an apparently kuthe bc u feel the need to stick up for that chomo. i bet u are the infamous "installer guy" lol
  15. Likes erod856 liked this post
    Dislikes thehardknoxlife disliked this post
  16. #12
    Austin175's Avatar
    Austin175 is offline CarAudio.com Elite
    Jan 2010
    Burlington,Ia
    872
    2 Post(s)
    242 Post(s)
    John Kuthe...
    Watching an doing the work are two different things apparently you don't know that because you didn't do any of it you just watched.
    2003 Lancer ES
    H/U- Pioneer 80Prs
    Mids/Highs- ????
    Sub Stage- DC Xlm2 12s(soon to be FI BTL Neo's)
    Mids/Highs Amp- Crescendo 1000C4
    Sub Amp- 2 Ampere 3800.1s
    Wiring- Welding 2/0, Welding 4g & Welding 8g
    Alt-Singer 270A
    Batteries- 4 Xs Xp3ks & 1 Lithium
    Enclosure- 3.33Cf tuned to 34hrtz
  17. #13
    BMayes36's Avatar
    Jul 2016
    NYC
    229
    106 Post(s)
    You're apparently the new village idiot.
  18. #14
    JohnKuthe's Avatar
    Sep 2016
    Missouri
    2,057
    13 Post(s)
    1194 Post(s)
    Quote Originally Posted by Austin175 View Post
    I watched and consulted with my installer guy on everything he did, save for the exact way he wanted to wire my amps which was probably my mistake. But I let him do the wiring the way HE wanted and it works, just maybe not as good as it could.
    I know exactly how I'm gonna change the wiring when I decide to go full active with my DSP! Then I will have to learn how to configure my DSP myself.
    John Kuthe...
    Alpine CDE-153BT HU
    Alpine PXA-H800 DSP
  19. Dislikes erod856 disliked this post
  20. #15
    Dec 2016
    153
    1 Post(s)
    81 Post(s)
    what do u think ur doing now? ur jacking dudes thread to run ur mouth. what have u done to answer the op's question? so do as i say not as i do right? smh
