Results 1 to 7 of 7
Reload Thread: Box Terminal Kits
    lsvtec's Avatar
    lsvtec is offline Junior Member
    Feb 2017
    CA
    25
    7 Post(s)
    Icon14 Box Terminal Kits
    Has anyone used these box terminals before? Opinions? How are you guys wiring them?
    Finally getting my foot back into the game and there are so much new products out there.. Trying to re-educate myself and get familiarized with these new products.
    Attached Thumbnails Attached Thumbnails Box Terminal Kits-terminals.jpg   Box Terminal Kits-terminal.jpg
    10k-watts's Avatar
    10k-watts is offline Member
    Aug 2016
    Hampton, VA
    40
    95
    21 Post(s)
    Re: Box Terminal Kits
    Same concept as SMD...just not as flashy...should work fine
    Mr. 10K
  3. Thanks lsvtec thanked for this post
  4. #3
    10k-watts's Avatar
    Aug 2016
    Hampton, VA
    40
    95
    21 Post(s)
    Where did u find those
    Mr. 10K
  5. #4
    lsvtec's Avatar
    Feb 2017
    CA
    25
    7 Post(s)
    Quote Originally Posted by 10k-watts View Post
    Mr. 10K
    https://jims-machineworkx.myshopify..../box-terminals
    Do u know what the purpose of this is?
  6. #5
    CSCStang's Avatar
    CSCStang is offline Enclosurist
    Mar 2014
    OC, Ca
    2,971
    411 Post(s)
    2 Thread(s)
    973 Post(s)
    Quote Originally Posted by lsvtec View Post
    So you can change the sub wiring outside the box. Ex....4 ohm load to 1 ohm load, without taking the subs out of the enclosure.
    Sent from my SM-N920V using Tapatalk
    DAILY '12 Mustang AVH2700BS
    RS28F/682.9CF/PWX 8....ppi900.4/gmd5602 3 way active
    2 HDS208 TLINE @44hz...xtr2200.1
    BEATER '99 Silverado xcab AVH3600BHS
    X comps....c1c/PWX 8".....ppi600.2
    2 XFL 1544 TLINE @30hz....FSD3800.1
    DC 300 powerhouse....big 3 in both with 2/0 weld
    Check out my past builds at Cscstang customs on fb or cscstang_customs ig.
    I'll be back to building eventually....
  7. Thanks lsvtec thanked for this post
    Likes lsvtec liked this post
  8. #6
    lsvtec's Avatar
    Feb 2017
    CA
    25
    7 Post(s)
    Thanks this makes more sense now.
  9. #7
    10k-watts's Avatar
    Aug 2016
    Hampton, VA
    40
    95
    21 Post(s)
    That and to have a better connection than what u can get on a prefab box...
    Mr. 10K
Tags for this Thread
