+ Reply to Thread
Results 1 to 5 of 5
Reload Thread: Did something wrong when installing new stereo 2003 in Mitsubishi Galant ES Infinity
    Freshesh's Avatar
    Freshesh is offline Junior Member
    Feb 2017
    Michigan
    So this is a used a car I bought from a private seller almost a year ago. Recently the factory stereo started failing so I decided to install a new one and tried doing it myself. I got the correct harness for the sound system (it has the infinity setup) and put it all together last night.
    There were two antenna wires and I couldn't use the smaller wire so I just wrapped it in electrical tape and let it be. There was a long black grounding wire that came attached the new stereo's harness and I attached that underneath a bolt that I think is just attached to the chassis so I'm hoping that's not where the trouble is from. Anyway I had the negative terminal disconnected while I was doing all this.
    I reconnect it and everything is working great. The car starts running when I turn the key and the new radio is playing music. Then the lights start to go dim and everything dies.
    I go to the battery and find that the negative terminal had become detached while I had the car running. It was a little loose to begin with so I wasn't surprised. I reattach it and try to start the car again but it won't start. Just makes this clicking noise from the area around the ecu and fuses.
    Also the headlights are flashing and if I open a door the door ajar light on the instrument panel starts to flash as well as the dome the car. When I turn the key to the on position some of the instrument panel the way nothing happens. When I turn the key to try and start it there is absolutely nothing. No sound, no cranking, no anything.
    At this point I'm wondering if I activated the electronics immobilizer? Or some kind of at this point alarm system? I don't think the battery is dead because when I first reconnect the battery the headlights will come on. They seem strong and after I open the door or start messing with it is when they start flashing. I'm bringing it in to a repair shop tomorrow but there are no Mitsubishi dealers anywhere near me so I'm not able to get it into a dealer.
    Also I cleaned the negative battery terminal and post and attached a shim post so it's not loose anymore and that didn't change anything.
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    12,790
    33 Post(s)
    5397 Post(s)
    Re: Did something wrong when installing new stereo 2003 in Mitsubishi Galant ES Infin
    Sounds like a dead battery.
    ---------- Post added at 10:34 PM ---------- Previous post was at 10:33 PM ----------
    Just noticed your in MI
    @Hertz Mafia is in MI as well. He can help ya out.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
    budahbuddy803's Avatar
    budahbuddy803 is offline CarAudio.com Veteran
    Feb 2006
    Brunswick, GA
    4,866
    14
    32 Post(s)
    I agree with Tahoe.... your battery is dead. Put it on a charge and make sure your battery terminals are tight.
    Vehicle: 2009 Pontiac G5
    Head Unit: Pioneer AVH-X3700BHS
    Highs: Image Dynamics XS28
    Mids: 6-1/2" Poly Cone Midbass Woofer 4 Ohm
    Subwoofer: Image Dynamics IDQ12d4v4
    Amplifier: Kenwood XR 900-5
    Battery: Kinetik HC800BLU
    Freshesh's Avatar
    Feb 2017
    Michigan
    Ok, I'm hoping that's what it was. I'll see what the guys at the repair shop find, they said they can work on it today.
    Hertz Mafia's Avatar
    Hertz Mafia is offline FEATHER RUFFLER
    Jul 2016
    Michigan
    1,692
    35 Post(s)
    1016 Post(s)
    Do u have a dmm to check battery voltage? My guess is the battery has enough power to turn headlights on but not enough to start the vehicle. Prly just need to charge the battery and good to go.
  6. Likes michaellane liked this post
+ Reply to Thread
