Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 35
Reload Thread: H/O alternator questions
  1. #16
    ashren315's Avatar
    ashren315 is offline Senior VIP Member
    Aug 2016
    Canton, MS
    174
    2 Post(s)
    83 Post(s)
    Re: H/O alternator questions
    Was John also the second gunman in the grassy knoll?
  2. #17
    Cm_low's Avatar
    Cm_low is offline Member
    Dec 2016
    Arnold, MO
    114
    30 Post(s)
    Another thing I was curious about is running 2 alternators, benefits/downfalls? Besides finding or building a custom dual alternator bracket, would running 2 stock alternators be a viable option or would it just be a better option all together to run 1 h/o alternator?
  3. #18
    ashren315's Avatar
    Aug 2016
    Canton, MS
    174
    2 Post(s)
    83 Post(s)
    Running 2 would slightly lower your horsepower some.
  4. #19
    Cm_low's Avatar
    Dec 2016
    Arnold, MO
    114
    30 Post(s)
    Yea I looked around online to see if I can figure out if my alternator is interchangeable with other vehicles bur didn't have much luck. I will keep searching though and make a couple calls around to see what u can find out. Just wasnt sure if there was some like common knowledge stuff out there I didn't know about when it comes to aftermarket h/o alternators. Like if there was a base model that was used and they configured it to match bolt patterns, belt types and such. Thanks for the info guys I do appreciate your help.
  5. #20
    Cm_low's Avatar
    Dec 2016
    Arnold, MO
    114
    30 Post(s)
    Quote Originally Posted by ashren315 View Post
    Haha that would **** on a 1.8L 4 cylinder cruze. I know the cruze also has some different type of charging system. It is wired into the engine management to where it charges during deceleration or something like that to lower the drag on the engine and increase performance, mpg, hp.
  6. #21
    ChaseinBass's Avatar
    ChaseinBass is offline CarAudio.com Veteran
    Jul 2013
    Calif
    2,018
    6 Post(s)
    975 Post(s)
    No but probably is an expert marksman. Just ask him.
    Pioneer Prs80, Rockford DSR1, Taramps 15000 HD, two 18 team FI , 4x PPI900.4s, Massive Audio CT2 tweeters, CDT 6.5 mids and 2 pr Anarchy midbass, 3 group31 juice box batterys , lots of 0 gauge and NRG aluminum hardware, Triple 300 amp CES hairpins, 4 Banks of 6 ultra caps.
  7. #22
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,481
    42 Post(s)
    6155 Post(s)
    Quote Originally Posted by ChaseinBass View Post
    Prob has a degree for that also.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
    Soundstream Rubicon 1.2500D & 4.500 amps (New amps coming soon)
  8. #23
    Flipper245's Avatar
    Flipper245 is offline Senior VIP Member
    Dec 2014
    Langley bc
    304
    1 Post(s)
    149 Post(s)
    Quote Originally Posted by Cm_low View Post
    I'm running two alternators on my 1.0 lt, 3 cyl Chevy sprint. It works perfect! The alts only draw hp when there is a load on them. I'm having better results with two 140 amp alts than I did with one 250 amp alt. I upgraded to alts almost twice the size of stock. Never had a failure in almost 5 years.
  9. #24
    Flipper245's Avatar
    Dec 2014
    Langley bc
    304
    1 Post(s)
    149 Post(s)
    Be careful of cheap eBay alts. I've been using power master with great results. They're priced in the middle.
  10. #25
    Cm_low's Avatar
    Dec 2016
    Arnold, MO
    114
    30 Post(s)
    Quote Originally Posted by Flipper245 View Post
    Good to know. I haven't made it to that stage of looking to purchase yet but just wanted to know what I was looking for if I had come across something in the meantime. I seem to have hit my stock electrical limit at around 1500 watts but I am doing the big 3 soon and upgrading the battery since that may be causing some of the problem as well, it is the stock factory battery the car came with over 4 years ago.
  11. #26
    Flipper245's Avatar
    Dec 2014
    Langley bc
    304
    1 Post(s)
    149 Post(s)
    Yup big 3 and battery should help. I used a kinetic 1800 and power master 140amp alt for that power. I think those alts are under $200 and same with battery. More power than that and you're probably looking at some pricier upgrades.
  12. #27
    LoudSound's Avatar
    LoudSound is offline Senior VIP Member
    Dec 2016
    Toronto
    174
    86 Post(s)
    You would have to look that info up yourself, which can be easily found via the internet.
    Googling is a lost art these days
  13. #28
    hamedsahl0's Avatar
    hamedsahl0 is offline Junior Member
    Feb 2017
    IR
    salam khabam
    فرستاده شده از HUAWEI G730-U10ِ من با Tapatalk
  14. #29
    JohnKuthe's Avatar
    JohnKuthe is offline CarAudio.com Veteran
    Sep 2016
    Missouri
    2,074
    13 Post(s)
    1206 Post(s)
    Oh so your a mechanic this week.
    Keep dem lies coming.....
    ---------- Post added at 01:54 AM ---------- Previous post was at 01:53 AM ----------
    You can believe anything you want. But just because you believe something does NOT mean it correlates well with the objective facts.
    Wrong. Some can fit other vehicles moron. Do the google search.
    I'm sure some maybe do, but not terribly prevalent!
    John Kuthe...
    2006 Grand Caravan "Baby II"
    Alpine CDE-153BT HU
    Alpine PXA-H800 DSP
    Alpine PDX-V9 main amp
    Alpine PDR-V75 secondary amp
    4 Alpine SPR-69 6x9" midrange
    2 PHD 5.1 AF 5.25" drivers w/ separate tweeters and passive crossovers with plans of going full active!
    JL Audio 12TW3-D4 400W TW3 Thin-Line Series 12" Dual 4 ohm Subwoofer set to 2 Ohms
    Damplifier Pro, BQuiet and Luxury Liner Pro sound deadening, lots!
  15. #30
    Jul 2005
    WA
    14,481
    42 Post(s)
    6155 Post(s)
    WTF are you talkin about?
    Jump off a bridge please.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
Tags for this Thread
