Results 1 to 9 of 9
Reload Thread: Rear Deck Cover Up
    Eggroll's Avatar
    Eggroll is offline RingsOfSaturn>your music
    Oct 2014
    Death Metal > Your Music
    22
    533
    3 Post(s)
    256 Post(s)
    Rear Deck Cover Up
    Never realized how much pressure the rear deck is under. I thought the trunk was sealed off, but the deadener covering the old 6x9 holes in the rear deck ripped from the pressure.
    Any ideas on how to cover these large holes?
    2 12" Ethos; DC 320; XSD34, Diehard 34; Four 2/0 Eb Flex runs.
    Sold To: FineLinePimpin. Bought From: PapaGeno21
    ~2013 Nissan Altima 2.5 SV ~ South Florida~
    Austin175's Avatar
    Austin175 is offline CarAudio.com Elite
    Jan 2010
    Burlington,Ia
    872
    2 Post(s)
    242 Post(s)
    Re: Rear Deck Cover Up
    Make a ring out of mdf to cover the hole the spray foam maybe?
    2003 Lancer ES
    H/U- Pioneer 80Prs
    Mids/Highs- ????
    Sub Stage- DC Xlm2 12s(soon to be FI BTL Neo's)
    Mids/Highs Amp- Crescendo 1000C4
    Sub Amp- 2 Ampere 3800.1s
    Wiring- Welding 2/0, Welding 4g & Welding 8g
    Alt-Singer 270A
    Batteries- 4 Xs Xp3ks & 1 Lithium
    Enclosure- 3.33Cf tuned to 34hrtz
    Hertz Mafia's Avatar
    Hertz Mafia is online now FEATHER RUFFLER
    Jul 2016
    Michigan
    2,109
    42 Post(s)
    1361 Post(s)
    U could deadener the whole back dash... I would get under there and fiberglass everything solid
    LosIsATool's Avatar
    LosIsATool is online now CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,942
    109 Post(s)
    7667 Post(s)
    ABS. Just like you seal a door
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
    Eggroll's Avatar
    Oct 2014
    22
    533
    3 Post(s)
    256 Post(s)
    Quote Originally Posted by Austin175 View Post
    Quote Originally Posted by Hertz Mafia View Post
    Quote Originally Posted by LosIsATool View Post
    Whole deck is deadened, above and underneath, this^ was the result. I am thinking about fiberglass but at the same time I don't want to customize the vehicle too much.
    What ABS do you recommend?
    Slo_Ride's Avatar
    Slo_Ride is offline Take It Easy
    Oct 2005
    Back to ATL
    13,245
    35 Post(s)
    3227 Post(s)
    I'd use sheetmetal.
    Refs = PapaGeno21, Goindef154, 92c1v1c, Disarmer, chemmins, 97maxima, kroid777, ithertz, basscort2009, hunterw, mar08052, appleyard, millimac247, jonny101abc, sundownz, cranberryyumyum, mig139, daboyfrumdabx, skateguy92, basebalz13.
  7. Likes JohnKuthe liked this post
  8. #7
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,942
    109 Post(s)
    7667 Post(s)
    Sheet metal works also but ABS won't cut you open. Just get some thin stuff and Tesa double sided tape. Cut it out, tape it up, put a layer of deadener on it.
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  9. #8
    JohnKuthe's Avatar
    JohnKuthe is offline CarAudio.com Veteran
    Sep 2016
    Missouri
    2,057
    13 Post(s)
    1194 Post(s)
    Quote Originally Posted by Slo_Ride View Post
    I'd use sheetmetal.
    Yep! That's what I used to seal up the big holes in my inner door sheet metal to make it behave a little more than a speaker cabinet! Sheet metal stuck on with 1/16" foam tape then many little self tapping screws to make sure it stayed in place. Covered it with the BQuiet sound deadener I'd bought before I bought a bunch of Damplifier Pro!
    John Kuthe...
    2006 Grand Caravan "Baby II"
    Alpine CDE-153BT HU
    Alpine PXA-H800 DSP
    Alpine PDX-V9 main amp
    Alpine PDR-V75 secondary amp
    4 Alpine SPR-69 6x9" midrange
    2 PHD 5.1 AF 5.25" drivers w/ separate tweeters and passive crossovers with plans of going full active!
    JL Audio 12TW3-D4 400W TW3 Thin-Line Series 12" Dual 4 ohm Subwoofer set to 2 Ohms
    Damplifier Pro, BQuiet and Luxury Liner Pro sound deadening, lots!
  10. #9
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,239
    41 Post(s)
    6026 Post(s)
    scrap wood. Then bolt up them covers made from wood into those existing holes I see in the pic.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
Tags for this Thread
