Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
Reload Thread: All about fusing!
    mjoekingz28's Avatar
    mjoekingz28 is offline Member
    Oct 2016
    Mississippi
    32
    15 Post(s)
    All about fusing!
    I am interested in fusing sound properly. There are a few concerns I have about fusing.
    First, even if they do pop- do they still allow excess power or dirty electricity to harm your equipment.
    Second, what materials are they made of? Plated steel, aluminum, ....silver? And how do these materials correspond with letting energy flow freely when supposed to YET interrupt it in time when things go awry.
    Thirdly, and what got me to post, is the sound quality they pass without making distortion. Just like a good set of RCAs can improve (or not degrade) the sound, can fuses do this as well? It also seems silly to have the best copper wire in a low gauge and then put a piece of tin for a fuse next to the battery.
    Bottom line is, safety aside, will I get better power transfer from a thick 200A fuse versus a 60A fuse that has a stringy piece of metal inside. And what will the sound difference be in terms of volume, and possibly clarity if a subpar metal is used. And then, I just kind of wonder is the short run of a fuse so insignificant as to not be able to change the path of power flow.....and if it does, then I question the point of having quality contacts and connections.
    Papermaker85's Avatar
    Papermaker85 is offline Better built than bought!
    Dec 2006
    New orleans LA
    32
    12,495
    68 Post(s)
    2 Thread(s)
    5100 Post(s)
    Re: All about fusing!
    Fusing doesn't affect current flow much. Not enought to worry. Id definitally use it.
    Just buy a good unit and dont sweat it..
    Insidious Audio
    But you at 2ohm it's all good!
    yeah i told wife guy on here pm'ed me wanting to buy my amp she said tell him it not fs (cause she knows i'll spend more $ on new one) and told her i wanted d2 sub for bday next week she said tell ya'll i'm to old to go down to 1ohm lol..
  3. Likes ChaseinBass liked this post
  4. #3
    Hertz Mafia's Avatar
    Hertz Mafia is online now FEATHER RUFFLER
    Jul 2016
    Michigan
    1,786
    36 Post(s)
    1091 Post(s)
    I don't run any fuses. I'm not spending money on all this big wire to bottle neck it with some fuses... pretty much the only thing fuses are good for are of u get in a crash and your wires get pinched/cut open the fuse will pop. But the side of the wire that's still connected to the battery will be live and could still burn it down.
    I can't tell ya how many times I've have fuse holder melt or bubble up from poor connection. Yea I made sure everything was tight and good connection
    I'm comfortable enough for NO fuses in my ride.
  5. #4
    kr15's Avatar
    kr15 is offline Polluting Residentials
    Feb 2010
    California
    6,385
    25 Post(s)
    1317 Post(s)
    I havent ran fuses in like 5 years
    Team Flex Issues
    JVF Customz
    REFS- Supergumby5000, Lastcall, 919motoring, hippishake, daboyfromdabx (great seller), beach22
  6. Likes Hertz Mafia liked this post
  7. #5
    Dec 2006
    New orleans LA
    32
    12,495
    68 Post(s)
    2 Thread(s)
    5100 Post(s)
    Quote Originally Posted by Hertz Mafia View Post
    ill run fuses in every application. it never bottled necked anything. ive seen 1000HP motors fused and no "bottle neck" occurred..
    few years back a guy had a truck with a **** ton of the pioneer amps and subs and didt fuse because he gained .2 or something and the truck burned down. if he would have used a tad more power and fused it would haven been louder and NEVER burned down.. lol
    Ive also NEVER IN the nearly 20 years of installing gear had a fuse holder melt like your guys have. than again i use copper and use the correct techniques.
    ive been doing heavy industrial electrical for 13 years and ive yet to see properly designed breaker fail at the connection point. matter fact the contacts inside go way before anything else..
    Insidious Audio
  8. Likes ChaseinBass liked this post
  9. #6
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    13,441
    39 Post(s)
    5668 Post(s)
    To fuse or not to fuse....that's the ultimate question.
    I do. Because a fuse is cheaper than buying another 1000 dollar amp (for example)
    Some do, some don't. It's up to them if they wanna take that risk or if they're exp enough they know what they're doing. I myself ain't taking that chance tho.
    Many fuses come in a variety of sizes, colors, amperage, etc. Just pick the one that your amps draw the most amperage.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
  10. Likes ChaseinBass liked this post
  11. #7
    Roland's Avatar
    Roland is offline Senior VIP Member
    Dec 2012
    Atlanta
    491
    10 Post(s)
    232 Post(s)
    Fuses don't cost any power until they get to their threshold, and then they quickly blow. IIRC it's at 98% rating before it effect the current/voltage, example, 40 amp fuse only restricts current at 39.5 amps. Fuse your system at least 10% above your real time operating current and you won't loose anything.
    I try blow a fuse with music to see real time current so uif i can blow a 40 amp fuse but not a 60 amp then i step up one size, to 80 amps, and im' good to go. I alway try to use the smallest fuse posible.
    2001 Odyssey - 80PRS -MS8 - NVX JAD amps - Satori 6.5", Satori tweeters, Pioneer TS-W1200Pro
    2008 Odyssey - 4100NEX - Helix P-SIX - ND16FA-6 - GB25 - Titan 8, JAD 1000.1 - TS-W1200Pro Still in progress
  12. Likes ChaseinBass liked this post
  13. #8
    ChaseinBass's Avatar
    ChaseinBass is offline CarAudio.com Elite
    Jul 2013
    Calif
    1,917
    4 Post(s)
    905 Post(s)
    I use fuses and I use industrial holders and quality fuses and dont have any issues. I did melt a couple of "car audio" fuse holders thats when I switched to industrial type. Also I fuse to what the wire is rated or a little under, I have 0 gauge cable rated at 350 amps at 20' and use 300 amp fuses and have three runs giving me 900 amps of current available before a fuse would blow and I dont think my HD 15000 could pull that much current as I have not blown a fuse yet. I think I fuse over fear of car accident really because I dont think an amp is ever going to blow the fuse on a large amp anyway. When my 7ks power supply shorted out with it mounted to my back wall of truck, power supply grounded out to heat sink and actually melted the mounting screws to the cab of truck and caught fire and fuses still didnt blow and that was pretty close to a dead short. Oh ya That didnt even melt the fuse holders. Another thing is I fuse the three runs in the engine compartment and in the rear before the batterys that way in an accident and cable is pinched both ends are protected, also fuse the runs from battery to amps.
    Pioneer Prs80, Rockford DSR1, Taramps 15000 HD, two 18 team FI , 4x PPI900.4s, Massive Audio CT2 tweeters, CDT 6.5 mids and 2 pr Anarchy midbass, 3 group31 juice box batterys , lots of 0 gauge and NRG aluminum hardware, Triple 300 amp CES hairpins, 4 Banks of 6 ultra caps.
  14. #9
    Dec 2006
    New orleans LA
    32
    12,495
    68 Post(s)
    2 Thread(s)
    5100 Post(s)
    Stinger has decent fuse blocks.
    Industrial electrical produxts have to meet stiff standards. By far superior. Run a wire that will handle 125% of the maximum load and fuse according to the wires rated ampacity and you won't have a " bottle neck"..lol
    sure the fuse adds resistance but thats why you use 125% figures.
    Insidious Audio
  15. #10
    Jul 2013
    Calif
    1,917
    4 Post(s)
    905 Post(s)
    Quote Originally Posted by papermaker View Post
    Industrial electrical produxts have to meet stiff standards. By far superior. Run a wire that will handle 125% of the maximum load and fuse doe the wirea rated ampacity and you won't have a " bottle neck" sure the fuse adds resistance but thats why you use 125% figures.
    And funny thing is the industrial fuses and holders are cheaper than the "car audio" stuff too lol
  16. #11
    Jul 2005
    WA
    13,441
    39 Post(s)
    5668 Post(s)
    ^^Boy that's some wrongful advice....so your saying go past the limited mark over 25%?
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  17. #12
    Dec 2006
    New orleans LA
    32
    12,495
    68 Post(s)
    2 Thread(s)
    5100 Post(s)
    Quote Originally Posted by ChaseinBass View Post
    Ifs its not ul rated its pretty cheap but you have to be careful sometimes because alot of it is intended for higher voltages. Ul rated stuff sometimes is ******* crazy exlensive. A 4 input/output 4/0 non fuaed distro block was 200$!
    Insidious Audio
  18. #13
    Dec 2006
    New orleans LA
    32
    12,495
    68 Post(s)
    2 Thread(s)
    5100 Post(s)
    I know i have terrible grammer but im not sure what you dont understand about my statement.
    Limited mark? Im not understanding what you are implying.
    Insidious Audio
  19. #14
    Jul 2013
    Calif
    1,917
    4 Post(s)
    905 Post(s)
    Makes sence to me ? Over compensate with the cable by 125% and fuse for the cables rated amount.
  20. #15
    Dec 2006
    New orleans LA
    32
    12,495
    68 Post(s)
    2 Thread(s)
    5100 Post(s)
    Yes. Larger wire means less restistance.
    Fusing isnt to protect the end device but the wiring.
    Motors are slightly differet though. They have "heaters" designed to open before the windings in the motor but the wire is still fused before the starter..
    Insidious Audio
  21. Thanks ummduh thanked for this post
    Likes ummduh liked this post
