Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Reload Thread: Amp Trouble
  1. #16
    knowlton's Avatar
    knowlton is offline Junior Member
    Feb 2017
    Wv
    Re: Amp Trouble
    Yes! it's KAC, i miss sorry
  2. #17
    knowlton's Avatar
    Feb 2017
    Wv
    Re: Amp Trouble
    Quote Originally Posted by sounds_explicit View Post
    a battery just for your amp is ideal IF you have a proper alt to supply your reg battery and a battery for your system.
    you just throw in a battery and use the pos battery terminal to your amp and ground the battery to any location wont help. that battery will be bead in an hour of playing without it being able to re supply the power taken from the amp.
    you could run the neg power cable from amp to the original batteries ground or batteries ground location and see if it helps.
    could i use the positive wire? if i cut it in half? or will it make a difference
  3. #18
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,245
    41 Post(s)
    6030 Post(s)
    Re: Amp Trouble
    I wouldn't.
    Keep the colors the same. Prevent confusion later.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
Tags for this Thread
