Page 1 of 2 1 2 LastLast
Results 1 to 15 of 26
Reload Thread: Front Stage Thread
    Eggroll's Avatar
    Eggroll is offline RingsOfSaturn>your music
    Oct 2014
    Death Metal > Your Music
    22
    533
    3 Post(s)
    256 Post(s)
    Front Stage Thread
    Clearly the search bar isn't working so forgive me if this has been posted before.
    I have a 2013 Nissan Altima, and my front stage will consist of my:
    1 - AVH - x4800bs (on the way)
    1 - PPI 900.4
    2 - VX4-ST Supertweeters. 4 ohm 300 rms
    2 - PAX65 Speakers. 4 ohm 260rms
    So here are my questions.
    1) Is there any way for me to be able to wire the speakers and the tweets on 2ohms?
    2) If so, on what channels and settings do I install it?
    3) The 4800bs has a network mode, can I use this for my setup?
    (Need to know how many rcas I need to purchase)
    2 12" Ethos; DC 320; XSD34, Diehard 34; Four 2/0 Eb Flex runs.
    Sold To: FineLinePimpin. Bought From: PapaGeno21
    ~2013 Nissan Altima 2.5 SV ~ South Florida~
    Eggroll's Avatar
    Oct 2014
    22
    533
    3 Post(s)
    256 Post(s)
    Re: Front Stage Thread
  3. Likes JohnKuthe liked this post
  4. #3
    JohnKuthe's Avatar
    JohnKuthe is offline CarAudio.com Veteran
    Sep 2016
    Missouri
    2,057
    13 Post(s)
    1194 Post(s)
    Quote Originally Posted by Eggroll View Post
    Yep! Wire them in parallel! A fancy Electrical Engineering term for a very simple wiring job! ;-)
    John Kuthe...
    2006 Grand Caravan "Baby II"
    Alpine CDE-153BT HU
    Alpine PXA-H800 DSP
    Alpine PDX-V9 main amp
    Alpine PDR-V75 secondary amp
    4 Alpine SPR-69 6x9" midrange
    2 PHD 5.1 AF 5.25" drivers w/ separate tweeters and passive crossovers with plans of going full active!
    JL Audio 12TW3-D4 400W TW3 Thin-Line Series 12" Dual 4 ohm Subwoofer set to 2 Ohms
    Damplifier Pro, BQuiet and Luxury Liner Pro sound deadening, lots!
  5. Likes Eggroll liked this post
  6. #4
    k5james's Avatar
    k5james is offline Senior VIP Member
    Jul 2005
    Yuma, AZ
    283
    1 Post(s)
    112 Post(s)
    He can't do that unless he plans on running four though. He won't have stereo separation that way.
    To the OP there's no way you can run everything at 2ohms with the current setup you have. Yes you can use network mode. You'll just need two sets of RCAs. One for the front stage and one for the sub stage.
    2006 Dodge Ram 2500 Mega Cab 4x4
    HU: CD7200MKII
    Front Stage: SI TM25/ID X-69
    Front Stage Amp: PG Ti21000.4
    Sub Stage: Sundown SD-3 12 x2 (soon to be 3 SA-8v3s in a CSCStang TLine)
    Sub Stage Amp: PG Ti22000.1
  7. Likes Eggroll liked this post
  8. #5
    Eggroll's Avatar
    Oct 2014
    22
    533
    3 Post(s)
    256 Post(s)
    Quote Originally Posted by k5james View Post
    I was afraid of that. It's alright if I have to wire them independently at 4ohm if I get to keep separation. Was only curious if I would be able to wire at 2 ohms
    Wouldn't I need 3 sets of RCAs on network mode? A set for highs, a set for mids, and a set for substage?
  9. #6
    LoudSound's Avatar
    LoudSound is offline Senior VIP Member
    Dec 2016
    Toronto
    174
    86 Post(s)
    Did you choose those components judging by the stated RMS ratings? 300rms tweeters no kidding huh
    you need 1 set of rcas for 1 amplifier(duh) unless we're talking splitting the signal. your HU has 3 "preouts"/outputs/RCAs/whateveryouwannacallit for both your speakers and the sub. you're good in that department.
    you'd need separate amps for mids and highs since each set of rcas coming out of the HU is gonna have different signal for mids, highs, lows..
    Are you only planning 1 pair of mids? With that amp you could run another pair and since you're gonna be doing custom doors you might as well get another pair of same mids.
  10. Likes Eggroll liked this post
  11. #7
    k5james's Avatar
    Jul 2005
    Yuma, AZ
    283
    1 Post(s)
    112 Post(s)
    No, the outputs from the deck should be front/rear/sub. Unless you plan on running a rear stage you don't need to use the rear stage output. Send the front rcas to your front stage amp and the sub rcas to your sub amp.
    HU: CD7200MKII
  12. #8
    Eggroll's Avatar
    Oct 2014
    22
    533
    3 Post(s)
    256 Post(s)
    Quote Originally Posted by LoudSound View Post
    In network mode, the 3 RCA pre-outs from the hu change. Front becomes High, Rear becomes Mid, and Subwoofer is still Substage.
    The PPI has 2 RCA inputs, front and rear, which is why I asked if I could use network mode and set crossovers to each separate channel. (Tweets hooked up on front amp channels and mids hooked up on rear amp channels.)
    The pax 6.5s fit perfectly in the stock housing (after deadening and customizing a bit), and the tweets will be fiberglassed onto the side panel pocket on an almost on-axis angle, held by fasteners, so no custom doors. Maybe in the future
    ^Watch the video I posted earlier about Pioneer's Network Mode
  13. #9
    Jeffdachef's Avatar
    Jeffdachef is offline Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,973
    241 Post(s)
    7792 Post(s)
    keep at 4 ohms, you arent gonna sound any better at 2 ohms. Infact, it'll sound like garbage. 4 ohms on that ppi with pro audio speakers will be MORE than loud enough. If you have trouble with the harshness, leave a big gap between crossover points. Usually have to cross super tweets at 8 or 10khz and mids at 2.5khz to 3.15khz and adjust slope accordingly in order to tame them. Thats a much bigger issue then loudness. Pro audio speakers is already guaranteed ear piercing tap out loud, main goal is to make it sound good.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  14. Thanks Eggroll thanked for this post
  15. #10
    Eggroll's Avatar
    Oct 2014
    22
    533
    3 Post(s)
    256 Post(s)
    Quote Originally Posted by Jeffdachef View Post
    The manuals only show the PAX curve, not the tweets.
    The one on the top right
  16. #11
    k5james's Avatar
    Jul 2005
    Yuma, AZ
    283
    1 Post(s)
    112 Post(s)
    You sure? I didn't see see anything about that in the manual.
    HU: CD7200MKII
  17. #12
    Eggroll's Avatar
    Oct 2014
    22
    533
    3 Post(s)
    256 Post(s)
    Yessir, this video explains is briefly
    https://www.youtube.com/watch?v=UsGEEeshAE8
    And this one explains it in detail (straight from Pioneer)
    https://m.youtube.com/watch?v=WvJXYh6vk_0
  18. #13
    Eggroll's Avatar
    Oct 2014
    22
    533
    3 Post(s)
    256 Post(s)
    Bottom line, I just want to know if I should use standard mode or network mode.
    I HATE how the hu doesn't have a volume knob, and the steering wheel controls are already failing (prob because the overuse and the vibration). I'm 5'11" and this small sedan isn't friendly for me so I have to lean all the way back. I have long monkey arms but I still can't reach the hu without leaning forward alot.
    Long story short: I want to buy a brick from CKB designs so I can control the main volume and bass gain next to my seat. Can't really do it in network mode but I wanna see what's best for my setup. Need to know how many RCAs I need to buy
  19. #14
    k5james's Avatar
    Jul 2005
    Yuma, AZ
    283
    1 Post(s)
    112 Post(s)
    In that case you could use the crossovers on the amp to go active and just run the HU in normal mode. You'll lose some of the advantages of network mode but it sounds like you care more about getting loud than finely tuned sq. I say go for it.
    HU: CD7200MKII
  20. #15
    Eggroll's Avatar
    Oct 2014
    22
    533
    3 Post(s)
    256 Post(s)
    Oh I love loud, but quality is also right up there
Tags for this Thread
