Results 1 to 6 of 6
Reload Thread: Right side speakers break up
    Jak900r's Avatar
    Jak900r is offline Junior Member
    Jan 2017
    Port saint Lucie, fl
    Need a little advice. I recently installed a pioneer avh291bt in my 2004 Mitsubishi. I also installed 2 Sony 6.5 in the front and 2 Kenwood in the rear. The wire harness was all soldered and I used heat shrink tubing on them. I got the schematics for the speakers and cap crimped the door speakers. The left side speakers sound great however; the right side are not good. When volume is under 15 they are clear but when you raise the volume or bass levels the right side sound like the speakers are blown. I have bought another set of speakers and they do the same. I bought a new harness and resoldered all the connections and still the same. I also brought the radio to best buy for them to test it and they said all was good. The only thing is I had to extend the ground wire. Could that cause the issue with only the right side? I have also put the factory unit back in and did not have the problem. Any suggestions would be great.
    Papermaker85's Avatar
    Papermaker85 is online now Better built than bought!
    Dec 2006
    New orleans LA
    32
    13,414
    68 Post(s)
    2 Thread(s)
    5551 Post(s)
    Re: Right side speakers break up
    without being there it is hard to say. I'm thinking it a bad connection or a issue with the head unit. switch the left a right speaker channels to there opposing channels and see if it does it in the other side.
    i told wife guy on here pm'ed me wanting to buy my amp she said tell him it not fs (cause she knows i'll spend more $ on new one) and told her i wanted d2 sub for bday next week she said tell ya'll i'm to old to go down to 1ohm lol..
    2twelves's Avatar
    2twelves is offline Junior Member
    Jan 2017
    New york
    8 Post(s)
    The headunit is bad or the speaker wire connects are loose some where start with all your wires on that side why not upgrade wire while your at it
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,059
    40 Post(s)
    5947 Post(s)
    Check wiring connections 1st before spending $$. It's $0.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
    fixinit's Avatar
    fixinit is offline Member
    Sep 2016
    Phoenix, AZ
    99
    55 Post(s)
    Great idea to swap sides. It very well might be the HU.
    JVC KD-R330
    Memphis PR 6.5"
    JBL GTO938 6x9"
    Dual SBPA8
    KnuKonceptz Kolossus 4ga
    20dB
    Jul 2005
    WA
    14,059
    40 Post(s)
    5947 Post(s)
    Quote Originally Posted by papermaker View Post
    Congratulations toiletpaper....you finally said something smart.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
