Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 38
Reload Thread: Speaker brackets
    neil4374's Avatar
    neil4374 is offline Senior VIP Member
    Nov 2016
    los angles
    151
    69 Post(s)
    Speaker brackets
    I need some advise please...
    I have taken out my old speaker out of the car door.
    You can see the speaker in its housing and the empty door panel.
    Problem is the new speaker is too small to fit directly onto the door panel. Is the best way forward to make or buy a plastic/wood adapter or bracket?
    I actually thought that the old speaker came out of the plastic housing and I could just put the new one in there but its one solid unit.
    **** I should of checked more throughly!
    The Camry's Avatar
    The Camry is offline Hey, I Try.
    Sep 2013
    Western Oregon
    2,898
    14 Post(s)
    1305 Post(s)
    Re: Speaker brackets
    Quote Originally Posted by neil4374 View Post
    Here...Attachment 26555826Attachment 26555827
    Yea. Mdf bracket works fine.
    Sent from my SGH-T999 using Tapatalk
    Gain on an amplifier to meant to be matched to the output voltage of your headunit. Think 3 volt, 4 volt, 5 volt pre out specs you see on headunit specs. This is how gain works for a given pre out(5 volt) theoretically. However most head units clip(start to distort) at around 80% of your volume so your 5 volt pre out wont give 5 volts Cleanly. You will most likely get 4 volts out at something like 33/40 on your volume knob and would thus set your gain to 4 volts. (these things can be measured with a GOOD Multimeter. )
    80% of your total volume is (max volume) X 0.8.
    Example is 40(is your max volume so, 40 X .8=32
    neil4374's Avatar
    Nov 2016
    los angles
    151
    69 Post(s)
    Icon12 Re: Speaker brackets
    Thank you.
    Am I right in assuming I just order 6.5" speaker mdd brackets or is it more complex than that?
    trumpet's Avatar
    trumpet is offline CarAudio.com Veteran
    Jan 2011
    Grafton, ND
    37
    6,792
    43 Post(s)
    1859 Post(s)
    What is the year, make and model of the vehicle?
    Rubyserv - I believe I can delivery joy every time you drive by the power of an incredible sound system. Barry Schanz, Owner
    Authorized dealer for CDT Audio - Shop With Us Now.
    FB | Rubyservsales
    IG | Rubyserv
    neil4374's Avatar
    Nov 2016
    los angles
    151
    69 Post(s)
    Hey,
    Here you are but It's korean car.
    Ssangyong Rexton Rx320 2002.
    I tried looking it up on Crutchfield but this car isn't exported to the US.
    It can be found in the UK but not this model.Arrrhhhh
    trumpet's Avatar
    Jan 2011
    Grafton, ND
    37
    6,792
    43 Post(s)
    1859 Post(s)
    Hey,
    Look up a Nissan from the same year. I have a pair of adapter brackets here that would almost certainly work.
    FB | Rubyservsales
    IG | Rubyserv
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,277
    41 Post(s)
    6048 Post(s)
    That speaker isn't removable from the pod/bracket?
    My s10 has similar but the pod the 6.5" speakers are into the pod itself is riveted to the door itself.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
    neil4374's Avatar
    Nov 2016
    los angles
    151
    69 Post(s)
    Quote Originally Posted by trumpet View Post
    Thanks.
    Any particular Nissan model?
  9. #9
    neil4374's Avatar
    Nov 2016
    los angles
    151
    69 Post(s)
    The speaker is attached to the speaker housing and it all unscrews so theres just a metal whole left.
  10. #10
    trumpet's Avatar
    Jan 2011
    Grafton, ND
    37
    6,792
    43 Post(s)
    1859 Post(s)
    Thanks.
    Altima, Sentra
    FB | Rubyservsales
    IG | Rubyserv
  11. #11
    Jul 2005
    WA
    14,277
    41 Post(s)
    6048 Post(s)
    Oh that *****.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  12. #12
    neil4374's Avatar
    Nov 2016
    los angles
    151
    69 Post(s)
    Oh that *****.
    Yer! Real nasty! Haha
    ---------- Post added at 02:59 PM ---------- Previous post was at 02:58 PM ----------
    Altima, Sentra
    Thank you
    ---------- Post added at 02:59 PM ---------- Previous post was at 02:59 PM ----------
    Altima, Sentra
    Thank you
  13. #13
    neil4374's Avatar
    Nov 2016
    los angles
    151
    69 Post(s)
    Do you guys use mdf speaker brackets or plastic like scosche?
  14. #14
    neil4374's Avatar
    Nov 2016
    los angles
    151
    69 Post(s)
    I have just realised I haven't taken into consideration the distance from the bare metal door to the inner door where the speaker grill fits. Thats 32mm according to my calculations. So not only does it need to be 32 mm thick it also has to be the right size for the new speakers and old holes. Re measure I think!
  15. #15
    drei4runner's Avatar
    drei4runner is offline Member
    Nov 2016
    Los Angeles, CA
    125
    48 Post(s)
    Try PVC Speaker Adapters - CNC Machined - In Stock or Custom Made. I went through them and purchased speaker brackets specifically made for the model year of my vehicle. Also, just to be on the safe side, order the spacers too. I ordered the 1/4" spacers for both front doors since the speakers I purchased were too big and it would hit the windows when rolled down. Just an FYI, if the spacers still aren't enough and you find that the magnets are still hitting the windows when rolled down, try using 1/4" foam tape to give it that extra space. That's what I did since the magnets were still hitting the windows. Hope this helps you out.
  16. Thanks neil4374 thanked for this post
