Results 1 to 7 of 7
Reload Thread: where can i get my alt. beefed up?
    aphinney's Avatar
    aphinney is offline CarAudio.com Elite
    Nov 2002
    in my house
    33
    828
    Icon32 where can i get my alt. beefed up?
    is there anywhere i can go to get my alt. beefed up so i dont have to go buy like a stinger alt.???
    TEAM AUDIOHYPE
    TEAM REVOLUTION
    TEAM KINETIK
    TEAM HO ALTS
    TEAM AUDIOHYPE
    3x world champs
    3x world record holders
    fury's Avatar
    fury is offline Member
    Jun 2004
    Indiana
    65
    Re: where can i get my alt. beefed up?
    just about any local alternator shop should do it.. it might be nearly as expensive as buying an H.O. alternator.. so make sure you check pricing before you go through with it.
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    the only problem with re-winding alts, other than the low cost differential between a new alt, is that when they rewind an alt for higher current, they re-use the same housing for it. So, you have simply a higher current alternator packed in a small case, which causes a lot more heat buildup and inefficiency than you'd get with a properly sized and built-from-the-ground-up high output alternator.
    It may just be worth it to buy and install a HO alt then to try to get your current one rewound. Just my two cents.
    iceteebone's Avatar
    iceteebone is offline Banned
    Aug 2003
    Michigan
    33
    37,876
    look into some HO alts. from these places: Dominick Irraggi [email protected], www.excessiveamperage.com, www.mean-green.com, www.mralternator.com, www.alterstart.com.
    trungthiendo's Avatar
    trungthiendo is offline Senior VIP Member
    Feb 2004
    amherst, ma
    32
    255
    rewound won't give u that much more amps...liek others have suggested...look into an HO alt
    Head Unit: Alpine CDA-9833
    Speakers: Polk/MOMO MMC650 (coaxials with ext. cross)
    Sub: Digital Design 9512
    Mono Amp: Hifonics Brutus bx1500
    Speak Amp: Tsunamni db4440
    Upcoming: in a 94 camry
    -Components: don't know yet
    -Midbass maybe?
    -seel and peel or second skin
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Quote Originally Posted by Jack Frost
    Actually, a lot of HO alts use the same casing size as the stock alts.
    The problem with rewound alts is that they don't upgrade EVERYTHING internally like a HO alt does, so the rewound simply isn't as "beefy" as a HO alt even of the same amperage rating. Plus, for the cost of a rewound you could just go get a higher amperage HO alt. There are limits on how high they can rewind an alt to (for example, my GM 105amp could only be rewound to a 140amp, and that would have cost $250. A 200A from irragi was just barely more expensive).
    But, just about any mechanics shop should be able to rewind an alt for you.
    Puggsley456's Avatar
    Puggsley456 is offline Who said you could talk?
    Apr 2003
    WPG>MB>CAN
    479
    Quote Originally Posted by squeak9798
    The price really depends on your local shops. I had my 105amp GM alt rebuilt for $140cdn. With a complete rebuild, custom stator and larger diode. And now its 140amp.
    - 99 Cougar -
    - Rainbow CMX265 Kickbass - PG ti600.2 -
    - Mach 5 Audio (2) IXL12's in 3.2 cubes [email protected] 33hz - USAmps MD.1D -
  1. HO ALt
    By vinnie_febs in forum Wiring, Electrical and Installation Help
    Last Post: 05-07-2004, 02:48 AM
  2. hm....alt or yellow top?
    By batsbaseball14 in forum Wiring, Electrical and Installation Help
    Last Post: 05-06-2004, 09:34 PM
  3. HO alt adaptation.
    By BooLeaN in forum Wiring, Electrical and Installation Help
    Last Post: 04-17-2004, 01:44 PM
  4. 200 amp alt overkill on a civic w/ 1500 watts?
    By pudgewack in forum Wiring, Electrical and Installation Help
    Last Post: 03-31-2004, 03:09 AM
  5. Tsunami 1800 amp, battery, alt...
    By BumpinDoug in forum General Discussion
    Last Post: 09-15-2003, 10:51 PM
