Results 1 to 7 of 7
Reload Thread: Radio stations problem
    niceguy's Avatar
    niceguy is offline Junior Member
    May 2002
    log angeles
    42
    I'm using the kenwood kdc-215s and I'm having a problem with my radio stations. I can only get uneven channels (ie. 88.1, 88.3, 88.5, 88.7........).
    I'm sure there is a way to solve this problem and see all channels (ie. 88.0, 88.1, 88.2.....).
    Help!!! any suggestions?
    rubix777's Avatar
    rubix777 is offline Junior Member
    Apr 2002
    Rowland Heights, CA
    35
    15
    I think your HU has an option to disable SEEK. SEEK searches for the next frequency that it receives the best from. When you turn it off you'll be allowed to go to each tenth of a frequency.
    If that doesn't solve your problem, then I don't know.
    gator4thehaters's Avatar
    gator4thehaters is offline Senior VIP Member
    Mar 2002
    Indianapolis, In
    45
    323
    Like the last post said or make sure your antenna is hooked up.
    Live life 2 the full cuz u only live once!
    niceguy's Avatar
    May 2002
    log angeles
    42
    It's not the antenna because it worked great until I disconnected the battery. After I connected it back, the problems began.
    Can you please explain how do I solve the SEEK problem when the radio is off?
    Mar 2002
    Indianapolis, In
    45
    323
    I think you misunderstood the post. You can't control the 'seek' feature with the unit off. You have to turn it on and find the 'seek' or 'auto' button. If you have the owners manual it will tell you how to enable or disable the seek feature if you don't have either of these buttons. Some radios have a button that says 'ame'. (i think, or something like that) Its the same button as the above ones and that would be the one you'd look for too. Hope I helped.
    MikeofTulsa's Avatar
    MikeofTulsa is offline The one and Only!
    Feb 2002
    Tulsa, OK
    21,244
    1 Post(s)
    309 Post(s)
    the problem is it is somehow set up for a diff country's music stations...i believe europe uses even stations and america uses odd stations....hope that helps
    Mar 2002
    Indianapolis, In
    45
    323
    I've never thought about that one! I guess you learn something new everyday, huh?!!
