Results 1 to 6 of 6
Reload Thread: wiring from scratch
    csheriff's Avatar
    csheriff is offline Junior Member
    Jun 2004
    Rockwell, IA
    Icon32 wiring from scratch
    hey everybody, im new to the sight, but not new to the stereo wiring world, but i do have a quick question. i am wiring up a stereo for a friend in a Fed Ex truck, and there is no wiring harness to start with, so i have to make my own. i know im gonna need power, ground, speaker leads, but what other wires am i gonna need, and how do i hook them up? any help would be greatly appreciated.
    KaeZoo's Avatar
    KaeZoo is offline CarAudio.com Elite
    May 2004
    Grand Rapids, MI
    1,103
    Re: wiring from scratch
    The easiest way will probably be to find the wire harness leading to the back of the key switch. Use a multimeter to find one wire that has power at all times, and another that has power only when the key is on. Tap these wires for the head unit power wiring. Be sure to use fuses on the new wires to the head unit. These two wires and ground are all you need other than the speaker connections.
    csheriff's Avatar
    Jun 2004
    Rockwell, IA
    which power wire goes to the actual power wire on the cd player, the constant or the ignition on wire? then what does the other one hook to on the cd player? also, what amp of fuse do you recommend?
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    37
    8,933
    You will need both constant and switched power to the HU. The size fuse is usually specified by the deck maker. For the constant power lead I would tap into the fuse panel and use a blank spot there rather than tap into the ignition. For the switched lead the ignition is pretty much the only source.
    Artificial Intelligence is no match for Natural Stupidity.
    Never underestimate the power of stupid people in large numbers.
    Life's tough...it's even tougher when you're stupid.
    csheriff's Avatar
    Jun 2004
    Rockwell, IA
    ok, ill be able to figure all that out, one more question, i went and looked at a headunits harness just a minute ago, and there was the dimmer wire hooked up, necissary or not? i dont think so but figured id ask.
    KaeZoo's Avatar
    May 2004
    Grand Rapids, MI
    1,103
    Quote Originally Posted by csheriff
    Not necessary to the head unit operation. Its purpose is to dim the display when the lights are turned on, kind of like the factory intrument lighting. In a FedEx truck, he'll probably do most of his driving during daylight hours.
  1. Remote Wiring
    By BIG_SUPERMAN72 in forum Wiring, Electrical and Installation Help
    Last Post: 05-03-2004, 05:43 PM
  2. wiring Q
    By exodus5139 in forum Wiring, Electrical and Installation Help
    Last Post: 03-27-2004, 04:35 AM
  3. Factory speaker wiring. Leave it or replace it?
    By gibhunter in forum Wiring, Electrical and Installation Help
    Last Post: 03-20-2004, 02:22 AM
  4. eclipse (F-TEN)headunit wiring?
    By PR8GG in forum Wiring, Electrical and Installation Help
    Last Post: 12-04-2003, 06:23 AM
  5. !¿!¿!¿Total wiring help!¿!¿!¿
    By unard in forum Wiring, Electrical and Installation Help
    Last Post: 08-07-2003, 02:49 PM
