Results 1 to 6 of 6
Reload Thread: 2 amps in house
    earth_bender's Avatar
    earth_bender is offline Junior Member
    Apr 2014
    chicago
    26
    6 Post(s)
    2 amps in house
    I have a regulated switching power supply 12v/29amp 4 channel 250x4 prime punch amp
    2 kicker comp 15" subs now that i got that project accomplished i want more i can feel the 15's want more power i can hear them whisper it to me, for jus project sake and fun was wondering any ideas as to power 2 amps in home what route to take what kind of power supply would be able to handle it do i go by amps my punch is 50 amps and lets say my second amp is 50 amps how do i power this do i need a 100 amp power supply or do i just need to get close to 100 amps or use car audio batteries with a charger help i want to bend the earth and compete against my neighbor i can hang with him for what i got i recon if i got a car reciever i could bang with him but i can't get low with jus 40 watts to 500 watt subs
    pickup1's Avatar
    pickup1 is online now CarAudio.com Veteran
    Aug 2005
    Roanoke,TX
    53
    8,467
    19
    7 Post(s)
    838 Post(s)
    Re: 2 amps in house
    You'll need a big power supply,but probably be cheaper if you just bought a Home receiver.
    RayRay1417's Avatar
    RayRay1417 is offline Senior VIP Member
    May 2014
    South west florida
    243
    42 Post(s)
    Re: 2 amps in house
    Quote Originally Posted by pickup1 View Post
    ^^^Yes. I've fine bolth and let me tell you a big home audio amp works the best and is cheapest in the long run. Go find a crown 800 it to blow your balls off
    bubbagumper6's Avatar
    bubbagumper6 is offline CarAudio.com Veteran
    Apr 2006
    The D
    11,052
    897 Post(s)
    Re: 2 amps in house
    Don't waste your time with power supplies and amplifiers designed for vehicle use. Most efficient route is just do it right from the start and buy a plate amplifier (amplifiers designed to run off 110V AC) like these
    Bash 300S Digital Subwoofer Plate Amplifier 300W RMS
    Bash 500S Digital Subwoofer Plate Amplifier 500W RMS
    Also, 500w in a house will be much louder than 500w in a vehicle, there's no road/engine noise to overcome so don't think that's too little power. I hooked a single 10" to a 100w plate amp in my living room and it got loud enough to annoy my neighbors.
    Joseph7195's Avatar
    Joseph7195 is offline Walkin Tall
    May 2011
    Saltillo, Mississippi, United States
    38
    1,467
    385 Post(s)
    Re: 2 amps in house
    Also make sure your amperage rating for your fuse in your fuse box can handle the extra current draw from the outlets you will be using. I've worked with 240 volts for home theaters before and it was really unnecessary. So if you really want to go that route, look for lots of money to be spent. But if you can't make your system loud on 110, you're probably doing something wrong.
    Quote Originally Posted by adulbrich View Post
    We don't have food stamps on the east side. Its called a link card. Man, the grocery is packed on the first of da month. I shit you not, a homie got stabbed over a can of soup.
    Apr 2014
    chicago
    26
    6 Post(s)
    Re: 2 amps in house
    ok joe riddle me this again i'm doin this bcuz i jus like tinkering and i want have a vehicle no time soon i jus want to do it jus to do it without traditional home reciever. my set up now is beautiful 2 door speakers pyle 6" and a 15 in kicker comp hooked up to a power supply rated at 12v and 39 amps the amp is rated at 50amps 250w rms and it bangs i was wondering how could i implement a second amp rated at 750 rms w100 amp fuse jus for kicks but at the same time i don't want to start a fire now this is what i was thinking a battery matched up of course and a 150 amp in between hooked up to the power supply and a battery charger all in plug into a power strip with surge protect and if you were to do this again jus saying how would you play this out
  1. Possible to run Car Amp in house?
    By Cali_Screw in forum Home Audio/Video
    Last Post: 11-04-2009, 06:56 PM
  2. help with wiring a car amp in house
    By cwatts2oo8 in forum Wiring, Electrical and Installation Help
    Last Post: 05-10-2009, 05:01 PM
  3. car amp in house?
    By pimpedout97x in forum Home Audio/Video
    Last Post: 06-14-2008, 05:07 PM
  4. car amp in the house
    By Unregistered in forum Amplifiers
    Last Post: 03-24-2003, 09:20 PM
  5. Amp In The House!!!!!
    By Unregistered in forum Wiring, Electrical and Installation Help
    Last Post: 02-08-2002, 06:58 PM
