Page 3 of 3 FirstFirst 1 2 3
Results 31 to 39 of 39
Reload Thread: What size alternator do I need?
  1. #31
    Based's Avatar
    Based is offline CarAudio.com Elite
    Mar 2014
    Louisiana
    883
    1 Post(s)
    417 Post(s)
    Re: What size alternator do I need?
    Quote Originally Posted by rujoesmith View Post
    its for when you need just a bit more volume than anyone else
    https://www.youtube.com/watch?v=4xgx4k83zzc
    Yeah I've seen the movie lmao.
  2. #32
    sharkman's Avatar
    sharkman is offline poor bass head
    May 2014
    oakland ca
    517
    2 Post(s)
    201 Post(s)
    Dang i hope i dont run into this problem. I have a 90 bronco which has 80 amp alt. But im running 2x power to the re sx18 off a mb quart 1600 plus a 400 watt amp for my 6.5s. I havent put the bass amp in not knowing if i should at least upgrade my alt to athe 130 g3 alt first
  3. #33
    yogegoy's Avatar
    yogegoy is offline Senior VIP Member
    Dec 2013
    San Jose, Ca.
    312
    97 Post(s)
    Quote Originally Posted by mylows10 View Post
    Gain is not a bass knob or volume knob
    Totally agree with you on this!
  4. #34
    LosIsATool's Avatar
    LosIsATool is online now CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,727
    107 Post(s)
    7518 Post(s)
    So OP where is the gain on the amp set? Also what head unit do you have?
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  5. #35
    av83's Avatar
    av83 is offline CarAudio.com Veteran
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    Quote Originally Posted by Based View Post
    the amp pulls 80a so...
    75a alt. around 40% of that is going towards your normal car stuff, so we are left with 60% of 75. 0.6 times 75 is 45a. 80a minus 45a is 35a. After 45a, it's up to your battery to pick up the extra 35a. If your battery is stock then it is probably pulling between 35ah to 60ah. I think if you are not going to go any higher in wattage (like get a bigger setup), then just get a little bit bigger of an alternator such as 100 - 150a and that'll solve the problem and you won't have to have a battery taking up space in your trunk or wherever you decide to put it. If you do think you might go bigger in terms of bass then I'd get something like a 250 - 270a alternator just to prepare for future builds.
    But I'm a noob so...
    This is assuming that the amp is playing a full power sine wave indefinitely... Music is dynamic. A good battery up front and
    upgraded battery/chassis grounds is more than sufficient to support a zx750. I agree with @DDtC ; on pretty much all he's said. Clipping, poor connections, or both are the most likely culprits here.
    An upgraded alt is ALWAYS a good thing to have in this hobby. But not having one is not the real problem here. Fix the issues... then see if you still want/need one.
  6. #36
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    54
    22,434
    141 Post(s)
    1 Thread(s)
    6011 Post(s)
    Pics of where the gain is set at ? Did you use a dmm ? Unibody cars don't have very many good grounding points so I also agree this is prolly the issue most cars/ trucks can hold more than 750 rms with the exception of a few. But the alt is the best option only if truly needed
  7. #37
    Based's Avatar
    Mar 2014
    Louisiana
    883
    1 Post(s)
    417 Post(s)
    Pics of where the gain is set at ? Did you use a dmm ? Unibody cars don't have very many good grounding points soni also agree this is prolly the issue most cars/ trucks can hold more than 750 rms with the exception of a few. But the alt is the best option only if truly needed
    My truck has never had problems dealing with my BRX1100 @ 1 ohm. Idk how efficient the amp is or if it is rated at 16V or what but my headlights have never dimmed. For some reason my alt charges everything at 14.1 and that's where it stays even at idle playing a 0db 40hz tone lol. Maybe I'm doing it wrong who knows. I guess I'm just lucky
  8. #38
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,434
    141 Post(s)
    1 Thread(s)
    6011 Post(s)
    Recheck your grounds all your connection points as well the bxi isn't very efficient since you asked And load test your battery
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  9. #39
    BoomTaco64's Avatar
    BoomTaco64 is offline CarAudio.com Elite
    Jan 2014
    gone...
    691
    296 Post(s)
    the strut tower is not a good location for a ground. use the floor of the vehicle, scratch away all pain and use your own screws and star washer.
  1. What size alternator do I need for 2000rms?
    By moparerrnocar in forum Wiring, Electrical and Installation Help
    Last Post: 05-24-2012, 07:23 PM
  2. questions about my system. what 2nd battery, & what size alternator do I need?
    By es101346 in forum Wiring, Electrical and Installation Help
    Last Post: 11-18-2010, 06:23 AM
  3. What size amp do I need
    By jspiller in forum Wiring, Electrical and Installation Help
    Last Post: 02-12-2002, 03:04 AM
  4. What size amp do I need???
    By swinehunter56 in forum Amplifiers
    Last Post: 02-10-2002, 08:47 PM
  5. What size amp do I need???
    By Unregistered in forum Wiring, Electrical and Installation Help
    Last Post: 02-07-2002, 12:09 PM
Tags for this Thread
