Results 1 to 9 of 9
Reload Thread: 4 Channel Wiring
    coolername's Avatar
    coolername is offline Junior Member
    Mar 2014
    Bellingham, WA
    21
    9 Post(s)
    4 Channel Wiring
    So I have a decent grasp on the situation but I've never amped my speakers before. I'm looking at a 4 channel amp and four 3ohm speakers. The amp is a Soundstream RUB4.600 which is fine at 2ohms from what I hear but what will the final ohm load be after I hook up all 4 speakers? Each speaker has 2 sets of terminals so how does that work? Also, my headunit has front and rear preamps and I already have my subs hooked up to rear. Only running front to the 4 channel with a daisy chain RCA just cuts out the fade feature right? Sub control stays the same? Thanks!
    fly_marlin's Avatar
    fly_marlin is offline CarAudio.com Elite
    Apr 2014
    United States
    1,947
    6 Post(s)
    828 Post(s)
    Re: 4 Channel Wiring
    It's rated 100W x4 at 4 ohms and 150W x4 at 2 ohms. At 3 ohms it'll be about 125W x4. You can get RCA splitters. You'll lose the fading ability with that.
    CrossoverOre's Avatar
    CrossoverOre is offline CarAudio.com Elite
    May 2012
    oregon
    1,041
    205 Post(s)
    if each speaker is a 3 ohm speaker then the amp will see 3 ohms per channel which that amp is fine with. What midrange are you installing? As for the rca connection all you have to do is run 1 pair to the amp out of the front output from the deck. Select 2ch input and make sure you connect rca to front input on the amp, no daisy chain required.
    coolername's Avatar
    Mar 2014
    Bellingham, WA
    21
    9 Post(s)
    Thanks guys! I'm using Soundstream SST6x9 and 4x6.
    May 2012
    oregon
    1,041
    205 Post(s)
    what kind of rig? some factory setups use a little beefier wire and some vehciles are a pain in the *** to run new wires. I would look into upgrading the wire thats in there for most vehicles if you are going to be running that kind of power.
    coolername's Avatar
    Mar 2014
    Bellingham, WA
    21
    9 Post(s)
    85 Cadillac Fleetwood! It's my lowlow so I've had the interior apart numerous times. So I figure I just cut apart all the speaker wires that were plugged into my deck and instead run em straight to the amp right? Cuz signal is from the RCA.
    CSCStang's Avatar
    CSCStang is offline Enclosurist
    Mar 2014
    OC, Ca
    2,971
    411 Post(s)
    2 Thread(s)
    973 Post(s)
    Yes. Disconnect the speaker wires behind the hu and run upgraded wires from the speakers to the amp, if you can access them through the door jamb.
    DAILY '12 Mustang AVH2700BS
    RS28F/682.9CF/PWX 8....ppi900.4/gmd5602 3 way active
    2 HDS208 TLINE @44hz...xtr2200.1
    BEATER '99 Silverado xcab AVH3600BHS
    X comps....c1c/PWX 8".....ppi600.2
    2 XFL 1544 TLINE @30hz....FSD3800.1
    DC 300 powerhouse....big 3 in both with 2/0 weld
    Check out my past builds at Cscstang customs on fb or cscstang_customs ig.
    I'll be back to building eventually....
    coolername's Avatar
    Mar 2014
    Bellingham, WA
    21
    9 Post(s)
    Quote Originally Posted by CCooney View Post
    Why would it matter if I can access the old wires? Isn't it actually easier to just run new ones?
  9. #9
    CSCStang's Avatar
    Mar 2014
    OC, Ca
    2,971
    411 Post(s)
    2 Thread(s)
    973 Post(s)
    You can do that too as long as the stock are a thick enough gauge for what you're running.
  1. 4 Channel Wiring
    By thehardknoxlife in forum Wiring, Electrical and Installation Help
    Last Post: 10-05-2005, 12:31 AM
  2. Center channel wiring question
    By Blazemore in forum Speakers
    Last Post: 07-18-2005, 05:49 PM
  3. 4-Channel Wiring ?
    By Alpine2005 in forum Amplifiers
    Last Post: 04-11-2005, 08:39 PM
  4. 4 channel wire harness?
    By i3abyjay25 in forum Wiring, Electrical and Installation Help
    Last Post: 10-10-2004, 10:55 PM
  5. 2 channel wiring
    By saywhat? in forum Wiring, Electrical and Installation Help
    Last Post: 05-23-2004, 08:23 PM
