Results 1 to 4 of 4
Reload Thread: DC Audio level 4 wiring Q
    CallMeRockford's Avatar
    CallMeRockford is offline Junior Member
    May 2014
    Lincoln Park, NJ
    im buying a DC audio level 4 15" w/ 1.2k amp soon and am pretty sure i know the answer to this but i have a debate to settle with a not so knowledgeable friend and wanted to make sure: originally, it runs 1400 watts @ 2 ohms per voice coil. if i run the coils in parallel to the monoblock, does it then work 2800 watts @ 1 ohm or stay at the 1400 watts.
    ill be showing the "friend" this post once it gets replies
    thanks!
    Dmac1991's Avatar
    Dmac1991 is offline '12 Focus Bangin
    May 2013
    Dallas - Denton, Tx
    26
    1,634
    4 Post(s)
    569 Post(s)
    Re: DC Audio level 4 wiring Q
    a sub doesn't run wattage. That is up to the amp to run power.
    The sub (sounds like a dual 2 ohm) is slated to handle 1400 rms (each voice coil rated at 700 rms) total
    That sub will handle 1400 rms no matter. If you get a dual 2 ohm sub, you can run it at 1 or 4 ohms and no matter what you run it at, the total rms power will always be 1400 rms
    So to answer your question in your terms, it will stay at the 1400 watts
    2012 Ford Focus
    Ampere Audio | SounDrive | Royal Excelene | STP Atlantic | Digital Designs
    http://www.caraudio.com/forums/itrader.php?u=1029894 = Feedback
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,442
    142 Post(s)
    1 Thread(s)
    6016 Post(s)
    The amp will see full power from the amp What amp ?
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
    May 2014
    Lincoln Park, NJ
    I realized after that I worded that post weird. Sorry and thanks for the answer dmac
  1. Replies: 108
    Last Post: 06-24-2008, 06:50 PM
  2. 2 dc audio level 4 box
    By Nismofreak in forum Enclosure Design & Construction Help
    Last Post: 03-24-2008, 10:48 AM
  3. DC audio level 3 tahoe flex vid
    By animalbmx in forum General Discussion
    Last Post: 02-27-2008, 01:49 PM
Tags for this Thread
